Old 08-22-2013, 03:24 AM   #1
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Swift BRZ spec lowering springs reveiw
I installed a set of Swift BRZ springs ordered from kami speed. 2 reasons I chose this spring kit over others was the spring rates (3.8k f/4.5k r) seemed like they would reduce some of the oversteer without inducing understeer. Second reason is that the modest 1" drop will retain some effective stroke with the dampers while giving me some much needed negative camber. Oh... and also the sample picture lead me to believe that these springs had less number of total coils. In reality it has the exact same number of coils per spring compared to the factory units. http://www.kamispeed.com/Swift-Sport...FShxQgodn0QAPg
My impressions of these springs is that the spring rates seem better suited for the factory dampers than the stock FR-S springs. Although the front springs would benefit from a bit more rebound damping, the way the front seem to want to push back a bit after going over some larger bumps. Other than that, I'm very happy with this mod. The ride feels slightly better than stock while cruising and the chassis stays flatter under hard cornering. The oversteering tendencies under throttle has been muted and turn in has pretty much stayed the same as with just front camber bolts, as far as I can tell.
In retrospect I think their FR-S spec spring kit (3k f/ 4.5k r) would have worked better with the factory dampers. This is with just spirited driving and commuting on the streets on factory rims/tires. Hopefully I can get back on the track soon and see how I like these springs there with some stickier tires. For the money, I'm happy with the result and I'm one to look for the 'best bang for buck'. Would recommend.
The Following 2 Users Say Thank You to solidONE For This Useful Post:
Brzzee (04-20-2016), Corner3garage (08-22-2013)
Old 08-22-2013, 12:52 PM   #2
Corner3garage
Corner3garage's Avatar
Drives: FR-S & BRZ
Awesome to hear that another person on here is liking the only springs we sell! swift springs!
Corner3garage is offline   Reply With Quote
Old 08-22-2013, 02:34 PM   #3
solidONE
solidONE's Avatar
I was just about to mention Hotchkis since I brought up "bang for the buck." The rates on their springs look like they would match the factory dampers quite well. At about $200 MSRP that seems like it would be the ultimate "bang for buck" springs.
Is there a reason that you carry some of their sway bars and strut bar, but not their lowering springs?
Old 08-22-2013, 05:35 PM   #4
Goya
Goya's Avatar
Drives: 2013 SWP BRZ
thanks for the review, but why dont you go ahead and post some pics...
Goya is offline   Reply With Quote
Old 08-22-2013, 07:56 PM   #5
Chase86
Drives: Ultramarine FRS
Thanks for the review!
Chase86 is offline   Reply With Quote
Old 08-22-2013, 11:27 PM   #6
solidONE
solidONE's Avatar
Cause I forgot to take photos of the springs. Here are some side by side photos of a stock height hotlava and my whiteout with the Swift springs.
Second thought... I will take better photos tomorrow.
The Following User Says Thank You to solidONE For This Useful Post:
Goya (08-23-2013)
Old 08-24-2013, 01:20 AM   #7
solidONE
solidONE's Avatar
The Following 5 Users Say Thank You to solidONE For This Useful Post:
chriscross_tnt (12-07-2013), Clipdat (08-24-2013), Fly Guy (08-03-2014), Goya (08-26-2013), Wolfking (08-26-2013)
Old 08-24-2013, 02:24 AM   #8
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Absolutely love this pic!
Originally Posted by solidONE View Post
Originally Posted by humfrz
I'm old and lazy
Old 08-25-2013, 06:25 AM   #9
solidONE
solidONE's Avatar
Here it is with one of my all time favorite cars, Shelby Cobra, at Streets of Willow.
245/40/17 Goodyear F1 Asymmetric 2 on RPF1 17x8 +45
SPC camber bolts and Swift BRZ springs.
Track impressions of this combo:
There is a touch of understeer while cornering, but if you mash the throttle with the wheels turned it will still easily show you it's back end. I settled on 38psi front and 36psi rear hot pressures toward the end, so that might have also contributed to understeer. Tires had decent grip but unimpressive compared to the 225/45/17 RS3 Hankooks I had on it before. Only tires I had to compare it to was the stocks and the Kooks. With the tires and springs there was barely any clearance between the tire and the lower spring coil/perch. Using my ghetto index finger clearance checker I'm guessing about 3mm of clearance with these tires. the Asymmetric 2's also had rounded shoulders, so tires with more squared off shoulders of this size may rub. Tires were also a bit noisy on the highway drive to Rosamond, much like the RS3.
My lap times were on par with my last visit to streets only this time we were going CCW at night instead of CW in the day. Also, I was not able to get very many laps in. Less than 20 laps for the entire night (4pm to 11:30pm). So I will say this is an improvement considering less grip with the new tires, the lack of visibility, and not having as much time on the track. Also, I hear lap times tend to be higher CCW than CW. Not sure if that is true.
Conclusion? Still recommend.
Old 08-26-2013, 01:43 AM   #10
diddy
diddy's Avatar
Drives: 2013 BRZ Sport-Tech
You guys have close up pics of the springs installed? Want to compare to my install and see how springs are sitting.
diddy is offline   Reply With Quote
Old 08-26-2013, 02:26 AM   #11
solidONE
solidONE's Avatar
I will take some photos when I swap my wheels later. yerwelcome
I just got done throwing around the car on my "test track." A one way, twisty, chewed up road by my house. Man.. I wish I went with the FR-S spec or Hotchkis. The front end was pogoing a bit. Definitely can use some more damping... definitely... definitely more damping. [Rainman voice] Or less spring...
Old 08-26-2013, 10:48 AM   #12
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
what the difference between the frs and brz versions of their product?
448hpsti is offline   Reply With Quote
Old 08-26-2013, 07:57 PM   #13
solidONE
solidONE's Avatar
The front spring rates are different. BRZ spec come with 3.8k/4.5k f/r. The FR-S specs are 3.0k/4.5k.
kiichiro (08-26-2013)
Old 08-26-2013, 10:31 PM   #14
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Thanks
kiichiro is offline   Reply With Quote
Swift Springs BRZ TouchMyHonda Suspension | Chassis | Brakes -- Sponsored by 949 Racing 149 05-12-2015 12:33 AM
RS*R vs Swift Springs SurfAndSand Suspension | Chassis | Brakes -- Sponsored by 949 Racing 90 07-12-2014 09:32 PM
wtb:swift frs springs bkblitzed Want-To-Buy Requests 0 06-16-2013 04:03 PM
SWIFT lowering springs ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 10-31-2012 06:15 PM
Will US spec lowering springs for the FR-S fit on our 86 in Aus? leej AUSTRALIA 7 07-08-2012 04:24 AM
