Old 09-27-2013, 12:10 AM   #29
BRZnut
Drives: BRZ DGM Limited
keep us updated
Old 09-27-2013, 03:51 PM   #30
learnerspermit
learnerspermit's Avatar
Drives: C-17A
Update
September 27 2013
Back at the dealer again today. To no surprise same issue this time instead of breaking down in a Kroger parking lot it was while crossing traffic. Got to the dealer and the lead tech supervisor today was very professional and knowledgable he apologized for the mis communication from the service advisor yesterday and is personally handling this process now. He pulled the codes and they were again "fuel" related today... He's keeping the car over the weekend to run diagnostics as well as forwarding this information to Toyota. Hopefully Monday I will get my car back because I have to go out of town for work Tuesday. They also provided me with a nice rental car today.
learnerspermit is offline   Reply With Quote
Old 10-17-2013, 07:44 PM   #31
learnerspermit
Drives: C-17A
Well finally go my car back from the dealer today. They diagnosed the issue to faulty wiring on the direct injection sensor to the harness. So the harness has been replaced and the car is fine now. Basically as the voltage changes due to the loose wire, the direct injection was told to dump fuel immediately followed by a lean code etc read the above for better description. I'm really happy with the service tech and the local dealer how they handled this now and happy to finally have the car.
The Following User Says Thank You to learnerspermit For This Useful Post:
roddy (10-18-2013)
Old 10-18-2013, 08:43 PM   #32
BRZnut
From the look of the picture, the harness came melted from the factory??
Old 10-18-2013, 09:33 PM   #33
roddy
roddy's Avatar
Drives: '13 Ultramarine
It looks like a bad splice (factory) that was making some heat and toasted the insulation on some of the other wires a bit. That could have been a problem...
Thanks for posting the pic. If I ever have a similar issue, I'll know where to look.
Old 10-21-2013, 10:31 PM   #34
jdcorbitt3
jdcorbitt3's Avatar
Drives: 2013 red FR-S, OFT. 2000 Miata SE
The loose ground could have caused a high current flow at that junction, resulting in those compound failures. I would make sure the battery ground is secure, especially as these cars age and batteries get replaced.
John
jdcorbitt3 is offline   Reply With Quote
Old 10-22-2013, 12:40 AM   #35
stugray
Drives: 2013 GBS BRZ Limited
Looks like a bad splice alright, but I'm betting not factory....
Old 10-22-2013, 08:14 AM   #36
roddy
roddy's Avatar
With only 170 miles, and a week of ownership on a leased car, my money's still on a manufacturing defect...
Old 11-06-2013, 10:38 AM   #37
learnerspermit
Drives: C-17A
Unless someone did it on the boat or dealer lot it was born with that defect.
When I went back to a stock manifold on my s2000 from ITB's I had to re wire the injectors and TPS. I'm fairly confident in my abilities to do so. So I have no reason to jerry rig the wires on a high pressure fuel sensor on a stock car.
Old 11-06-2013, 03:51 PM   #38
Razz
Razz's Avatar
Drives: Fast
Now his Cat will go bad from the car dumping all the fuel into it.
Razz is offline   Reply With Quote
Check engine light just came on after 2k miles. danthedirt Issues | Warranty | Recalls / TSB 604 01-31-2015 05:26 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 11:06 PM
Check engine light now on at 2995 miles Marshman Issues | Warranty | Recalls / TSB 2 12-17-2012 08:41 PM
Check engine light? czar07 AUSTRALIA 0 09-01-2012 03:50 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
