Old 09-09-2013, 08:25 AM   #211
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by phloozy View Post
Base Innovate: 3195
Base FA20Club:3500
Base Vortech: 4000
Vortech vs Innovate
Where did you get this dyno since you haven't dyno'd your own car yet... And seriously, you had moto-east do your install, but you didn't pony up for a dyno tune while you were there? That's just crazy.
And I know this dyno isn't from moto-east because his vortech tune is on my car, proven via dyno.
When it comes to moto-east tunes, for the innovates to come close to me they have to run E85, same dyno same tuner, innovate e85 265 with alot under the curve, my vortech @ 274 with 150tq at 2k... On 92 WAWA gas, if I went e85 I think it would be a blowout.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 09-09-2013, 08:55 AM   #212
phloozy
phloozy's Avatar
Drives: Scion FR-S
I didn't go with a dyno run on Mikes suggestion. I asked him if I should throw it on the dyno and he let me know it was up to me but wasnt necessary since he would be road tuning and my build was fairly generic (innovate/injectors with no other real power mods). I hope to get it on a dyno soon but honestly don't care about the numbers.
Here is the thread I took the dyno from. http://www.ft86club.com/forums/showthread.php?t=41909 He says its the same dyno and same tuner.
phloozy is offline   Reply With Quote
Old 09-09-2013, 09:17 AM   #213
Adeets
OEDC
Adeets's Avatar
Did you miss this lil blurb below the dyno:
DYNOJET WHEEL HORSEPOWER:
INNOVATE BASE TUNE: 213HP 171TQ
VORTECH BASE TUNE: 212HP 176TQ
The Vortech Kit was set to it's lowest horsepower map
My BRZ FI Build
Old 09-09-2013, 09:22 AM   #214
phloozy
phloozy's Avatar
Drives: Scion FR-S
The Vortech Kit was set to it's lowest horsepower map for fair comparison
So that kinda sums up that dyno, the vortech was under tuned so it was a fair acceleration test between the two.
RIGGED DYNO.
That blurb is from Dezoris not FRSPirate who posted the dyno.
Old 09-09-2013, 09:26 AM   #215
Adeets
OEDC
Adeets's Avatar
A dyno is all ways worth it, not for the numbers but for the peace of mind. (It's also nice to know your getting everything that is safe out of that 4k investment under the hood.)
A canned tune will never provide the peace of mind that a dyno does... (Unless ur v-tuned)
My BRZ FI Build
Old 09-09-2013, 09:28 AM   #216
Adeets
OEDC
Adeets's Avatar
Yeah I read further on, only thing I can think about that is that that tuner is horribad.
When I was on stock injection moto-east still got me to 263. On 92 octane.
My BRZ FI Build
Old 09-09-2013, 09:32 AM   #217
phloozy
phloozy's Avatar
Drives: Scion FR-S
I agree which is why I brought it up. It is not a canned tune though, mike had ther car for a day and road tuned. I do agree with you though a dyno graph would be nice to see, I put all my faith in mike which may be foolish but so far I am more than happy with the way the car drives.
Honestly all a dyno would do at this point is eat into my ego and make me want more power :P The car felt perfect from 2k- redline in every gear so that was fine with me.
Old 09-09-2013, 09:34 AM   #218
phloozy
phloozy's Avatar
Drives: Scion FR-S
Also every dyno is different. This is another reason it's bad to play the numbers game. For all we know that dyno posted baselines at 130 whp.
Old 09-09-2013, 09:37 AM   #219
s2d4
s2d4's Avatar
peak hp gives you forum bragging right though
justifying ones purchase is the norm for some so it seems.
Old 09-09-2013, 09:57 AM   #220
xjohnx
Grip>Slip
xjohnx's Avatar
FWIW, here's a comparison of NA vs Innovate on my car.
Unfortunately for the Innovate kit we had to abort the dyno run early because the dyno operator thought that the car was running lean (We later discovered that the issue looks to have been with the dyno's tailpipe wideband. I'll be adding my own just to be safe.) As soon as my wideband arrives and is installed I will be rescheduling to redo the E85 Innovate runs, and do some 93 runs as well. The car appeared to be on track to make ~250rwhp though.
NA Mods: Nameless Overpipe/Downpipe/High-Flow Cat, Nameless Axleback, K&N Panel Filter
Fuel: E85
Tune: Visconti
Temp: 60F
Innovate Mods: Same as above + Innovate SC (stock 75mm pulley), DW65c Fuel Pump, DW700C injectors
Fuel: E85
Tune: @DeliciousTuning (First shot at the tune, no revisions as of yet.)
Temp: 80F
Old 09-09-2013, 10:02 AM   #221
Adeets
OEDC
Adeets's Avatar
Fuel: E85
Tune: Visconti
Temp: 60F
Innovate Mods: Same as above + Innovate SC (stock 75mm pulley), DW65c Fuel Pump, DW700C injectors)
Fuel: E85
Temp: 80F
I wish you did another pull, that does look like a very nice flat torque curve... And ur HP line could be used in blue prints.
My BRZ FI Build
Old 09-09-2013, 10:03 AM   #222
phloozy
phloozy's Avatar
Drives: Scion FR-S
Wow that curve looks perfect
Sent from my HTC One using Tapatalk 2
Old 09-09-2013, 10:12 AM   #223
xjohnx
Grip>Slip
xjohnx's Avatar
I did a couple others, they were having some RPM dropout issues though, need to find a better place to clamp for RPM signal pickup. Moto-Mike's tune/curve was very similar.
Run 8 is Delicious's E85 run
Run 9 is Moto-Mike's E85 Map 3 (slightly less aggressive timing)
Run 10 is Moto-Mike's E85 Map 4 (slightly more aggressive timing)
All three were only run to ~6500 because of the uncertainty with the wideband.
Old 09-09-2013, 10:33 AM   #224
Adeets
OEDC
Adeets's Avatar
Ot
Have you seen any full pulls of moto-mikes e85 innovate tune?
My BRZ FI Build
N/A power output potential as race setup? rice_classic Engine, Exhaust, Transmission 67 12-17-2013 07:03 PM
Abbey Motorpsort GT86 Sprintex installation Mark@Abbey m/s Forced Induction 18 09-07-2013 04:11 AM
WA Next meet Sun 30th June - Sprintex Test Drive AND A One Audio display plus special invisage Australian Meets & Events 2 07-22-2013 03:20 AM
Sprintex Supercharger Sneak Peak!!! invisage Forced Induction 52 03-03-2013 06:11 AM
