Old 09-17-2013, 01:22 PM   #29
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
Originally Posted by garfull View Post
32 offset you will be fine with that setup. only the 45 offset puts you close to the strut. a lot of people run 35 offset no issues.
Will the 32 offset, 17 x 9 in the RPF1 work fine on stock suspension?
MightyMeeple is offline   Reply With Quote
Old 09-17-2013, 01:26 PM   #30
ZionsWrath
Thanks
ZionsWrath's Avatar
I believe tire rack states it is an aggressive fitment and revommends aftermarket suspension
Old 09-20-2013, 08:23 PM   #31
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
It'll poke out. Et35 pokes out in the front a lot if you don't lower it. Et35 is perfect for the rear. So just consider add an extra 3 mm out. There a plenty of threads showing this fitment
garfull is offline   Reply With Quote
Old 09-22-2013, 06:06 AM   #32
Perry
Drives: 86 Raven
What about +42 ? Im planning to go 17x9+42 I dont know what tire specs will be the best? Im also planning lowering using H&r SUPER SPORTS which is 1.4 front 1.2 ( correct me if im wrong)
Perry is offline   Reply With Quote
Old 09-22-2013, 07:27 AM   #33
fstlane
fstlane's Avatar
Drives: BRZ Limited
A 245/40 tire on a 17x9+42 will fit lowered but does not allow enough front strut clearance for camber bolts. You'll have to either use wheel spacers or camber plates if you want/need more negative camber.
http://www.ft86club.com/forums/showthread.php?t=46733
fstlane is offline   Reply With Quote
The Following User Says Thank You to fstlane For This Useful Post:
Perry (09-22-2013)
Old 09-22-2013, 07:31 AM   #34
Perry
Drives: 86 Raven
You mean i can use 245/40 will have no issues? I just can put cmber bolts if i go with that tire set up? is it really required? i just want to lower my car for looks i dont do autox track my car is my DD
Old 09-22-2013, 07:56 AM   #35
fstlane
fstlane's Avatar
Drives: BRZ Limited
Correct, they won't rub or poke and you'll have this much clearance with the stock front struts.
Camber bolts are not required and you will gain some negative camber anyway just by lowering the suspension. Additional camber is usually beneficial to those who track/autocross or slammed cars with wheel offsets too high to fit them under the fenders. In your case you should have no issues with the fit.
Perry (09-22-2013)
Old 09-22-2013, 02:26 PM   #36
Perry
Drives: 86 Raven
Thanks. Another guy said that the issue here is the wheel size 17x9 +42 i have already the wheels and my lowering springs here but i havnt installed it yet because i dont want the wheel/tires to rub. Because if i will have a problem maybe ill just change my wheels bring it back to the seller. So you have the same set up abd specs sir?
Old 09-22-2013, 03:07 PM   #37
fstlane
fstlane's Avatar
Drives: BRZ Limited
My setup is 17x9+42 Rota Titan wheels, 245/40R17 Direzza ZII tires, RCE yellow springs, stock struts and stock bolts/alignment. I do not rub under any conditions including autocross. The above picture was taking at normal ride height with the above setup.
Perry (09-22-2013)
Old 09-22-2013, 03:12 PM   #38
garfull
garfull's Avatar
Yeah this setup will be fine. You can actually use the OEM 14mm upper strut bolt and gain some camber and still clear. I did this but with et45 and a 3mm spacer which nets et42.
Old 09-22-2013, 03:38 PM   #39
fstlane
fstlane's Avatar
Drives: BRZ Limited
Were you able to max them out and still clear? I have a set of oem crash bolts I might throw in to add a little bit more negative and fine tune cross camber. With my HTV camber plates maxed out I'm at -1.9L/-2.2R.
Old 09-22-2013, 07:06 PM   #40
garfull
garfull's Avatar
Yeah I pushed the brake assembly as far in as I could before tightening it down. From the looks of it, the front went from -.5 to -1.5 degrees of camber.
Old 09-22-2013, 08:13 PM   #41
fstlane
fstlane's Avatar
Drives: BRZ Limited
Thanks for the info. I'll have to install them and play around with settings a little.
Old 09-23-2013, 09:08 PM   #42
garfull
garfull's Avatar
Got my alignment done and it actually landed at -1.1 on both a sides. Sometimes it jumped to -1.2.
Thanks for the info. I'll have to install them and play around with wsettings a little.
Wheel Directory: Enkei Raijin 18x8.5 +45 SWPBRZ415 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 62 11-28-2016 03:51 PM
Wheel Directory: OEM Nissan GT-R 20x9.5 +45 MaDBaRMaN Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 06-01-2014 10:31 AM
Wheel Directory: Drag DR-19 17x7.5 +45 sirhc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-08-2013 02:47 PM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
largest tire for 19x8.5 et45 garfull Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-24-2013 11:44 PM
