Old 09-09-2013, 01:52 PM   #155
losjackal
Drives: FR-S 10-series #405
Luis_GT, and others who prefer to turn the nannies off for daily driving....would you similarly turn off ABS if you could?
losjackal is offline   Reply With Quote
Old 09-09-2013, 02:23 PM   #156
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
I can say that leaving it on at the track doesn't hurt you. I ran a 1.46 at PIR with it on. Ran the whole time on the edge of traction with out getting loose or traction control kicking in at all. During my first 2 sessions it was wet so If kicked in a lot as the stock tires are soft. But I'm sure it saved me from spinning out like several other cars did.
Video for reference
[ame]http://youtu.be/EuOE9re3Xyc[/ame]
Lets be honest, if u get sideways at the track you are loosing speed. So on or off won't change much if you are going for time. I do turn it off some times for fun in the rain.
FRSfan111 is offline   Reply With Quote
Old 09-09-2013, 02:25 PM   #157
Luis_GT
I have driven without ABS due to electrical faults, would I disable it if I had the option, probably not.
Old 09-09-2013, 03:17 PM   #158
fr3nch13
Originally Posted by cfusionpm View Post
My last car ended up like this, so I leave mine on all the time. I don't another stupid mistake in a low traction scenario and I'd rather not repeat another wet slide/roll.
Hey, at least you were next to a call box. :-p
fr3nch13 is offline   Reply With Quote
The Following 2 Users Say Thank You to fr3nch13 For This Useful Post:
cfusionpm (09-09-2013), DylanFRS (09-09-2013)
Old 09-09-2013, 03:21 PM   #159
fr3nch13
Nice! That has to feel good to pass a Porsche.
Old 09-09-2013, 03:24 PM   #160
losjackal
That's a cool overlay! How does that information get in the video?
Originally Posted by FRSfan111 View Post
Video for reference
Yes this is what I am wondering. These TC and VSC systems are designed to keep power applied from the wheels to the pavement, and the car pointed in the right direction. I don't understand from a physics perspective how that can be a bad thing.
Theoretically they help preserve you getting the fastest times. If you never lose control, they'll never kick in. If someone can explain to me how they clock physically slower times with these systems on, I'd like to understand.
Old 09-09-2013, 03:29 PM   #161
FRSfan111
:happy0180:
The video is from an app on my iPhone called Harry's lap timer. It uses internal sensor and GPS to record all the information then overlays it onto the video it records while driving. Obviously I had my iPhone mounted to my dash lol. Once the race is done select the run you want to watch. Them click the apply overlay option and in about 2 min ur video will be ready.
Old 09-09-2013, 04:01 PM   #162
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
They don't only kick in when you lose control. If you are driving fast, you are utilizing a certain amount of slip angle in the tires, doesn't mean you are drifting or even "getting sideways". The system in our car doesn't really care what is the optimal slip angle. It sees slip and cuts power. All the power.
DylanFRS is offline   Reply With Quote
The Following User Says Thank You to DylanFRS For This Useful Post:
strat61caster (09-09-2013)
Old 09-09-2013, 04:20 PM   #163
losjackal
Isn't this what the VSC Sport more is for though? It allow some slippage, but not spinning out?
P.S. What makes you say "all the power"? I would think some power is still required to keep the car on course.
Old 09-09-2013, 04:27 PM   #164
Luis_GT
Whenever the car starts to "slip" it cuts all throttle from he engine, so you are left powerless and relies on brakes to adjust the cars direction.
The Following User Says Thank You to Luis_GT For This Useful Post:
Old 09-09-2013, 04:28 PM   #165
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Yes, that is what VSC Sport should do. Instead, it feels like a 12 year old is controlling the brakes and throttle via a Playstation controller.
I mean "all the power" as in you might as well be hitting a rev limiter, it pretty much just cuts fuel. Or at least that is how it seems to me. Regardless, I always turn off VSC and TC at the track.
Last race we had in the rain I thought I better leave VSC Sport on and shaved 3 seconds off my time when I decided to turn it all off. Was I faster without the aids? Definitely. Was I also much more likely to lose control and spin completely without the aids? Definitely. Which is why I leave them on for my daily commute. Spin at the track. No big deal, fix it on the next run. Spin entering a highway next to a mini-van full of kids....
The Following 4 Users Say Thank You to DylanFRS For This Useful Post:
losjackal (09-09-2013), Luis_GT (09-09-2013), strat61caster (09-09-2013), thill (09-09-2013)
Old 09-09-2013, 06:23 PM   #166
juliog
juliog's Avatar
Drives: 86
Lets be honest, if u get sideways at the track you are losing speed.
Correct. However, technically you will be faster if you corner within a certain slip angle.
The ECU on the 86 has no idea what tires you are running or what the road conditions are. The driver has more information. Grippy tires , proper alignment and good pavement, the computer may think you're about to lose control (and apply brakes individually on each corner) way before you hit that ideal slip angle. Makes sense since on this car, TC and VSC are safety (not performance) features above all.
Also you get more traction (higher coefficient of friction) and therefore better acceleration when there's a small amount of wheel-spin, a.k.a. wheel-slip. TC systems don't like wheel-spin and will apply brakes for you, even on straightaways. Try to launch your car with TC on and then try it again with TC off. With some practice, you should clock faster 0-60 and 1/4 miles times when it's off.
http://www.hondata.com/help/traction..._operation.htm
Now, Nissan's ATTESA , Mitsubishi's AYC and Porsche's latest stuff (TPV, rear axle steering..)... those systems are way more advanced and designed for performance, making the cars faster in the majority of cases
juliog is offline   Reply With Quote
The Following 4 Users Say Thank You to juliog For This Useful Post:
cfusionpm (09-10-2013), DylanFRS (09-10-2013), losjackal (09-09-2013), strat61caster (09-09-2013)
Old 09-10-2013, 04:13 AM   #167
FRSfan111
I understand what ur saying and don't disagree at all. However my time on the track has not required me to turn it off. My TC definitely hinders my 1/4mile and so as you stated I don't use it when I'm trying to launch. Interestingly enough through DDing my car I've been able to on several occasions launch my car at just the right rpm to chirp the tires then roll on the gas aggressively with out activating my traction control.
Also through both my track days my tc never went off even with my tires squealing through all the corners. On the street when I don't have as much room to apex it is verry intrusive though. Idk if its the difference in the apex that helps on the track or what. My car is a first 86 so it's older then almost every car on this forum but I can't imagine that it's malfunctioning since it kicked in a lot during my first 2 sessions when it was raining on Friday.
But for what ever reason it was just not kicking in at all my last 2 sessions when it was dry and I'm not mad about it lol.
Old 09-13-2013, 11:43 AM   #168
NIKOLA
NIKOLA's Avatar
Drives: 2013 Scion FR-S in Ultramarine
I try to keep my traction control off, but it comes on automatically after travelling a short distance down the road. How are any of you keeping traction control off all of the time?
Currently driving a Sprintex Supercharged FR-S in Ultramarine with an Invidia N1 Catback with Catless Front Pipe, Invidia Over Pipe, Injen Catless 4:1 EL Headers, Perrin Aluminum Drive Pulley & Driveshaft Shop Aluminum Driveshaft. Also, looking to upgrade wheels someday to Enkei PF01's (17x8's).
NIKOLA is offline   Reply With Quote
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
traction control question Sileighty_guru BRZ First-Gen (2012+) — General Topics 9 09-26-2012 09:54 PM
CEL Traction Control ON then OFF HATED1 Issues | Warranty | Recalls / TSB 5 09-24-2012 07:11 PM
traction control issue *KID* Scion FR-S / Toyota 86 GT86 General Forum 13 07-08-2012 08:13 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
