wat
Drives: a potato.
Headlight auto on thing
Whenever the car is locked/unlocked the headlights stay on for a moment, i went to Toyota to get this switched off like the manual says.
Well, they want $108 to do this, does that seem normal? |
#2 | |
Drives: Scion FR-S
#3 |
wat
Drives: a potato.
nah, everytime i lock/unlock the car the low beams and maybe the drls, or high beams, can't really tell...both come on for roughly 15-20 seconds then shutoff
#4 |
Phantom
Drives: Whiteout MT
that's weird, only my turn signals light up for 1 second on unlock or lock
| The Following User Says Thank You to nbafandan For This Useful Post: | Jake_86 (06-16-2015) |
#5 |
Victim's aren't we all
Drives: Toyota GTS 86 - Pegasus White
My DRL's switch on when I turn on the car. But the main lights only turn on if the auto sensor detects it's dark enough to turn on the lights. Then when I'm exiting the car they only stay on until I open the door.
#6 |
Drives: 2013 Scion FRS
Hi Rumbaar, would you please confirm that this is indeed the behavior of your Scion FR-S? My headlights or DRLs do not turn off when I open the door, it simply beeps until I manually turn them off. This is how my Lexus behaves and I would love for my FR-S to do the same. Does anyone know if it is something that can be set via the Main Body ECU? Thanks for the suggestions any fellow members could provide me with.
#7 |
First 86 Driver Baby!
Drives: FR-S, Flex
He lives in Australia & has a Toyota GT-86, so no Scion. I'm pretty sure it can be turned off using techstream, though.
#8 |
wat
Drives: a potato.
Just heard about that techstream, looks like im going that route.
#9 |
Drives: 2013 Premium BRZ
I am having an issue with my Auto headlights switch. When I put it in Auto headlights in the daytime, the low beams come on and not the DRLs. Also, the navigation display remains in night mode. I have to manually set the switch to O - off, in order for the DRLs to come on and the navi display to be daytime mode.
I just realized it started doing this. Before, I would always have it on Auto and the DRL's and navi display mode would adjust based on the amount of day light there is. Do you think it has something to do with sensor that detects the amount of outside light? It is a minor issue, but its frustrating to know that I am already having issues when I've only had the car for a month. Anything helps! thanks
#10 |
are you still under warranty? it sounds like a sensor problem. I never use the auto option on my car and it doesn't make anything difficult. if you're no longer under warranty, I would just say to start manually switching your lights since the dealership would probably charge you a lot to fix it.
#11 | |
Drives: 2015 CWP BRZ Limited
#12 |
u could try this app called "carista" (on android) paired with an obd2 bluetooth scanner, its like a portable techstream
https://play.google.com/store/apps/d....carista&hl=en http://www.amazon.com/iKKEGOL%C2%AE-...etooth+adapter |
| The Following User Says Thank You to mush For This Useful Post: | IceFyre13th (06-17-2015) |
| WTB Stock headlight projectors from retrofit OR a broken headlight | official_george | Exterior Parts (Aero, Lighting, Etc.) | 3 | 12-02-2013 03:32 PM |
| Auto Headlight Sensor Conector Help!!! | kmbkk | BRZ First-Gen (2012+) — General Topics | 5 | 06-04-2013 09:43 AM |
| PROGRAM AUTO-ON HEADLIGHT FEATURE | xcelir8brz | BRZ First-Gen (2012+) — General Topics | 4 | 07-14-2012 09:20 PM |
| Auto headlight weirdness | Grimlock | BRZ First-Gen (2012+) — General Topics | 9 | 06-05-2012 02:40 PM |
| First thing you are going to do when you get your BRZ? | Norcalmav23 | BRZ First-Gen (2012+) — General Topics | 74 | 04-02-2012 11:05 PM |
