Old 09-26-2013, 09:09 AM   #1821
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by thehapaone View Post
So my forgestars should be coming in soon what size tires should I go with to avoid any rubbing
wheels: forgestar f14s 18x9 +36 all around
want a little meatier than stock tires and probably the same all around opened to staggered if people think it will be better
245/35R18 is a perfect size for that wheel (OEM diameter), or 255/35 could fit but probably overkill. Square is better IMO.
What suspension are you on?
Slick is offline   Reply With Quote
Old 09-26-2013, 09:16 AM   #1822
Thongpocket
Master Troll
Thongpocket's Avatar
Drives: 2013 BRZ Limited
Are 17" wheels with 245/40 tires so much larger than stock to cause the speedo to be off? I haven't noticed a difference but I figured someone here knows.
Sent from my XT1080 using Tapatalk 2
Thongpocket is offline   Reply With Quote
Old 09-26-2013, 09:28 AM   #1823
Slick
Slick's Avatar
Pretty much bang on the same diameter. Speedo should be accurate.
The Following User Says Thank You to Slick For This Useful Post:
Thongpocket (09-26-2013)
Old 09-26-2013, 09:37 AM   #1824
Thongpocket
Master Troll
Thanks!
Old 09-26-2013, 12:46 PM   #1825
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
damn I meant to put that in the post I'm running stock struts with Eibach pro kits will I still be good?
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
Old 09-26-2013, 12:53 PM   #1826
Slick
Slick's Avatar
No problem. I'm running pretty much that exact setup. See my sig.
18x9 +35 with Eibach ProKit and camber bolts, 245/35R18 tires. Looks fantastic (IMO).
You'll be fine, and the 245 tire has a slight stretch on that rim, could fit a 255/35 if needed, but its probably too much tire for stock power.
Old 09-26-2013, 01:23 PM   #1827
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Here is a question and I've looked back at least through 20+ pages lol. More directed around front camber, as I know what wheels I am looking at and know they fit. but....
I will be dropping 1 to 1.250 inch max drop.
18 x 9.5" (40) offset is the wheel size, looking at using 255/35/18 MPSS tires.
Does one NEED to run camber in the front to -2 if only dropping that much?
Every example I have seen or that's been discussed with this size the people are running quite low, say 1.5" or greater so I fully understand in needing camber from -2 or greater with slamming the car down to seeing no gap. But given if one was leaning to less extreme drop would say -1.0 be just fine up front and have no rubbing or issues?
Reason I am asking as in the final dilemma, I like the idea of rotating tires at a min front to back depending on tire. But if the car is primarily street and hwy driving the benifit of rotating simply may not be there as to regarding the amount of tire wear on the inner edge at running a big camber up front...
Down to where I have to make order soon because wheels I want will take months to get and I'd like to get my alignment within a useable spec here this weekend when I install my KWs and Vorshlaggs on my car.
Thanks if someone can chime in. Currently I am on a staggered set of Rotas and running -.4 up front and -2.5 in back. Going to bring backs in by using LCAs to around -1.8 ish and fronts are unknown as I'll decide based on what I can gather here...
I know many folks running -2 or greater up front but I think with most of my driving I am abit concerned about dramatic tire wear and how it will handle when its 95%+ street and HWY.
The Following User Says Thank You to OICU812 For This Useful Post:
Dan@AWD (09-27-2013)
Old 09-26-2013, 02:31 PM   #1828
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I'm about to do 17x9 +45 with 245/40. Will try a 3mm spacer in the front and hope for the best. RCE Yellow springs.
Originally Posted by humfrz
I'm old and lazy
Old 09-27-2013, 02:02 AM   #1829
Dan@AWD
Drives: 2013 Argento FR-S
I just ordered some Enkei RPF1 18x9.5 +38. I'm trying to order some tires ASAP. What is the widest I can go up front and in the back without hitting anything on the suspension? I am dropped on Hotchkis Springs, which are about 1" all around. I also have SPC camber bolts if that helps any.
Dan@AWD is offline   Reply With Quote
Old 09-27-2013, 09:37 AM   #1830
juanam0909
Drives: scion fr-s
guys someone is selling me xxr527s 18x8.75 +20 XXR 527
"5x114 And I believe 5x100 for the other"
he trew me off on "5x114 And I believe 5x100 for the other" what does this mean? also my ride is completely stock so what else would i need in order to make them fit.
i plan on droping it soon but i want to get the wheels first.
juanam0909 is offline   Reply With Quote
Old 09-27-2013, 11:43 AM   #1831
Slick
Slick's Avatar
Statement or question?
Should be close, depends on your camber though. Let us know.
Old 09-27-2013, 11:45 AM   #1832
Slick
Slick's Avatar
Fronts 245/35 give or take, maybe 255's
Rears should be okay up to 265 wide
Old 09-27-2013, 11:49 AM   #1833
Slick
Slick's Avatar
He means the wheels are dual-pattern, 5x114.3mm and also 5x100mm pcd. Wheels should have 10 stud holes.
Your fitment will poke out, pretty aggressive. You will need lots of camber to pull it back in.
Not at all an optimum offset for our cars. +30 to +40 for that width is closer to what you need.
Old 09-27-2013, 11:52 AM   #1834
juanam0909
Drives: scion fr-s
thanks for youre help sir, also how much will it poke out if possible do you have any pictures or link to something similar ?
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
