Old 09-20-2013, 10:48 PM   #1807
Perry
Drives: 86 Raven
What if i go 235 / 40 / 17 ? WIll it still have issue on rubbing? Sorry im noob lol
Perry is offline   Reply With Quote
Old 09-21-2013, 06:18 AM   #1808
lavisxice
lavisxice's Avatar
Drives: WRB BRZ
is 225/40/18 on 18x7.5 a good fit?
2013 WRB Subaru BRZ Sport-Tech
-TRD intake
-Perrin 2.5 inch cat-back exhaust
lavisxice is offline   Reply With Quote
Old 09-21-2013, 11:36 AM   #1809
BadLuckZN6
BadLuckZN6's Avatar
Drives: GT86
will SSR SP1's fit 18x9.5 +5 and 18x8 +0. I don't mind a slight roll but is the offset too extreme?
BadLuckZN6 is offline   Reply With Quote
Old 09-21-2013, 12:17 PM   #1810
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
It has more of an issue with the wheel offset, at +42 it pushes the whole wheel/tire right against the strut. You may need to run a spacer to get adequate clearance to clear the spring perch. But the narrower tire may help as the tire is closest component to the strut.
Read the above thread in its entirety if you are planning to run this combo.
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
Perry (09-22-2013)
Old 09-21-2013, 12:19 PM   #1811
Slick
Slick's Avatar
Yes, great tire size for that wheel.
lavisxice (09-21-2013)
Old 09-21-2013, 12:25 PM   #1812
Slick
Slick's Avatar
I'm gonna guess the 18x8 are the fronts and 18x9.5 rears?
These offsets are pretty extreme, probably suited well for a Rocket Bunny kit.
Most guys (stock body) running really aggressive setups are in the +20 to +25 range but they also run aggressive camber to make it work.
Have a look at this thread to see but I don't see that offset at all working on a stock body:
http://www.ft86club.com/forums/showthread.php?t=25171
Old 09-22-2013, 12:31 AM   #1813
Perry
Drives: 86 Raven
sir do you think 225/40/17 would fit? i mean will it rub on the spring perch? i know its a little bit stretched but im more concern on rubbing. thanks
Old 09-22-2013, 07:54 AM   #1814
jshadeck
jshadeck's Avatar
17x9 +42 is the issue, not the tire size i think. If the wheel/tire will rub the suspension, and u stretch a smaller tire, the rim will still rub.
jshadeck is offline   Reply With Quote
Old 09-24-2013, 08:07 PM   #1815
RedBRZ80
Drives: 2013 Red BRZ
Ok so 17x8 with 235/40 tires.
Offset either 35 or 45??
Any thoughts either way?
RedBRZ80 is offline   Reply With Quote
Old 09-24-2013, 09:03 PM   #1816
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Whichever you want. Both are a non-issue.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 09-25-2013, 05:33 PM   #1817
RedBRZ80
I'm aware of the figment non issue, was just trying to get some feedback on looks either way. I'm leaning toward the 45 cause that would only push out the rim 16mm.
Old 09-25-2013, 05:41 PM   #1818
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
So my forgestars should be coming in soon what size tires should I go with to avoid any rubbing
wheels: forgestar f14s 18x9 +36 all around
want a little meatier than stock tires and probably the same all around opened to staggered if people think it will be better
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
Old 09-25-2013, 06:18 PM   #1819
2point0
2point0's Avatar
Correct, the +45 will look fairly stock-ish since this car has so much room in the wheel wells. If you like a little more of a wide stance, I think +35 would look good.
Right now, I'm on 17x8 +48 with spacers, so effectively my offsets are +22 F and +23 R. The front pokes a tad more than I'd like but the rear is perfect to me.
I don't have an "after" pic handy, but here's what it looked like without spacers (so only 3mm in from yours).
Old 09-25-2013, 09:18 PM   #1820
RedBRZ80
Perfect. I'm good to go. I'll post pics when they get on.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
