#393 |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
The vendor has determined I got a defective unit. I'm currently waiting for the sales staff to send a replacement. Apparently it is adding a character unexpectedly when the information is received.
- AdrianG |
| The Following User Says Thank You to AdrianG For This Useful Post: | Yruyur (08-27-2013) |
#394 |
Drives: 86 GTS
I'm using these mounts - www.stuggracing.com - awesome!
I have a question on graphing though - how can I add more than one PID to the line graph? I presume you can because of the yellow and purple key at the bottom, but I cant see how to add the second one... Thanks in advance. |
#395 |
Drives: Scion FR-S/Toyota Yaris
Has anyone tried the Asus Memo Pad HD 7 , has blue tooth 4.0, GPS,and a Quad car for $142 ? Its android 4.2 concerned about the eml connectivity.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#396 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
Semi-related question(s): Do they make wifi obd2 adaptors and can I pick up adaptors of any type at a pep boys or advance auto parts store?
Sent from my SCH-I535 using Tapatalk 4
#397 |
They sell them on ebay. Usually not locally.
Sent from a Motorola DynaTAC 8000X |
| The Following User Says Thank You to Yruyur For This Useful Post: | Turkish (09-01-2013) |
#398 |
daGangsta
Drives: 2013 FR-S 6MT
To the Torque App users who and have a tune (e.g. Unichip, Ecutek, etc) and use the app to log their vehicles: which parameters did you log and what did you look out for? How can you tell for sure, other than the way the car "feels", that the car is running right with your tune?
#399 |
Drives: Scion FR-S
Search for mad_sb's posts as he has a good writeup. I'd recommend logging KR (Knock Retard), AFR (air fuel ratio), LTFT and STFT (long and short term fuel trims), as well as ignition advance.
Short version: KR should be 0, LTFT 0.0 is perfection but realistically I see +/- 5% on good tunes, etc. Do a search, mad_sb has a very thorough reviews on how to gauge the quality of your tune. For general "health" logging, I also usually have coolant temp, oil temp, and IAT (intake air temp) up. |
#400 | |
Boosted
Drives: Sideways
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
| The Following User Says Thank You to Synack For This Useful Post: | Brody602 (09-04-2013) |
#401 |
Drives: '13 BRZ Ltd
So it seems like when you pull a freeze frame or fault log, the Vehicle Calibration ID is reported. Does anyone know if there's a way to access this if you don't have any DTCs?
#402 |
Drives: 2013 GBS BRZ Limited
#403 |
There are now 2 carseats!
Drives: 2013 DGM BRZ
If you have ecutek and a can log using that you are better off. Torque uses obd ii and not the ssm protocol (this car does use ssm right?) which means you get less resolution (data samples per given time) on it.
#404 |
For anyone looking at buying a tablet, I am smitten with this new Asus MemoPad HD7. It is quad core and fast, has GPS basically does everything the 2012 Nexus 7 does but is thinner and lighter. Even has a decent 5mp camera. For $142 its got to be the best option now.
#405 |
Drives: Scion FR-S
There's a listing in this thread of vehicle-specific PIDs you can manually enter. I use EcuTEK for a majority of my logging, so not sure which PID it is, but it can log knock retard.
#406 |
Drives: FRS(sold), AP2, R35, FJC, ED9
Just pull the rubber mat out and add a plate to extend it out. I originally did this to hold my cell phone but the Nexus 7 fits perfectly in there too. Not recommended for the track because it will tip back under hard acceleration. I am planning to add a couple tabs at the top to prevent tip over.
| The Following User Says Thank You to garfull For This Useful Post: | aagun (10-03-2013) |
| Tags |
| android, app, boost, gauges, torque |
| Torque app for android question | Brody602 | Electronics | Audio | NAV | Infotainment | 8 | 01-08-2015 04:53 PM |
| Torque for Android | Freeman | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 11-22-2012 11:05 PM |
| Android Torque app questions | Craig | Engine, Exhaust, Transmission | 1 | 11-12-2012 04:14 PM |
| Bluetooth OBD scanner and Android Torque - less than 25 shipped | whataboutbob | Engine, Exhaust, Transmission | 7 | 10-20-2012 01:15 PM |
| Android Tablet + torque | CharlieChaos | Electronics | Audio | NAV | Infotainment | 3 | 10-04-2012 08:23 PM |
