Old 09-21-2013, 12:27 PM   #15
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Originally Posted by NomoreNA View Post
Boost. 28psi on a fmw 80mm but we have been testing a new fmw68.5 at 40psi.
Can we atleast hear the cams
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 09-21-2013, 01:02 PM   #16
NomoreNA
NomoreNA's Avatar
Drives: Raven FRS
The day after sema
NomoreNA is offline   Reply With Quote
Old 09-21-2013, 01:09 PM   #17
Fabron757
Drives: 2013 blue frs m6 BW EFR 7064 Turbo
The efr 7064 is to crazy. First time using a BW efr turbo. they are alot of fun and the sound they make is super nice. My tranny is fine. I use the FX400 clutch feels like stock just grabs alot better so easy to stall but you get use to it. If you want to see pics and hear what it sound like click in my build link below.
http://www.ft86club.com/forums/showthread.php?t=31807
Fabron757 is offline   Reply With Quote
Old 09-21-2013, 01:11 PM   #18
ft_sjo
Drives: GT86
What fuel?
Old 09-21-2013, 01:12 PM   #19
Dipstik-sportech
Dipstik-sportech's Avatar
Who has a built motor?
Your fx400 feels like stock!!?? Mine is Waaaay stiffer than stock.
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
ftc~brz (09-24-2013)
Old 09-21-2013, 01:12 PM   #20
Tansey86
Tansey86's Avatar
The day after sema
Is billet the company or the material? Will it be a production cam for everyone to buy?
Old 09-21-2013, 01:12 PM   #21
Fabron757
Motor was built by me and my bro parts include: custom sleeves, Race prep/nitride coated crank, pauter rods +625 rod bolts, msm custom pistons 2618 ceramic tops/pc9 skirts 12:1 CR, tool steel .25" wrist pins, L19 case studs, L19 head studs, Copper head gaskets, custom valve seats, +2mm valves "inc exhaust ti intake", ti retainers & keepers, dual valve springs, billet cams "not going to give out cam profile" adv duration 268 lift 14mm and a custom damper to keep it balanced. Thats all I can think of off the top of my head
Does your turbo make power past 8k rpms? And is that a custom grind?
Old 09-21-2013, 02:17 PM   #22
NomoreNA
NomoreNA's Avatar
Drives: Raven FRS
Originally Posted by ft_sjo View Post
What fuel?
E98
Material. No plans at this time for mass production.
Yes it is a custom grind and the car makes power at 9k. We havnt pushed big boost on the 80 but I could see it holding power at 10k.
Old 09-21-2013, 03:02 PM   #23
MooKz
MooKz's Avatar
Drives: 2013 Scion FR-S Firestorm Red
Just Wow
......SUBRSCRIBED
MooKz is offline   Reply With Quote
Old 09-21-2013, 03:19 PM   #24
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Power Goals?
Old 09-21-2013, 03:55 PM   #25
NomoreNA
NomoreNA's Avatar
Drives: Raven FRS
Power Goals?
I dont really have a power goal we will just keep making suspension changes and adding boost until it cant hold then back it down a bit. I would suspect final numbers in the 1100 range "keep in mind thats through a th400"
The Following User Says Thank You to NomoreNA For This Useful Post:
Sportsguy83 (09-21-2013)
Old 09-21-2013, 03:58 PM   #26
Opposed
Drives: 2013 Asphalt FR-S
No sh#*t. Your clutch is the furthest thing from stock I have ever felt lol.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 09-21-2013, 03:59 PM   #27
Tansey86
Tansey86's Avatar
What are you gonna do in terms of tire? lmao
Old 09-21-2013, 04:00 PM   #28
lexusb3
Drives: FRS
My build day is comming up soon lol
lexusb3 is offline   Reply With Quote
Frs300 Fa20club built motor and turbo build Frs300 Member's Car Journals 32 01-18-2014 05:27 AM
Crawford Limited Turbo BRZ - built motor Mrqb22 Forced Induction 8 11-11-2013 01:34 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 06:26 AM
When was you 86 built and what no. is it? Vic_RSA AFRICA 22 04-16-2013 02:58 PM
Where is each AS1 car built? Fox Scion FR-S / Toyota 86 GT86 General Forum 18 01-08-2012 04:33 PM
