#43 |
Kuruma Otaku
We really need to get something down on roll rates and camber curves.
It can help quantify how much of an effect each has on keeping the tire where we want it.
Because titanium. |
#44 |
i'm sorry, what?
Drives: Canada
i'm sure someone's modeled the car in 3D, it wouldn't take much work to make some internet friendly animated gifs.
but they'd want $$$ for it..
#45 |
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I just got a copy of Lotus Suspension Analysis yesterday. I plan to tackle this when I get a chance.
![]() Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication STX Build thread 14th/67 SCCA Nationals (2014) |
#46 |
Drives: '13 BRZ Ltd
I've done the math on the camber change as a function of steering angle, caster, and SAI. I'll post up the results.
Camber change as a function of bump/droop - I don't think there's anything unique about the McStrut geometry on the twins - I've seen a few of those curves for Imprezas, if we don't have the exact geometry of the twins we can probably use the Impreza curves as an approximation. There is camber gained during bump (more than non-trivial), just not as much as what you can get from a wishbone/multilink. |
#47 |
i'm sorry, what?
Drives: Canada
do these models take into account axial body roll and resultant change in the relative position of the suspension pickup points as a result of weight transfer?
#48 |
The software is able to do all of this, just have to learn how to work with it.
#49 |
i'm sorry, what?
Drives: Canada
#50 | |
12k front springs need roughly -2.8 camber 10k front springs need roughly -3 camber 9k front springs need roughly -3.3 camber 8k front springs need roughly -3.5 camber 14k rear springs need roughly -2.3 camber 12k rear springs need roughly -2.4 camber 11k rear springs need roughly -2.5 camber 10k rear springs need roughly -2.6 camber These results are based on our observations with multiple Tein SRC and JRZ setups, and are for maximum grip under track conditions, which gives you anecdotal evidence that can be extrapolated into camber curves. As always, YMMV, and this is very, very crude data. |
#51 | |
Kuruma Otaku
Because titanium. |
#52 |
#53 |
i'm sorry, what?
Drives: Canada
do you think static camber requirement would have changed had the height remained at OEM levels
#54 |
I honestly don't know, since I don't know the camber gain/loss curves under compression. Those numbers above are what is necessary with our setup, and is only meant to be a single data point; it's hardly conclusive.
#55 | |
Drives: '13 BRZ Ltd
http://www.ft86club.com/forums/showthread.php?t=48107 |
#56 | |
Drives: Blue BRZ
what's the recommended spring rates? i out of the box KWV3s
| Sway Bars: What's The Trade Off? | Captain Snooze | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 04-24-2020 11:18 AM |
| brz and fr-s sway bars different? | 1010110 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 08-03-2013 01:43 AM |
| ST sway bars | bmxhotsauce | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 05-09-2013 03:11 PM |
| FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! | NJA | Brakes, Suspension, Chassis | 18 | 04-07-2013 06:00 PM |
| Cusco Sway Bars? | wootwoot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 08-04-2012 05:31 AM |
