Old 09-17-2013, 10:10 AM   #15
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Shouldn't you be able to just use the lines for the interwarmer/tb anti-freeze lines for easy hook up?
industrial is offline   Reply With Quote
Old 09-17-2013, 10:39 AM   #16
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Kostamojen View Post
The ECU doesn't read oil temps right?
It does.
Old 09-17-2013, 11:06 AM   #17
Kostamojen
If this really is the same as the earlier EJ oil coolers, then finding one at a junkyard for a few bucks is a possibility. I would rather go new myself with my BRZ, but in a few years this is easily a possibility for used FRS/BRZ's.
Pretty much. Its not a complicated install at all. Just need to feed cool temp coolant into the lines.
Originally Posted by xjohnx View Post
It does.
Then it should be pretty easy for someone to test whether or not this improves oil temps and what effect it has on coolant temps as well with the Torque app and a bluetooth OBDII adapter.
Old 09-17-2013, 07:22 PM   #18
JiB
JiB's Avatar
Drives: GT86
@jet86
JiB is offline   Reply With Quote
The Following User Says Thank You to JiB For This Useful Post:
alexm86 (09-19-2013)
Old 09-17-2013, 08:09 PM   #19
lazyluka
Drives: GT86
I ordered the Cusco Oil Cooler kit, should arrive in the next few weeks, will install and post review + results.
FYI I ordered the revised version. According to their site it also reduces engine coolant temps (WTF??)
http://www.cusco.co.jp/products/etc-parts/86brz_mt.html
lazyluka is offline   Reply With Quote
The Following 2 Users Say Thank You to lazyluka For This Useful Post:
CxG (04-25-2016), hmong337 (01-17-2015)
Old 09-17-2013, 08:29 PM   #20
xwd
I would be interesting in seeing the results. Cusco also bills this as an oil warmer as well, to bring the oil temp up faster along with the coolant temp.
The graph shows it lowering the peak oil temp from 259 degrees to 239 degrees which whille not an immense amount may be the margin of safety needed. The tests seem to have been done with the Sprintex supercharger installed. Anyone read Japanese?
Old 09-17-2013, 09:51 PM   #21
Kostamojen
I think its more of a temperature "regulator" rather than cooler/heater. Heats up the oil quickly, but also keeps it cooler than boiling hot.
Win-win proposition?
I'm going to try to get a parts diagram for the Forester DIT to see exactly where the coolant feed lines are coming from.
The Following User Says Thank You to Kostamojen For This Useful Post:
Dimman (09-22-2013)
Old 09-17-2013, 10:37 PM   #22
FT_Monk
Drives: Over the hill WRX
This cooler works on the WRX, STI and the Forester turbo. Why wouldn't it works on the BRZ? The heats in the coolant helps the oil gets to temp faster, reduces engine wear and keep oil close to operating temp. Unless you are running some serious boosted application, or have money to spare on after market solution that sprung leaks and alter oil pressures then this is not for you.
FT_Monk is offline   Reply With Quote
Old 09-18-2013, 02:51 AM   #23
Kostamojen
I'm seriously going to make it a mission to get one of these oil coolers tomorrow from the junkyard...
I bet I can put it all together for under $50.
The Following 2 Users Say Thank You to Kostamojen For This Useful Post:
ATSAaron (09-18-2013), industrial (09-18-2013)
Old 09-18-2013, 09:25 PM   #24
Kostamojen
Didn't find any at the Junkyard or Recyclers today...
However, I did do some research on the parts diagrams and such for the DIT engine and got the part number for the Oil Cooler:
Part Number 21311AA170 - List Price $180, www.subaruparts.com has it for $143
Thats $100 LESS than the other turbo oil coolers NEW! And it includes the "spill tray" on top!
StormTrooper (03-23-2014)
Old 09-18-2013, 10:14 PM   #25
ATSAaron
Drives: 2013 Raven FR-S
Don't forget the extended bolt.
Aaron
ATSAaron is offline   Reply With Quote
Old 09-18-2013, 10:18 PM   #26
Kostamojen
Aaron
Figured that was a given... Its the same extended bolt I believe as before.
Old 09-18-2013, 10:19 PM   #27
Kostamojen
Anyway, some diagrams...
DIT coolant diagrams:
BRZ Coolant Diagrams:
This is what I'm thinking:
The Following 5 Users Say Thank You to Kostamojen For This Useful Post:
ft_sjo (09-19-2013), illmatic (09-19-2013), jonnyozero3 (03-11-2014), Mikem53 (09-21-2013), RallySport Direct (09-19-2013)
Old 09-18-2013, 10:34 PM   #28
Kostamojen
Couple photos showing how the DIT routes the coolant:
Under the engine where the hot side connects back to the heater core piping:
ft_sjo (09-19-2013), RallySport Direct (09-19-2013)
BRZ wheels on Forester XT sea otter 99 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2017 06:56 PM
Wheel Directory: OEM Subaru Forester STi (2005) 18x7.5 +48 Surok Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-24-2015 07:42 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
OEM Forester All Weather floormats Laika Cosmetic Modification (Interior/Exterior/Lighting) 2 01-14-2013 09:19 PM
1998 Forester on BRZ/FRS Rims :) Meeners BRZ Photos, Videos, Wallpapers, Gallery Forum 11 11-23-2012 08:45 PM
