alpine, ATL BRZ, ftc~brz, jamesm, King Tut, OrbitalEllipses, sklimo, SmsAlSuwaidi, Sportsguy83, whitefrs
Old 09-30-2013, 11:25 AM   #1261
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I worked harder on this birthday than any other. I even took off work that day. I had to prep my SpecE30 for my race weekend in Memphis. I didn't have any time to check the forums till today.
Welcome back. The forum was extremely quiet this weekend.
Old 09-30-2013, 11:26 AM   #1262
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I just ordered a Hallman MBC... Will report back leak test and more boost curves for @King Tut to feast on them....
I agree that I think there is something wrong with your Perrin MBC. You are actually the only person I have ever known to use a Perrin MBC. Have you checked with all the @PERRIN boys on this site? All the Subaru guys either run the Hallman Pro or the Grimmspeed MBC. I will be very interested to see your results. It would have only been a little more money to get the GFB G-Force II EBC though.
Old 09-30-2013, 11:30 AM   #1263
Sportsguy83
Drives: Limited BRZ
$105 vs. $250+
I don't even remember what made me choose a Perrin MBC... LOL
At least the Hallman will be easier to move whenever I decide to go EBC.
Old 09-30-2013, 04:57 PM   #1264
PERRIN_Jeff
PERRIN_Jeff's Avatar
Drives: Matte Black STI
So I think my Boost controller took a crap.
I'm now running Perrin's MBC. This are my latest Plots. I'm actually hitting peak boost like at 4200 RPMs
Below are my Boost curves when on 93 pumpgas and hitting 11-12 psi, same Perrin MBC.
So I did some runs yesterday to see how Boost behaved. Interesting results. I think my Perrin MBC took a shit..... Two things why I think this. First look at the Red curve. That one is without Perrin MBC. It drops from 10.5 to about 9.7 which is fine, it has always been like that.
In situations like this, giving us a call could really help figure out what is going on. This part has been around for years and years and been one of those items we sell tons of with virtually ZERO problems. Also why go through the hassle and cost to buy something else when we could have easily taken care of you with zero out of pocket cost?
With any MBC, engine load plays a huge factor in the actual boost. Another factor is how hot the manifold is and how cool the charge air is. Between those factors you could get a change to the drop in boost. I just tuned a car with an MBC and it takes about 3 runs before boost settles and then it can be adjusted. Secondly if you do a run that is like a 1st gear the boost is much lower than if you do a run that is like 4th gear. I am not saying that is the problem here but that is what crossed my mind.
Second thing is debris in the MBC making the ball not seat (very rare), and thirdly if the MBC was taken apart and or unscrewed too far, its possible the spring got stuck making the adjustment not adjust anything.
I still want you to call with the part in hand and we can walk you through a couple of quick tests to see what is going on. We can quickly eliminated the MBC being the problem.
PERRIN_Jeff is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Jeff For This Useful Post:
PERRIN (09-30-2013)
Old 09-30-2013, 05:04 PM   #1265
Sportsguy83
Drives: Limited BRZ
No biggie. I'm actually going to do a leak test on the whole intake tract to make sure its not a boost leak. I know you guys take care of us customers and I planned to call as soon as I had results ruling out a leak and testing other MBC. I have lots of Perrin products in my car and have had zero problems with them.
Just to add to the discussion, I do all runs in 3rd gear to eliminate that variable. I also always followed instructions as far as not taking the screw too far out, only taken it out so that 5 lines can be seen. I will have results later this week and will update everyone. I have not 1000% ruled out the MBC is ok and something different is the issue.
Thanks for chiming in.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
ftc~brz (10-01-2013)
Old 09-30-2013, 05:10 PM   #1266
PERRIN_Jeff
Still give me a ring with that in hand. One quick "Blow" test will tell us a bunch
I deal with a bunch of weird setups all the time and the first thing I always do is a pressure test of the system starting at the inlet of the turbo. I have a cap and silicone coupler that I will clamp to the intake (prefer at the filter) and pressurize everything to 20psi (or more). It's amazing the leaks you find!! On the BRZ's I find that the crank case vent hose under the manifold blows off easily as well as the upper hoses on the intake manifold (under the cover). One of those creates a big enough leak that not only do you loose boost, but your AFR's will run super rich, which effects the boost big time(because of cooler EGT's) when using an MBC.
Just a few more things to think about.
The Following 2 Users Say Thank You to PERRIN_Jeff For This Useful Post:
PERRIN (09-30-2013), Sportsguy83 (09-30-2013)
Old 09-30-2013, 05:34 PM   #1267
Sportsguy83
Drives: Limited BRZ
Thanks for the chat on the phone Jeff. I will update everyone with the results of my leak test.
PERRIN_Mladen (09-30-2013)
Old 10-01-2013, 03:12 AM   #1268
boxer 2.5
Drives: 2007 Impreza, 2013 BRZ
I love your wheel choice! Any rubbing issues?
boxer 2.5 is offline   Reply With Quote
Old 10-01-2013, 09:21 AM   #1269
Sportsguy83
Drives: Limited BRZ
Zero rubbing issues and thanks!!
Old 10-01-2013, 10:22 PM   #1270
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Im using it too
Lol
Sent from somewhere
Old 10-01-2013, 10:27 PM   #1271
Sportsguy83
Drives: Limited BRZ
Originally Posted by whitefrs View Post
Im using it too
Lol
Sent from somewhere
Hahaha. I'm doing a pressure test Thursday, results will be coming soon.
Old 10-03-2013, 11:51 PM   #1272
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
This is what my Catch Can "catched" after 2.5K turbo miles
Here is what i got after 1k hard driving
Sent from somewhere
The Following User Says Thank You to whitefrs For This Useful Post:
Sportsguy83 (10-04-2013)
Old 10-04-2013, 10:51 AM   #1273
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Mostly condensation in both of those pictures and less than I have seen in my catch can.
Old 10-04-2013, 11:01 AM   #1274
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
mine has been in e85 with is known for more condensation
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 05:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 11:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 03:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 08:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-13-2012 12:35 AM
