#29 |
Slower than Fast
Drives: BRZ Limited 6MT
Will the 32 offset, 17 x 9 in the RPF1 work fine on stock suspension?
#30 |
Thanks
I believe tire rack states it is an aggressive fitment and revommends aftermarket suspension
#31 |
Drives: FRS(sold), AP2, R35, FJC, ED9
It'll poke out. Et35 pokes out in the front a lot if you don't lower it. Et35 is perfect for the rear. So just consider add an extra 3 mm out. There a plenty of threads showing this fitment
#32 |
Drives: 86 Raven
What about +42 ? Im planning to go 17x9+42 I dont know what tire specs will be the best? Im also planning lowering using H&r SUPER SPORTS which is 1.4 front 1.2 ( correct me if im wrong)
#33 | |
Drives: BRZ Limited
http://www.ft86club.com/forums/showthread.php?t=46733 |
| The Following User Says Thank You to fstlane For This Useful Post: | Perry (09-22-2013) |
#34 | |
Drives: 86 Raven
#35 | |
Drives: BRZ Limited
![]() Camber bolts are not required and you will gain some negative camber anyway just by lowering the suspension. Additional camber is usually beneficial to those who track/autocross or slammed cars with wheel offsets too high to fit them under the fenders. In your case you should have no issues with the fit. Last edited by fstlane; 09-22-2013 at 08:10 AM. |
#36 | |
Drives: 86 Raven
#37 | |
Drives: BRZ Limited
#38 |
Yeah this setup will be fine. You can actually use the OEM 14mm upper strut bolt and gain some camber and still clear. I did this but with et45 and a 3mm spacer which nets et42.
#39 |
Drives: BRZ Limited
Were you able to max them out and still clear? I have a set of oem crash bolts I might throw in to add a little bit more negative and fine tune cross camber. With my HTV camber plates maxed out I'm at -1.9L/-2.2R.
#40 |
Yeah I pushed the brake assembly as far in as I could before tightening it down. From the looks of it, the front went from -.5 to -1.5 degrees of camber.
#41 |
Drives: BRZ Limited
#42 |
| Wheel Directory: Enkei Raijin 18x8.5 +45 | SWPBRZ415 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 62 | 11-28-2016 03:51 PM |
| Wheel Directory: OEM Nissan GT-R 20x9.5 +45 | MaDBaRMaN | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 06-01-2014 10:31 AM |
| Wheel Directory: Drag DR-19 17x7.5 +45 | sirhc | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 10-08-2013 02:47 PM |
| Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** | LSD Motorsports | Groupbuys | 246 | 08-29-2013 01:35 PM |
| largest tire for 19x8.5 et45 | garfull | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 04-24-2013 11:44 PM |
