Old 09-27-2013, 10:33 PM   #1
CSG Mike
CSG Mike's Avatar
Brake fluid review opportunity
Do you drive hard? Has your brake pedal ever gotten softer or mushy? Do you want to try a top shelf brake fluid at a sponsored price? We're looking for some folks to independently review Torque RT700.
I've had an excellent experience with it in the CSG BRZ, as well as both the time attack S2k, and the street concept S2k, and I'm confident that anyone who tries it will be satisfied with the performance. My next brake flush for my on S2k will be with RT700.
If you're interested in reviewing, please post on this thread or PM me (@CSG Mike) directly with the following information. We're looking for cars ranging anywhere between completely stock all the way to dedicated race cars.
- Mods on the car
-- Current brake mods on the car (pads/lines/rotors/bbk?)
-- Suspension (coilovers? springs?)
-- Power adders (bolt-ons? Turbo? Supercharger?)
- Driving habits
Please be prepared to post a review of your experience with the fluid, both good and bad! We are looking for honest impressions of the product.
The Following 5 Users Say Thank You to CSG Mike For This Useful Post:
448hpsti (09-28-2013), Anthonytpt (09-29-2013), bkblitzed (09-29-2013), Sportsguy83 (09-27-2013), whataboutbob (09-28-2013)
Old 09-28-2013, 01:08 AM   #2
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Can buy, will try, where do I PayPal?
Today ds2500 and motul 600
Tomorrow Essex sprint
GC koni race
"Built Fi"
Driven hard
448hpsti is offline   Reply With Quote
Old 09-28-2013, 03:21 AM   #3
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I'm willing to give it a try. I'll be doing 8 sessions worth of HPDE at Heartland Park in Topeka, KS in the season ending NASA event October 11-13.
After a few sessions at Mid America Motorplex last weekend at a NASA HPDE event I had some definite pedal softness and braking degradation. Heartland Park is a much more demanding track brake wise ... will definitely need to address the issue prior to the Heartland event.
Scion 2013 FR-S
RCE Tarmac 2 Coilovers
Volk TE37SL Black Edition 18x9.0 +45
255/35/18 Dunlop Direzza ZIIs
EBC Yellow Pads
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 09-28-2013, 09:23 AM   #4
wparsons
wparsons's Avatar
Passed the link along to a friend, not sure if he has any more races this year or not though. He runs an ITR with a supercharged K20 and isn't really friendly to brakes
flickr
Old 09-28-2013, 01:22 PM   #5
whataboutbob
AutoX-10/10ths every run
I'd be interested.
Stangarone Motorsports
Robert (a.k.a. Bob) Stangarone
SDR-SCCA Solo2 #686
Suspension -
Shocks: factory struts
Springs: RaceCompEngineering yellows
Camber plates: Whiteline COMCs (with Subie washers)
Rear camber: Whiteline LCAs
Rear toes: Whiteline
Anti-roll bars: Whiteline 20mm adj front (on softest presently) and 16mm adj rear (on softest presently)
End links: Whiteline adj front and rear
Upper strut bars: Whiteline (front)
Bushings: Whiteline front LCA bushings (main and anti dive/caster)
Camber bolts: Whiteline (front)
Subframe bushings: Whiteline
Alignment & suspension settings -
Ride height: Approx a bit over 5" from the pinch weld to the ground front & rear
Caster: +8.75
Alignment: -2.75 in front, -2.5 in rear
Shock settings: factory
Weight: 2743 - no driver, no junk in the trunk, 1/3 tank of gas
Corner weights: not sure
Tire pressures: I've ran 42F and 34R, 36 square, and 34F and 42R. 34F/42R might be the best so far as it allowed me to rotate the car on exit nicely.
Engine & drivetrain -
Header: factory
Over pipe: factory
FI: Innovate Motorsports SC, stage 1, Innovate 91 basemap
Front pipe/cat: Invidia N1 cat-back, Invidia front pipe with high flow cat
Intake: aFe dry drop in filter w/OEM intake
ECU: factory
Crank pulley: Perrin
Motor mounts: Cusco
LSD: stock
Differential bushings: Whiteline
Transmission bushing: Whiteline
Mustang Dyno results: 176WHP 140FTLBSTQ @Evasive Motorsports (NA), 216.9WHP 178WTQ @Infamous Performance (FI - Innovate SC)
Wheels/Tires, etc -
Wheels: Black 17x9 Enkei RPF-1 35mm offset
Tires: Dunlop ZII 245/40-17
Brakes: Stoptech slotted front rotors and Hawk HP+ pads, Grimmspeed MCB
Battery: Stock
Seats: stock
Build thread:Here
Old 09-28-2013, 01:56 PM   #6
ImAwesome
Drives: 99' M3, 13' SWP Brz
I'm Interested
Completely stock except for exhaust.
Have a track event at VIR Nov. 9-10
Otherwise alot of spirited driving
ImAwesome is offline   Reply With Quote
Old 09-28-2013, 03:29 PM   #7
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
- Mods on the car
- Driving habits
I'd be very interested!
-Stock brakes at the moment.
-H&R Super Sport Springs, RacerX Rear LCA's, SPC Camber bolts, Whiteline Subframe bushings, differential bushings, transmission insert.
- Alignment -1.5* front camber, -2* rear camber, stock caster, 0 toe all around.
-17x8 Enkei RPF1's on 235/45-17 Conti Extremecontact DW
-Headerback exhaust, E85 and 91 tune by Delicious Tuning, drop in Apex'i filter.
- 90% spirited driving in canyons/mountain roads. This car is a dedicated fun car for me.
Zach3794 is offline   Reply With Quote
Old 09-29-2013, 03:00 PM   #8
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
I wouldn't mind this.
Anthonytpt is online now   Reply With Quote
Old 09-29-2013, 04:09 PM   #9
nelsmar
GC koni race
"Built Fi"
Driven hard
So.... a bolt on kit & tune is considered "built"? I have more fuel upgrades than yours i must be "hella built".
My flickr - Canibeat
Local magazine scout
Old 09-30-2013, 12:18 PM   #10
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Yes
You're hella built
Old 09-30-2013, 02:05 PM   #11
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
interested..
-- Mods on the car
currently none
currently none, may upgrade pads in the spring and add a brake cylinder brace
- Driving habits
on the street or on the track i like to be very minimal with my brakes. If i brake, i want to brake once and not let go until i can get back on the gas or come to a complete stop. So i brake deep and hard, releasing pressure as i get to the apex or complete stop.
Old 09-30-2013, 03:08 PM   #12
CSG Mike
CSG Mike's Avatar
I will get back to everyone after I get off of work (my day job). Sorry for the delays! I was at CVR all day Saturday setting up and testing a few cars, and moving Sunday.
whataboutbob (09-30-2013)
Old 09-30-2013, 06:16 PM   #13
Calum
That Guy
Drives: 2013 asphalt FRS MT
Go on...
Old 09-30-2013, 07:42 PM   #14
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
PM sent.
gdrider77 is offline   Reply With Quote
Torque RT700 - DOT 4 Racing Brake Fluid - Review CounterSpace Garage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 121 06-05-2023 10:23 PM
Brake fluid question barabia Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-01-2013 12:08 AM
Brake fluid leak.. tintumz22 Issues | Warranty | Recalls / TSB 9 02-01-2013 04:20 PM
Track Day Brake Fluid Skorov AUSTRALIA 2 11-11-2012 08:10 PM
Brake fluid volume celica73 Tracking / Autocross / HPDE / Drifting 1 08-20-2012 03:05 PM
