Old 09-22-2013, 09:28 AM   #15
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Bacardi and coke. Do it. Do it.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Tansey86 For This Useful Post:
solidONE (09-22-2013), Squishy86 (09-23-2013)
Old 09-22-2013, 10:31 AM   #16
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
i did a front pipe a while ago, didn't feel any difference.
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
The Following 2 Users Say Thank You to Grip Ronin For This Useful Post:
BC-Boy (05-26-2014), Paewrblue (03-19-2016)
Old 09-22-2013, 11:06 AM   #17
stugray
Drives: 2013 GBS BRZ Limited
I would assume that swapping from the catted stock front pipe to a non-cat front pipe means that you would fail future emissions tests?
Or is the engine clean enough that you would still pass?
Old 09-22-2013, 11:24 AM   #18
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
im running stock exhaust with just front pipe(no cat) and theres def a difference. there is a little rasp and i passed emissions on my car without the cat. I believe this car has two cats and if you delete one theres no issues. the cat in the header i believe will cause issues because thats where the two o2 sensors are at.
brichard0625 is offline   Reply With Quote
Old 09-22-2013, 11:33 AM   #19
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
For those of you running cat-less front pipes, are u getting much exhaust smell?
Fizz is offline   Reply With Quote
Old 09-22-2013, 11:38 AM   #20
brichard0625
im getting a little i wont lie..but only when im really revving on the engine...on a normal drive i smell nothing
Old 09-22-2013, 11:48 AM   #21
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Originally Posted by solidONE View Post
I just installed a front pipe on my FR-S earlier and came back from a drive. All I can say is, if you don't already have one, do it.
The amount of partial throttle power and response I gained was ridiculous. I had installed a aFe R5 filter previously and my butt dyno was like "meh I think I got a bit more power..." After the front pipe it was like "dayum!" It was that noticeable, the increase in power and response. I'm quite positive if I granny/feather the throttle for MPG, I'd get quite a bit more over the factory front pipe.
Only mods I have that would affect the engine output is the aFe r5 drop in, and the up pipe. This leads me to believe that the stock fuel map is ridiculous rich for these 2 mods to make this much of a difference.
You are correct, the stock fuel mapping is rich -- quite rich for an N/A car. I'm sure you are feeling the difference -- that is a big restriction you removed from the exhaust, increasing flow.
Add a header and tune and you will have no more torque dip at all, and very nice power and torque gains across the board.
-- Bob
Circuit Motorsports is offline   Reply With Quote
The Following User Says Thank You to Circuit Motorsports For This Useful Post:
ravenblackfrs (09-23-2013)
Old 09-22-2013, 04:26 PM   #22
wparsons
wparsons's Avatar
What do you think of sound on the following (in terms of quietness/loudness):
AVO turbo header, 2.5" overpipe, front pipe, midpipe, and stock muffler?
If I don't go innovate this is my plan for exhaust setup.
I'm looking for OEM sound level or less with the best performance gains.
A turbo will greatly quiet down any exhaust, as well as kill a bunch of rasp so you'll probably be EXTREMELY quiet with the stock muffler and a turbo.
flickr
wheelhaus (09-25-2013)
Old 09-22-2013, 07:54 PM   #23
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Typically when you open up the exhaust on a otherwise stock car you'd expect the to gain in the top end and maybe even lose some at the low end and with partial throttle. The willingness of the car to pull forward with only slight throttle after installing the front pipe really caught me by surprise. I'm sure when you go WOT the difference may or may not be as noticeable, but the difference when just putting around is really that big IMO.
Intent > Content
Old 09-22-2013, 07:59 PM   #24
solidONE
solidONE's Avatar
Originally Posted by whitefrs View Post
just got my j2 front pipe.... will be installing today
Let us know your impressions after the install. I'm sure you will be pleasantly surprised as I was.
Intent > Content
Old 09-22-2013, 08:01 PM   #25
solidONE
solidONE's Avatar
Did you have the header in before you did the front pipe?
Intent > Content
Old 09-22-2013, 08:05 PM   #26
pmccut
Drives: Blue Subarus
Is your car working yet??
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 09-22-2013, 08:13 PM   #27
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Car is running perfect on e85
Sent from my iPhone using Tapatalk - now Free
Old 09-22-2013, 08:48 PM   #28
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
So which front pipe did u get btw? Catted or catless?
Installed Over pipe,no more low end torque? Sniper2606 Engine, Exhaust, Transmission 40 10-16-2017 03:53 PM
What is the difference between a Front pipe, a down pipe and an over pipe? liajet24 Engine, Exhaust, Transmission 5 09-19-2013 10:03 PM
Nameless Performance Track Pipe Installed MTeator Engine, Exhaust, Transmission 46 09-15-2013 08:57 PM
Tint, lights and backup cam installed, and camber kit installed in Gainesville area? husker741 Southeast 2 08-16-2013 03:59 PM
