#1009 |
#1010 |
Drives: 2013 Scion FR-S 10 Series
#1011 |
Drives: FRS 10 Series #243
New 10 owner here #0243
Tearin' up these streets in Atlanta, GA |
#1012 |
#1013 |
#1014 | |
Drives: Da-Big Banana
Get your dealer to replace the passenger's side dash trim as your's is coming off like mine which is being replaced this week. ![]() Look at the panel next to the radio trim panel see how doesn't set flush with the radio trim panel.
#1015 |
Drives: frs
#1016 | |
Hey buddy you've got #1964: jthornton1993, Vandenberg AFB, California in the wrong place. ![]() He's listed after #1401: kf417, Los Angeles, California.
#1017 |
Drives: RV-7
#1018 |
Drives: 10 Series FRS #1525
Quick question. This is my first manual car, so I am still learning the in's and out's of driving. I'm up to about 1300 miles and about 6 weeks of driving experience. Should the car ever be able to go from gear to neutral without the clutch pedal being pressed first? My hand slipped and it fell from 2nd to neutral, and I was really confused. It happened once more after that, but I'm not going out of my way too do it over and over again, I don't want to damage anything.
#1019 | |
Drives: RV-7
The one time you don't want the gear to disengage is when using cruise control. Should the trans jump out of gear into neutral the car will slow so the cruise control computer will call for more and more throttle to maintain set speed unless you disengage cruise with one of the several methods available (brake, clutch, button, lever and maybe e-brake). |
#1020 | |
Hail Magnet
#1021 |
Drives: RV-7
I thought I tested this back in early July and the engine started revving when forced out of gear without the clutch but am no longer 100% sure. Maybe I'm thinking of one of the other Toyota M/T's in use. I won't be driving my FR-S today, can you could test and confirm?
#1022 | |
Hail Magnet
| 86 Owners of New England - Registry | MannyO | New England | 247 | 10-27-2025 03:45 PM |
| **Tennessee Registry** | Xryn | Southeast | 139 | 11-02-2022 12:31 PM |
| Mid-Atlantic Owners Registry. | IloveBaldEagles | Mid-Atlantic | 366 | 10-24-2022 08:55 PM |
| Issue updating Registry. | IloveBaldEagles | Site Announcements / Questions / Issues | 1 | 03-18-2013 07:19 PM |
| First 86 Registry: 2013 Scion FR-S | Flipside909 | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 05-18-2012 05:54 PM |
