Old 09-07-2013, 12:13 AM   #71
Rabble
Drives: Asphalt FR-S
They replaced my transmission under warranty. No questions asked.
Sideways is a normal operating condition.
Rabble is offline   Reply With Quote
Old 09-07-2013, 12:29 PM   #72
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Same here. My issue started out as a 6th gear grind that came out of nowhere after 3000rpm. Then I started noticing 4th gear grinding at high RPM. Central Fl. Toyota replaced it for me after the 2nd complaint. They said they had to call it in and wait for an answer to replace the tranny. Hope this doesn't turn out to be an issue that never gets resolved like the 3rd gear grinds in the Civic Si.
D-VO is offline   Reply With Quote
Old 09-07-2013, 01:17 PM   #73
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
What dealer? If they replaced yours for you I wanna go to the same dealer if its anywhere near me.
husker741 is offline   Reply With Quote
Old 09-07-2013, 01:23 PM   #74
husker741
What state are you in? Gatorland here in Gainesville are incredibly incompetent.
Old 09-07-2013, 03:28 PM   #75
HI
HI's Avatar
Drives: 2013 FR-S Ultramarine
Mine only grinds 5th. Phew I thought it was only my car that did it. I'll be taking it in soon then.
HI is offline   Reply With Quote
Old 09-08-2013, 09:07 PM   #76
Kostamojen
I replaced my fluid yesterday, my chunky shifts/slight grinding is gone.
Old 09-09-2013, 02:37 PM   #77
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
They're going to flush my transmission today at Hanson Suabru in Olympia and look for "debris." Sooner or later I'm sure it'll be replaced.
DoomsdayJesus is offline   Reply With Quote
Old 09-13-2013, 04:14 PM   #78
DoomsdayJesus
I just talked to the dealer, when they flush my transmission they found metal debris. They're going to ship it to Subaru for inspection, and they're currently replacing my transmission. The bummer is that they're being held up by a $5 part that they didn't know they needed and had to order from Florida.
Sent from my SCH-I545 using Tapatalk 4
Old 09-16-2013, 05:50 PM   #79
DoomsdayJesus
If you still have the fluid, get it analyzed. Not to beat a dead horse, but I just saw your post and they found metal debris in mine.
Old 09-16-2013, 08:39 PM   #80
tahoward
tahoward's Avatar
Drives: Firestorm FR-S
Just brought mine in for the 7500 mile service and reported 3rd to 4th grind. They knew right away what I was talking about. Apparently a few others reported the problem to the same dealer. Was advised that Toyota is still researching for cause/solution.
tahoward is offline   Reply With Quote
Old 09-17-2013, 04:07 PM   #81
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
seems like many people have issues with transmission.
what was build date who had problems with transmission?
Old 09-17-2013, 05:01 PM   #82
jarviz
jarviz's Avatar
Drives: Raven FRS MT
I've heard people that have gotten transmission fluid changes see improvements. I have about 23K miles on my car and changing gears is smooth as butter 99% of the time. Every once in a while it'll grind but then I can't tell if it's because I left off the clutch too early or if I didn't put it in gear all the way.
jarviz is offline   Reply With Quote
Old 09-17-2013, 05:14 PM   #83
Dezoris
Dezoris's Avatar
No one ever answered my question on this. Do you guys with issues skip gears? Or have you in the past?
Like going from 3rd to 5th on an upshift etc?
Old 09-17-2013, 07:18 PM   #84
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
I personally never skipped gears before or after my 4th gear issues with my previous transmission. Even after the issue showed up I still went to 4th, just gingerly. Strangely, with my new transmission I've been skipping gears quite often, just to see if I can improve my MPG.
Superfast Jellyfish
overlookedx is offline   Reply With Quote
6th gear grinding D-VO Issues | Warranty | Recalls / TSB 59 04-07-2015 02:26 PM
6th Gear Grinding KpAtch3s Issues | Warranty | Recalls / TSB 0 06-18-2013 08:07 PM
Spacers grinding...? Yamajee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-09-2013 03:54 AM
steering grinding kendalldwhite Issues | Warranty | Recalls / TSB 2 05-02-2013 09:38 AM
How did you hear about your FRS? bdanisi Scion FR-S / Toyota 86 GT86 General Forum 26 01-21-2013 01:14 AM
