Old 09-19-2013, 11:17 AM   #43
infinite012
Drives: 13 DGM BRZ Ltd
omg no. stop.
The compressor will spin to infinity rpm if you have no wastegate, melting your turbo.
The intake air will get jammed into the intake pipe if you have no BOV, blowing your intake pipe off the engine.
In both cases, you still get an F for this class.
infinite012 is offline   Reply With Quote
The Following User Says Thank You to infinite012 For This Useful Post:
shiro (09-19-2013)
Old 09-19-2013, 11:18 AM   #44
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by shiro View Post
Furthermore, understanding that the waste gate regulates boost (PSI) level, why do I get a fudder noise when I let off on the gas at a high RPM with no BOV installed? I'm guessing that is because the waste gate is dumping the extra gasses not needed to produce the boost. Hence, would it still dump with a BOV installed?
You get a fudder noise because you have no BOV or way for the compressed air in your piping to escape once you slam the throttle closed so it heads back to your turbo. The wastegate starts opening as soon as you hit your target PSI and then opens/closes as needed to maintain your desiered boost level and then as soon as you let off the throttle and boost drops, it slams closed. Think of the BOV and wastegate as being opposites. Wastegate opens and BOV closes when it sees boost. BOV opens and wastegate closes when it no longer sees boost.
shiro (09-19-2013)
Old 09-19-2013, 11:21 AM   #45
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
Originally Posted by infinite012 View Post
omg no. stop.
Lol, no F+?
shiro is offline   Reply With Quote
The Following User Says Thank You to shiro For This Useful Post:
Sportsguy83 (09-19-2013)
Old 09-19-2013, 11:23 AM   #46
shiro
shiro's Avatar
Right on; sounds like the push-pull method in martial arts. Love it!
Old 09-19-2013, 01:07 PM   #47
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
A few FRSs and BRZs is running the greddy turbo kit without a BOV. Ken Gushi's Firestorm red FRS doesn't have a BOV, Greddy's raven black FRS track car doesn't have a BOV, Mackin's FRS doesn't have a BOV, and notorious BRZ's doesn't have a BOV. When I called the Greddy tech about the kit I asked them why are they not using a BOV, they said the kit doesn't really need it. I got a BOV anyway.
Cessblood is offline   Reply With Quote
The Following 2 Users Say Thank You to Cessblood For This Useful Post:
shiro (09-19-2013), Sportsguy83 (09-19-2013)
Old 09-19-2013, 01:39 PM   #48
shiro
shiro's Avatar
I think this thread might help those that want to get the Greddy Turbo Kit have a better understanding of it's design. Greddy USA said the same thing to me. I just really like the sound
Cessblood (09-19-2013)
Old 09-19-2013, 02:55 PM   #49
STV3
Seńor Member
STV3's Avatar
Its always better to have a bov to reduce the stress on turbo. When the air bounces off the closed throttle body you have the air going back through the turbo trying to spin it the other way while the exhaust is still spinning forward.
STV3 is offline   Reply With Quote
The Following User Says Thank You to STV3 For This Useful Post:
shiro (09-19-2013)
Old 09-19-2013, 10:03 PM   #50
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
I'll give you guys the tech on BOVs. First off I bet the race team doesn't use the BOV because it doesn't work well. I've probably tuned with every BOV made and you would think its impossible for them to leak but some do and the best do not.
A BOV actually works off of pressure differential between the top chamber and the bottom of the valve (part connected to the charge pipe). This is why a BOV can vent at partial throttle and it's part of the reason why a drifter or racer my not like how the BOVs reacts to throttle inputs. If you bov has a light spring pressure differential is reached easily causing the bov to dump and therefore the driver must continue to dip into the throttle more and more to maintain speed. I can't stand that so I run a BOV that not only has a very stiff spring (requires high pressure differential) but also bas preload adjustmentt to fine tune it. This way when I apply 50% throttle boost increases and I get a steady rate of acceleration and my BOV only dumps when I slam the throttle shut.
Ok nerd button off
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
The Following User Says Thank You to Element Tuning For This Useful Post:
shiro (09-20-2013)
Old 09-20-2013, 10:21 AM   #51
shiro
shiro's Avatar
Ok nerd button off
Thanks,
Phil Grabow
Lol, the stiffer the better...what she said :P
Thanks for the input!
Old 09-23-2013, 01:16 AM   #52
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Videos please @shiro !
Build Thread
Instagram
Old 09-23-2013, 01:42 PM   #53
shiro
shiro's Avatar
Sure, I'll see what I can do after work on uploading a video here / youtube
midnight23 (09-23-2013)
Old 09-26-2013, 10:08 AM   #54
shiro
shiro's Avatar
Took some time to get back to you all; it's been a really busy week. For right now I have my Dyno chart to post up. Let me know what you think. She feels like a rocket when the 1000cc IDs kick in at 5K RPM
Name:  300hp myles.jpg
The Following 2 Users Say Thank You to shiro For This Useful Post:
Cessblood (09-26-2013), ImperiousRex (09-26-2013)
Old 09-26-2013, 10:20 AM   #55
ft_sjo
Drives: GT86
There's some awesome factoids in this thread (I recommend looking up what a factoid is).
I'll add some of my own..
- Lots of cars came from the factory without re-circulation valves
- They don't tend to do that these days due to the MAF base configurations
- Modern turbochargers like the GT range with delicate ball-bearing cores are spec'd to be used with a re-cir valve. The shafts are thinner than the old T-series, for example, and are prone to breaking without suitable measures in place.
- You do not necessarily need a wastegate to control boost. Lots of engines effectively run without wastegates when the engine and turbocharger are specified correctly.
Yours Unicorningly,
Unicorn.
Old 09-26-2013, 12:03 PM   #56
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Attachment 52262
Very interesting. That small turbo didn't spool as quickly as I thought it would, but that 14 psi hit gave you a real nice torque peak, unfortunately it starts tailing off immediately and you drop to 10 psi by redline. Still I am very impressed with the kit and I bet it does feel amazing at 5000 RPM.
shiro (09-27-2013)
bov, fabrication, greddy turbo kit
Greddy turbo MikesFRS Forced Induction 104 11-24-2014 11:47 PM
Greddy Turbo! Threads Forced Induction 16 08-29-2013 05:11 PM
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 11:50 AM
Greddy turbo brocktwalker Forced Induction 3 04-03-2013 09:03 PM
GReddy in on-deck circle. GReddy turbo for FR-S/BRZ first up. 2JZ-DNA Engine, Exhaust, Transmission 46 04-19-2012 08:13 PM
