Old 09-16-2013, 09:53 PM   #1009
mush
mush's Avatar
Originally Posted by Raiin View Post
I have PSX24W / 9009 noted...
u have the ones from toyota?
mine is the kit from toyota
Old 09-16-2013, 10:09 PM   #1010
Raiin
Raiin's Avatar
Drives: 2013 Scion FR-S 10 Series
whoops! yeah, not sure where I grabbed those numbers from.
H11 sounds right to me!
Raiin is offline   Reply With Quote
Old 09-16-2013, 10:11 PM   #1011
Av8tor
Drives: FRS 10 Series #243
New 10 owner here #0243
Tearin' up these streets in Atlanta, GA
Av8tor is offline   Reply With Quote
Old 09-16-2013, 10:21 PM   #1012
mush
mush's Avatar
maybe from BRZ fogs
Old 09-16-2013, 10:23 PM   #1013
Raiin
Raiin's Avatar
maybe from BRZ fogs
Yeah, no clue...
Old 09-16-2013, 11:38 PM   #1014
TRD-X
TRD-X's Avatar
Drives: Da-Big Banana
Originally Posted by Hanni_0176 View Post
Hello everyone. I've been lurking the forums for a while and decided it was time to register and make a post.
#176, MT
Get your dealer to replace the passenger's side dash trim as your's is coming off like mine which is being replaced this week.
Look at the panel next to the radio trim panel see how doesn't set flush with the radio trim panel.
Old 09-17-2013, 12:09 AM   #1015
twag4
Drives: frs
pics of the badge or it didnt happen
#535, Manual Transmission
Name:  sc10n badge.jpg
twag4 is offline   Reply With Quote
Old 09-17-2013, 08:07 AM   #1016
TRD-X
TRD-X's Avatar
Originally Posted by torqdork View Post
Today's the day! Please post pics including your badge number.
Congrats to all of the patiently waiting 10 Series owners!
Hey buddy you've got #1964: jthornton1993, Vandenberg AFB, California in the wrong place.
He's listed after #1401: kf417, Los Angeles, California.
Old 09-17-2013, 09:59 AM   #1017
torqdork
torqdork's Avatar
Drives: RV-7
??? Don't know how that happens every now and then, but fixed it.
torqdork is offline   Reply With Quote
Old 09-17-2013, 10:31 AM   #1018
TRD4life
Drives: 10 Series FRS #1525
Quick question. This is my first manual car, so I am still learning the in's and out's of driving. I'm up to about 1300 miles and about 6 weeks of driving experience. Should the car ever be able to go from gear to neutral without the clutch pedal being pressed first? My hand slipped and it fell from 2nd to neutral, and I was really confused. It happened once more after that, but I'm not going out of my way too do it over and over again, I don't want to damage anything.
TRD4life is offline   Reply With Quote
Old 09-17-2013, 10:46 AM   #1019
torqdork
torqdork's Avatar
Drives: RV-7
I could see it happening if you were on constant throttle or going from on to off throttle when your hand slipped. At those points it wouldn't take much effort to disengage the gear. Technically, you could change every gear after launch that way without using the clutch, but there's no need since things sound awful if you get it wrong.
The one time you don't want the gear to disengage is when using cruise control. Should the trans jump out of gear into neutral the car will slow so the cruise control computer will call for more and more throttle to maintain set speed unless you disengage cruise with one of the several methods available (brake, clutch, button, lever and maybe e-brake).
Old 09-17-2013, 10:53 AM   #1020
HunterGreene
Hail Magnet
HunterGreene's Avatar
Actually, if the car comes out of gear, it will automatically disengage the cruise control, if I remember correctly.
It has priests in it?
Old 09-17-2013, 12:47 PM   #1021
torqdork
torqdork's Avatar
Drives: RV-7
I thought I tested this back in early July and the engine started revving when forced out of gear without the clutch but am no longer 100% sure. Maybe I'm thinking of one of the other Toyota M/T's in use. I won't be driving my FR-S today, can you could test and confirm?
Old 09-17-2013, 02:00 PM   #1022
HunterGreene
Hail Magnet
I would....but I'm currently rocking a rental while my hail damage is repaired. Sorry dude.
86 Owners of New England - Registry MannyO New England 247 10-27-2025 03:45 PM
**Tennessee Registry** Xryn Southeast 139 11-02-2022 12:31 PM
Mid-Atlantic Owners Registry. IloveBaldEagles Mid-Atlantic 366 10-24-2022 08:55 PM
Issue updating Registry. IloveBaldEagles Site Announcements / Questions / Issues 1 03-18-2013 07:19 PM
First 86 Registry: 2013 Scion FR-S Flipside909 Scion FR-S / Toyota 86 GT86 General Forum 44 05-18-2012 05:54 PM
