Old 09-19-2013, 01:16 AM   #239
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Originally Posted by Aznsky View Post
Any rubbing along the fender (or other issues) for those lowered with 245's? Especially those that autox / track their cars?
Did autox a couple weeks back and had zero rubbing issues, I am lowered on tein flex and have 245/40/17 hankook v12 with 17x9 +35.
Build Thread
Instagram
The Following 8 Users Say Thank You to midnight23 For This Useful Post:
Aznsky (09-19-2013), Corner3garage (10-18-2013), fooddude (05-31-2014), HATED1 (04-17-2015), karma003 (10-15-2013), normancw (09-22-2013), trigger happy (04-07-2016), YangerD (05-31-2015)
Old 09-20-2013, 03:21 PM   #240
Aznsky
Drives: Nissan 350Z (sold) 13' Whiteout FRS
Curious if anybody has run this setup on stock suspension? Thinking of doing it next year until I can afford coilovers
Aznsky is offline   Reply With Quote
Old 10-01-2013, 01:35 AM   #241
Hachi86Roku
Hachi86Roku's Avatar
Here's mine, lowered on eibach sportlines and maxed out camber bolts up front (i do need 5mm spacers for the front once i dialed in the camber, didnt need it before)
Hachi86Roku is offline   Reply With Quote
Old 10-11-2013, 11:40 PM   #242
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
Looks good man. Got any more pics? Whats your tire size? Im considering getting these wheels and springs at the same time, but I dont know if I should go with the sportlines or pro-kit. I prefer the sportlines but not if its more of a hassle. Did you max out the front camber bolts so it wouldnt rub? How much camber do you have and any other rubbing issues?
eSOLOR is offline   Reply With Quote
Old 10-11-2013, 11:46 PM   #243
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
You don't really need any camber to not rub. The 17x9 +35 with 255's square fits fine on stock springs. We got several clients with this set-up.
FT-86 SpeedFactory is offline   Reply With Quote
The Following 2 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
boxer 2.5 (10-12-2013), TouchMyHonda (12-31-2013)
Old 10-12-2013, 02:50 AM   #244
Hachi86Roku
Hey, I when I had the car without camber bolts, and just dropped it, the front came to be -0.3 and rear -2.5. At this point with the 245/40 17 tire size I had around 1cm clearance between tire and perch, after adding camber bolts (maxed it out) Im not too sure how much camber the front is now (guessing around 1.75) but the gap between it became dangerously close (around 2-3mm) hence why I had to add 5mm and the space in between the space between the tire and spring perch to be around 8mm (one finger) which is fine for me
STX Whiteout Build Thread
http://www.ft86club.com/forums/showthread.php?t=47980
Anybody in the West Lafayette, IN area pm me
Old 10-14-2013, 12:55 PM   #245
EMS Guy
The cynic
Drives: An ambulance
I was debating on these...The 5x100 bolt pattern seems to be death wish in the wheel world. Surely limits the playing field. Should be 5x114!
Any hoot, these wheels in the +35 are definitely custom. I don't see that combo ANYWHERE other than the place linked above. Tire Rack has higher offsets like 45 and 42. Personally, I think the +35 in a 9" wide is ideal all day long.
It appears they are on sale on that top link too now....hmmm....decisions decisions. I mean, $999 for the customs....NOT BAD AT ALL. Might have to pull the trigger.
EMS Guy is offline   Reply With Quote
Old 10-14-2013, 12:59 PM   #246
EMS Guy
The cynic
Looks awesome! Where did you get them from?
Old 10-14-2013, 01:29 PM   #247
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
LOVE DEZOD got mine at xmas time last year from them. they were closed over the break and I still got my wheels 3 days later.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 10-14-2013, 01:30 PM   #248
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
17x9 +35 in 5x100 is easily available now.
Numerous vendors here on this site have them readily available and in stock. Not really custom. The same size in SBC is "custom" and only available through group buys.
Old 10-14-2013, 06:01 PM   #249
wparsons
wparsons's Avatar
Originally Posted by stockysnail View Post
They are cheaper on tire rack unless this guy is offering free shipping. Better offset too as 35 will stick out way too much according to the wheel fitment guide that's stickied.
9" +45 with 245's will almost be guaranteed to rub on stock struts, you need coilovers (or spacers, but if you're going that route why get the higher offset) to make them fit, especially if you want to run useful camber.
If you're lowered with a bit of camber the +35 doesn't really poke much at all.
flickr
whataboutbob (10-15-2013)
Old 10-14-2013, 06:31 PM   #250
FT-86 SpeedFactory
We got these in stock as well, ours is free shipping so technically cheaper after you do a shipping calculation on their site. +35 in a 17x9 is the way to go hands down. http://ft86speedfactory.com/enkei-rp...et-of-803.html
SportInjected (10-14-2013), whataboutbob (10-15-2013)
Old 10-14-2013, 09:49 PM   #251
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
^I got my set from these guys and couldn't be happier!
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 10-15-2013, 12:22 AM   #252
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Do you Ship to Australia? Specifically Melbourne?
Wise is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
