Old 09-27-2013, 11:27 AM   #29
CSG Mike
CSG Mike's Avatar
Originally Posted by infinite012 View Post
Lubricating wheel studs? Sounds like you're going to end up with your wheels falling off. Lubrication of a fastener will change the fastener preload and torque required.
Obviously that is an exaggeration and your wheels will likely not fall off, but please don't just say "slap on some antiseize and go about your business."
We use anti-sieze on our lugnuts. We also include a few packets with every set of CSG lug nuts we sell. We specifically chose a lubricant that is compatible with our Chromoly and Aluminum lugnuts, and will resist temperatures up to 2000F.
The purpose for this is to reduce/eliminate galvanic corrosion from mixed metal contact. It also makes the lugnut go on easier
CSG Mike is online now   Reply With Quote
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Alabang 86 (02-28-2014), Guff (03-19-2014), King Tut (09-30-2013)
Old 09-27-2013, 11:28 AM   #30
CSG Mike
CSG Mike's Avatar
Originally Posted by rice_classic View Post
Just slap a little anti-seize on your lugs an go. You'll be just fine.
Edit: I have to elaborate some so people don't think it's a bad idea.
Porsche recommends it in their factory manuals:
"Thinly grease thread, shank and under head (between screw head bearing surface and spherical cap ring) of the wheel bolts with Optimoly TA (aluminum paste). Do not grease bearing surface of the spherical cap facing the wheel. If heavily contaminated, clean bolts first with a lint-free cloth."
Personal Experience:
At the race track when wheel lugs are torqued to spec on dry studs what often happens is they bond themselves to the studs after the heat/abuse of the race track and when try to remove them it is very very difficult. So much so that I've broken a stud right off while trying to loosen a lug. This is where I learned of the necessity to use a little anti-seize on the stud threads. If you're changing/removing wheels in between sessions at the track (aka: when hot), it's something you're going to want to do. I've been racing with anti-seize on my studs for almost a decade now and since then I haven't broken a stud since.
Anti-seize is not oil, it's not moly.. it's just a soft metal (nickel/copper) with a mild lube as a carrier. It's does very little to affect the torque value especially when it's not being applied to contact faces of the things being torqued together.
Just some more fun reading:
http://www.pro-touring.com/threads/7...-the-question!
"As a technician for over 20 years I have done many different things, mostly based on employer based requirements.
Now a few years ago I was working at a Firestone Mastercare. Well we got Modern Tire Dealer magazine and in that publication for the record one of the tire/wheel/whatever groups did proper investigation and found that "silver" nickle based anti-seize is fine and even recommended as it does not change torque values by any more than 5% but actually normalize the fastener torquing.
And if you ever look at any properly maintained semi or trailer you will see anti-seize on the wheel studs.
So silver nickle based anti-seize is ok and even recommended this will keep things from rusting, prevent things from binding or galling."
The other thing to consider is that a closed wheel stud is such that it keeps the elements away from the stud and it's threads. When running open lugs, the studs are exposed to the elements and corrosion will eventually occur so for a daily driven application where open lugs are part of the equation it can keep the corrosion down as well as keep the lug from corroding to the stud.
This is an excellent post.
The Metal "fusion" is galvanic corrosion I previously mentioned.
Old 09-27-2013, 11:28 AM   #31
CSG Mike
CSG Mike's Avatar
Originally Posted by kvnchu View Post
i've snapped a ton of lugs on this car..
I'm gonna buy you a harbor freight torque wrench...
Old 09-27-2013, 11:32 AM   #32
CSG Mike
CSG Mike's Avatar
Originally Posted by 448hpsti View Post
Failing at brakes so far and have yet to go pay Essex my wad.
My brakes aren't ducted, and they suck. So maybe you're onto something there! I just am not sure adding ducting will give me the thermal capacity I need, in the same physical volume of pad and rotor. I have only tried a ds2500 in stock size, are any of you convinced these setup plus track specific pads offer enough stop to not want a unrated brake kit for an Fi car?
I am on r comps with oe studs and steel lugs, no issue, do you guys think I should be worried about catastrophic failure of all five studs since I drive like an idiot on oe studs?
And yes, factory brake fluid in these cars is horse piss
The studs are fine.
I'd recommend you try some race pads before committing to a BBK. If the race pads are still lacking, THEN it's time to get a BBK.
Or, alternatively, if you know you're going to stick to tracking, get the BBK up front, because it'll reduce your operating cost substantially.
Ducting will help cool your brakes faster, making the sustained temperatures climb, faster, and potentially lower the equilibrium temperature your brakes reach, but if that equilibrium is still too high for the setup, then yes, ducting alone won't be enough.
amram (03-20-2014), ciro (09-28-2013), Dezoris (09-27-2013)
Old 09-27-2013, 11:44 AM   #33
trackjunkie
Drives: Subaru BRZ Blue
rice_classic: Great pictures on covering the boots with tape. Will definitely do that.
smb_style: Can you post a link to where to get the Ti shims. I definitely want them based on your experience.
Glad to see I am not the only track junkie out there
trackjunkie is offline   Reply With Quote
Old 09-27-2013, 11:44 AM   #34
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
The anti seize I use goes on the back of the wheel, against the rotor. I dunno, lube on lug and my driving style would sit in the back of my head all wrong I think, unless you tell me the carrier for the copper in the anti seize is not a petroleum base
hold on a second
you anti-sieze the mating surface between the WHEEL and the ROTOR and you're wondering why you're snapping the studs?
anti-sieze goes on the THREADS, no where else
any two surfaces that mate flat together for the purposes of sticking together should be free of any contaminants, most of all anything that prevents friction.
Old 09-27-2013, 11:55 AM   #35
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Here are the ti-shims:
http://hardbrakes.com/?gclid=CJaVm6L467kCFYSd4AodDkUAfw
smbstyle is offline   Reply With Quote
The Following 2 Users Say Thank You to smbstyle For This Useful Post:
amram (03-20-2014), normancw (03-23-2014)
Old 09-27-2013, 11:57 AM   #36
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i like diagrams...
The Following 3 Users Say Thank You to 7thgear For This Useful Post:
amram (03-20-2014), DAEMANO (03-01-2014), Guff (03-19-2014)
Old 09-27-2013, 01:00 PM   #37
Dezoris
Dezoris's Avatar
Originally Posted by smbstyle View Post
I was considering the DBA rotors, but honestly, after 5 very hard days at Sebring and Barber, the OEM rotors are still holding up fine. Normal heat checking, but nothing that is of concern. I have a set of blanks ready to go, but am going to run these OEM rotors to see how far I can go with them.
I've been running the TF Brake Cooling kit and ti-shims since I started tracking, and I think they help contribute to extending the pad and rotor life. I know two guys whos OEM rotors were trashed after a day or two at Sebring.
Sounds like you found the best setup for OEM brakes without costing an arm and leg.
I personally don't like the idea of the ducts it's harder to control the cooling. It's either full open or blocked off. In your case if you are always on a heavy braking track it becomes the magic bullet.
Old 09-27-2013, 02:32 PM   #38
smbstyle
smbstyle's Avatar
yeah good point, on a light braking track I'd be worried about overcooling and not having any bite when going into the next braking zone.
Old 09-28-2013, 02:10 PM   #39
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Barring the sci-fi reality of Mr. Freeze's freeze ray... There's no such thing as too much cooling for your braking system. (In the context of a car on a racetrack)
Always leave those ducts open, they're not just helping your heat-sinks scrub heat they are helping key parts in your rotating assembly stay cool like your wheel bearings. It isn't a need to "control cooling" as Dezoris says, it is a need to improve the functionality of the heat-sinks (that is, everything that absorbs the heat generated by the brakes). Heat causes bearings to wear out, fluid to degrade, grease to fail etc etc. It goes back to why we're putting heat reflective tape on our ball joint boots. You want to keep heat out of things that don't want heat in them or around them and brake ducting goes a LONG way to aid in this.
If you have a pad that can't function with your brake ducting, the answer isn't to reduce the ducting. The answer to buy the correct pad.
PRO86 | WTCC | STL
The Following 8 Users Say Thank You to rice_classic For This Useful Post:
amram (03-20-2014), CSG Mike (09-29-2013), DAEMANO (03-01-2014), glamcem (03-19-2014), Guff (03-19-2014), normancw (03-23-2014), Racecomp Engineering (03-19-2014), Touge Factory (10-04-2013)
Old 09-28-2013, 03:13 PM   #40
bolecailey
Drives: FRS
I was under the impression that with race pads and race fluid (RBF 650, SRF, etc.) that the factory brakes were more than adequate for track days even with faster drivers. Is that not the case?
bolecailey is offline   Reply With Quote
Old 09-29-2013, 03:17 AM   #41
CSG Mike
CSG Mike's Avatar
Adequate? yes. Cost effective? Not at all.
bolecailey (09-30-2013)
Old 09-29-2013, 03:37 AM   #42
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
So would you recommend BBKs up front? If so what brand? Also if BBK is the way to go should I invest in brake cooling ducts too? I was pondering BBKs up front, brake cooling ducts and possibly just pads/rotors for the rear. Would this be a decent set up? I DD and do hpde/advanced driver classes 1-2 times a month.
FRSfan111 is offline   Reply With Quote
A warning about wheel studs post_break Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 05-05-2015 03:07 PM
non-extended wheel studs BadCompany235 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-14-2013 08:02 AM
86 brake calipers Hardrock4445 Cosmetic Modification (Interior/Exterior/Lighting) 19 03-17-2013 09:04 PM
broken wheel studs Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-06-2012 12:47 AM
Small wheel studs PrinzJ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-10-2012 04:47 PM
