Old 10-01-2013, 10:59 AM   #43
Dimman
Kuruma Otaku
Dimman's Avatar
We really need to get something down on roll rates and camber curves.
It can help quantify how much of an effect each has on keeping the tire where we want it.
Because titanium.
Old 10-01-2013, 11:23 AM   #44
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i'm sure someone's modeled the car in 3D, it wouldn't take much work to make some internet friendly animated gifs.
but they'd want $$$ for it..
Old 10-01-2013, 11:30 AM   #45
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I just got a copy of Lotus Suspension Analysis yesterday. I plan to tackle this when I get a chance.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
The Following 2 Users Say Thank You to SubiePig For This Useful Post:
Calum (10-01-2013), Dimman (10-01-2013)
Old 10-01-2013, 11:33 AM   #46
Wepeel
Drives: '13 BRZ Ltd
I've done the math on the camber change as a function of steering angle, caster, and SAI. I'll post up the results.
Camber change as a function of bump/droop - I don't think there's anything unique about the McStrut geometry on the twins - I've seen a few of those curves for Imprezas, if we don't have the exact geometry of the twins we can probably use the Impreza curves as an approximation. There is camber gained during bump (more than non-trivial), just not as much as what you can get from a wishbone/multilink.
Wepeel is offline   Reply With Quote
The Following User Says Thank You to Wepeel For This Useful Post:
Dimman (10-01-2013)
Old 10-01-2013, 11:38 AM   #47
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
do these models take into account axial body roll and resultant change in the relative position of the suspension pickup points as a result of weight transfer?
Old 10-01-2013, 03:08 PM   #48
SubiePig
The software is able to do all of this, just have to learn how to work with it.
Old 10-01-2013, 03:12 PM   #49
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
The Following User Says Thank You to 7thgear For This Useful Post:
Dimman (10-01-2013)
Old 10-01-2013, 03:15 PM   #50
CSG Mike
CSG Mike's Avatar
This isn't exactly what you're looking for, but in our experience, this is our observation with Street tires (RS3, Z2, RE11A, etc) with a -1.5ish drop all around for track used based on wear and pyrometer readings:
12k front springs need roughly -2.8 camber
10k front springs need roughly -3 camber
9k front springs need roughly -3.3 camber
8k front springs need roughly -3.5 camber
14k rear springs need roughly -2.3 camber
12k rear springs need roughly -2.4 camber
11k rear springs need roughly -2.5 camber
10k rear springs need roughly -2.6 camber
These results are based on our observations with multiple Tein SRC and JRZ setups, and are for maximum grip under track conditions, which gives you anecdotal evidence that can be extrapolated into camber curves. As always, YMMV, and this is very, very crude data.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
autobrz (10-01-2013), Calum (10-01-2013), Dimman (10-01-2013), normancw (03-22-2014)
Old 10-01-2013, 03:25 PM   #51
Dimman
Kuruma Otaku
Dimman's Avatar
Stock bars?
Because titanium.
Old 10-01-2013, 04:42 PM   #52
CSG Mike
CSG Mike's Avatar
Stock bars?
Yup, stock bars.
Dimman (10-01-2013)
Old 10-01-2013, 04:44 PM   #53
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Yup, stock bars.
do you think static camber requirement would have changed had the height remained at OEM levels
Old 10-01-2013, 06:19 PM   #54
CSG Mike
CSG Mike's Avatar
I honestly don't know, since I don't know the camber gain/loss curves under compression. Those numbers above are what is necessary with our setup, and is only meant to be a single data point; it's hardly conclusive.
Old 10-01-2013, 06:27 PM   #55
Wepeel
Drives: '13 BRZ Ltd
Okay numbers are posted here, because it seemed like it should be it's own thread.
http://www.ft86club.com/forums/showthread.php?t=48107
The Following 2 Users Say Thank You to Wepeel For This Useful Post:
autobrz (10-01-2013), CSG Mike (10-02-2013)
Old 07-03-2019, 09:37 PM   #56
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
Originally Posted by CSG David View Post
Are you running square spring rates? That alone will induce some understeer. Your alignment should also fix some of the issues as well. Most setups dial in understeer for safety purposes.
what's the recommended spring rates? i out of the box KWV3s
BRZ RN is offline   Reply With Quote
Sway Bars: What's The Trade Off? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-24-2020 12:18 PM
brz and fr-s sway bars different? 1010110 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-03-2013 02:43 AM
ST sway bars bmxhotsauce Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-09-2013 04:11 PM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 07:00 PM
Cusco Sway Bars? wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 08-04-2012 06:31 AM
