Old 09-13-2013, 10:35 AM   #15
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
If you go avo and your car is anything like mine, I'm under 300whp but at 260 tq. With a supercharger the tq is much less so you can get away with a lower clutch rating
Old 09-13-2013, 10:37 AM   #16
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Looks good. Oh wait, no it doesn't for 300 whp and 250 ft-lbs.
Works for the numbers in your sarcastic quote
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 09-13-2013, 11:11 AM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
No it doesn't. Where are you guys getting this misinformation? That clutch from the manufacturer says it can hold 203 ft-lbs at the wheels. Nearly all turbo kits and even some of the supercharger kits are making more than that.
Old 09-13-2013, 11:14 AM   #18
phloozy
phloozy's Avatar
Drives: Scion FR-S
No it doesn't. Where are you guys getting this misinformation? That clutch from the manufacturer says it can hold 203 ft-lbs at the wheels. Nearly all turbo kits and even some of the pathetic little supercharger kits are making more than that.
FTFY!
phloozy is offline   Reply With Quote
Old 09-13-2013, 11:24 AM   #19
ZionsWrath
Thanks
ZionsWrath's Avatar
I don't know I'd consider them pathetic. I'm trying to be objective in my decision but if my goal is the power an SC can achieve, I don't need an oil pump [to the turbo] or my oil pan drilled, I can install in my backyard without lifting the car off the ground.
I mean if you can tell me or link me why a turbo is way better I'm all ears because I want the most cost effective DD setup with regular track use around 300whp, otherwise just saying SC is pathetic is kind of useless...
Old 09-13-2013, 11:32 AM   #20
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
LOLz.. he's an Innovate owner, he's just being silly.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
phloozy (09-13-2013)
Old 09-13-2013, 12:18 PM   #21
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
It's pretty simple.
It's a clutch that comes highly recommended. I've used it in the past and one that I recently purchased to use again.
My last Exedy stage 1 took the 280 ft-lbs I threw at it every day for 4 years until I traded in the car and when I had the clutch uninstalled to return to stock it was in great shape. I'd say 70K boosted miles is pretty impressive.
It's a clutch that retains OEM driveability and clutch feel. It's the clutch Ptuning recommended back then, it's the clutch they recommend for their own turbo system now. I tend to trust them because of the quality of work they do and the research they do. They don't recommend a thing if they haven't beat on it and used it themselves. Vendors wouldn't recommend it if it weren't capable of handling the additional strain.
I have experience with it at the power levels the OP is trying to achieve, that's why I recommended it.
If the clutch fails I'll eat crow and say it, I have no problem with that. I've had clutches fail in the past, springs pop right out the pressure plate and I was nowhere near the power the manufacturer claimed they could hold. It never happened with the Exedy clutch.
Old 09-13-2013, 12:39 PM   #22
xxscaxx
Drives: 2013 SWP BRZ
It's pretty simple.
Comforting to hear you have real world testing, but it still scares me to buy that clutch. It sucks because I want it, and I know PTuning suggested it, but I would be severely pissed if I installed it and had it slip on me after a little while and have to pull the tranny down again to swap it out.
Plus trying not to waste money, but TBH I think I still rather have this clutch than the others people suggest. meh
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
ecko04 (09-13-2013)
Old 09-13-2013, 12:43 PM   #23
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
That's totally understandable. It never slipped and that was back in my younger days when I really the beat the shit out of my cars. It's my own experience that caused me to go back to it.
Sent from my HTC6500LVW using Tapatalk 4
Old 09-13-2013, 12:44 PM   #24
xxscaxx
I don't beat on my car which is why I was thinking of trying it out..but its just a gamble.
Who am I kidding, I will probably buy it
Old 09-13-2013, 01:11 PM   #25
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It's pretty simple.
So you put 70,000 miles on a previously owned turbo BRZ/FR-S? Because unless you did, your experience is invalid in this case because we are talking about a different car with a different clutch design. What car was this previous Exedy Stage 1 clutch installed on?
Old 09-13-2013, 01:14 PM   #26
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
If you want to get into a back and forth about the reasoning why I recommend the clutch and prior vehicles, I cleaned out my inbox for you. Feel free to fill it up.
Old 09-13-2013, 01:45 PM   #27
phloozy
phloozy's Avatar
Drives: Scion FR-S
Why do people feel the need to take things to PM? There are other interested parties.
Old 09-13-2013, 01:48 PM   #28
King Tut
NASA SpecE30 Racer
King Tut's Avatar
There was nothing big in the PM. Here are the cliffs:
ecko04 will be using the Exedy Organic Clutch
ecko04 has used one on his previous two non BRZ/FR-S forced induction builds with success
ecko04's shop of choice recommends the Exedy Organic Clutch
ecko04's OPINION is that the Exedy Organic Clutch can hold much more torque than the 203 ft-lbs it is rated to hold by Exedy themselves
King Tut expressed to ecko04 that he is stating an opinion and not a fact
Sportsguy83 (09-13-2013)
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
