Old 08-27-2013, 11:42 AM   #15
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Here is the before video on the busted up road I was talking about. stock suspension with SPC camber bolts only. RS3 tires.
http://s174.photobucket.com/user/sol..._4071.mp4.html
After I installed the Swift springs, still with SPC bolts and Asymmetric 2's
ttp://s174.photobucket.com/user/solid_ONE/media/IMG_4334.mp4.html
Not sure if you can see the front pogoing after some of the bumps and potholes on the second video.
Old 08-27-2013, 12:31 PM   #16
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
great 2nd video driving btw
so you feel the rebound is too fast?
448hpsti is offline   Reply With Quote
Old 08-27-2013, 01:55 PM   #17
solidONE
solidONE's Avatar
Yes it rebounds to quickly with these springs, but it's not horrible. The rears are pretty much on point. That is why I think the 3k or 3.3k front spring of the FR-s spec and hotchkis would be closer to ideal.
Believe it or not my fastest time on that road was with stock suspension and tires.
Old 08-27-2013, 03:38 PM   #18
soodxn
Drives: S2000
more pics! =)
soodxn is offline   Reply With Quote
Old 08-27-2013, 05:13 PM   #19
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Just confirms that I need to wait for bilsteins, go cut koni or get more of what i already got, which I was trying to avoid...
Thanks so much for feedback
kiichiro is offline   Reply With Quote
Old 08-30-2013, 11:30 PM   #20
solidONE
solidONE's Avatar
Originally Posted by diddy View Post
You guys have close up pics of the springs installed? Want to compare to my install and see how springs are sitting.
Passenger Side Front:
Tire marks on front coils:
Front clearance with tire. My index finger feeler gauge was pretty accurate. abt 3-4mm clearance at full droop.
Nemo camber:
Driver side rear:
I'm hoping a 5mm spacer will let me add some more camber using a second set of camber bolts on the strut bottoms while eliminating the tire contact with the coils. May have to go 8mm spacer...
The Following User Says Thank You to solidONE For This Useful Post:
diddy (08-31-2013)
Old 08-31-2013, 07:28 AM   #21
diddy
diddy's Avatar
Drives: 2013 BRZ Sport-Tech
Originally Posted by solidONE View Post
Driver side rear:
On my rears, there is no gap between the top coils of the spring. The coils are touching each other. Is it installed wrong?
diddy is offline   Reply With Quote
Old 08-31-2013, 12:49 PM   #22
solidONE
solidONE's Avatar
Did the spring come like that? Also, on the lower spring perch are your springs seated like what you see in my photo?
Old 08-31-2013, 04:00 PM   #23
BRZ NA
Drives: WR blue
Nemo camber:
Driver side rear:
What size tire was that?and how much camber r u running?
BRZ NA is offline   Reply With Quote
Old 08-31-2013, 04:04 PM   #24
solidONE
solidONE's Avatar
245/40/17 Goodyear F1 Asymmetric 2 on RPF1 17x8 +45
SPC camber bolts and Swift BRZ springs.
the spc camber bolts and the 1" drop is getting me about 1.5 degrees of neg camber, more or less.
BRZ NA (08-31-2013)
Old 09-13-2013, 11:49 PM   #25
solidONE
solidONE's Avatar
Just a little update on my suspension with the Swift springs installed. Initially after installation the rear end felt very good with the factory dampers offering enough damping for these up-rated springs. Now, while I'm still pretty satisfied with the ride and performance, I feel the rear damper's compression damping to be a little bit lacking for the springs. I'm not sure if it's the oil in the factory dampers breaking down in viscosity or if I just hadn't noticed before, but the rear seems to have softened a bit. Not to the point of bottoming, but compliant with a little boat-like action over some bumps.
I suppose you really can't ask for too much with just lowering springs. I'm sure when they are coupled with heavier duty dampers they will be that much better.
Here's a recent test 'lap' I did with stock wheels and tires after adding some more negative camber out front. http://s174.photobucket.com/user/sol...43611.mp4.html
Intent > Content
Sleepless (07-29-2014)
Old 09-14-2013, 12:34 AM   #26
yhng
Drives: -
Did you cut the bumpstop during installation? I haven't driven around enough to have a proper impression of the springs but so far been pretty happy with them.
yhng is offline   Reply With Quote
Old 09-14-2013, 02:18 PM   #27
solidONE
solidONE's Avatar
Yes I cut the bumpstops.
Intent > Content
Old 10-29-2013, 01:10 PM   #28
trustyler
Drives: Toyota 86
What sized tires are you using?
trustyler is offline   Reply With Quote
Swift Springs BRZ TouchMyHonda Suspension | Chassis | Brakes -- Sponsored by 949 Racing 149 05-12-2015 12:33 AM
RS*R vs Swift Springs SurfAndSand Suspension | Chassis | Brakes -- Sponsored by 949 Racing 90 07-12-2014 09:32 PM
wtb:swift frs springs bkblitzed Want-To-Buy Requests 0 06-16-2013 04:03 PM
SWIFT lowering springs ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 10-31-2012 06:15 PM
Will US spec lowering springs for the FR-S fit on our 86 in Aus? leej AUSTRALIA 7 07-08-2012 04:24 AM
