Old 09-17-2013, 11:32 AM   #15
Synack
Boosted
Synack's Avatar
Drives: Sideways
Well, I hope you get it fixed up soon.
Back in the day, it wasn't uncommon for a throw out bearing to go bad, especially if the driver rode the clutch or the clutch was badly out of adjustment. Not so much anymore.
Keep us posted on what you find.
I mean I hate to threadjack but I want to list the symptoms here, as I've never had a transmission act like this.
It's normally hard to shift into 1st and reverse. The other gears seem easier to shift into, when the car is in motion.
All of the gears including 1st are easier to shift into when moving, I can just push pressure slowly on the gear until it slides into place. But it's far from smooth. At a dead stop, it's normally damn near impossible to shift into any gear.
Most of the time the clutch will stick going from 3rd into 4th, making 4th grind almost everytime. Yes the clutch gets stuck sometimes, and takes a few seconds to return to fully depressed.
It's much easier to shift at middle range RPM's as opposed to dead stop idle, and high RPM's at or near redline.
Basically the transmission is just acting like the clutch is only getting pressed like 80%, just barely allowing for shifting. Often with the clutch fully pressed down, it will still act like it is partially engaged and the car will move forward.
Now, if this sounds like anything any of you have heard before, please let me know so I can relay the info to the techs.
Sorry OP if this is a threadjack, we just have the same issue going on with the noisy throwout bearing. And your noisy bearing might eventually lead to my current issues.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 09-17-2013, 12:12 PM   #16
^......well, I have a simple solution to most all problems ..... and they are usually wrong .....
(sort of like someone said once ..??)
Maybe if you bleed the clutch system, all will be OK .... ??
Old 09-17-2013, 01:26 PM   #17
Synack
Boosted
Synack's Avatar
Drives: Sideways
Hmmmm I thought about it. I'll see if someone can look at it this Friday, not just someone trying to make money and replace an entire transmission.
Old 12-02-2013, 10:15 AM   #18
Halcyon Whisper
Drives: GTS86 Man - Pegasus White (soon)
May interest you lot in a Toyota tech's observation on the throwout bearing
http://www.ft86club.com/forums/showt...=1#post1363860
Halcyon Whisper is offline   Reply With Quote
Strange noise/vibration under heavy engine load Panecki17 Issues | Warranty | Recalls / TSB 65 05-04-2017 07:58 AM
Clutch noise new to-day Skye Issues | Warranty | Recalls / TSB 16 11-19-2016 11:42 AM
Vibration/Noise near instrument cluster? nktech Scion FR-S / Toyota 86 GT86 General Forum 11 03-28-2014 08:42 AM
Clutch Pedal Noise Help!! ZackZ Scion FR-S / Toyota 86 GT86 General Forum 6 09-06-2013 05:35 PM
Winding Noise From Clutch Bach415 Northern California 0 06-24-2013 07:19 PM
