Old 09-06-2013, 04:21 AM   #1
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Question Should I worry about gas aging at the gas station?
The gas station nearest my house only sells ethanol-free gas. They offer 87, 89, and 93. I live in a fairly rural area, and this is a really old, really popular, 2-pump mom and pop grocery store/deli/gas station all-in-one with no competitors for miles situation in a really haggard looking building. It pretty much fits the bill of a backwoods Mississippi store. Shoeless toothless customers and all.
I use their 87 octane in my Tiburon all the time and it runs beautifully. There's a new modern gas station 15 minutes away now, and they have one single 87 octane ethanol-free pump out their 8+ pumps. Their gas is ok, but my car still runs better on the mom and pop gas, so I use it.
Being they're the only store for miles, everyone knows the ~90 year old owner, and most people would rather support local small businesses, the mom and pop store is always slam packed and it's not uncommon to have to wait in line to get gas. Most customers have old trucks, boats, and lawn mowers. I've actually never seen anyone there buy anything but 87. Which leads me to wonder...
How old must their 93 be? And since it's ethanol-free, does that even matter? I'd love to put ethanol-free 93 in my FR-S, but I'm kind of sketched out at the thought I could very well be the first person to ever use that gas.
I'm considering just asking them how often it's refilled. If it's not too bad, I could get my girlfriend to start using it too. She has a 2ZZ Corolla, so she has to use at least 91 as well. Maybe between the two of us, they'll start having to buy 93 more often, thus having fresher gas.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-06-2013, 04:22 AM   #2
Anthony
Weight Nazi
Anthony's Avatar
I'm also going to buy a kit and test their 93 for ethanol either way. I recently found out that test kits are super cheap.
Old 09-06-2013, 08:42 AM   #3
Shagaliscious
Drives: Firestorm FR-S (MT)
Try it out in the girls Corolla. If it doesn't run well, tough shit
The Following User Says Thank You to Shagaliscious For This Useful Post:
Anthony (09-06-2013)
Old 09-06-2013, 08:46 AM   #4
Anthony
Weight Nazi
Anthony's Avatar
Hahaha you are drunk, sir. I love that car.
Old 09-06-2013, 08:48 AM   #5
Shagaliscious
Is it the Corolla XRS?
Old 09-06-2013, 08:50 AM   #6
Anthony
Weight Nazi
Anthony's Avatar
See, senior.
EDIT: Same engine as this car:
[ame="http://www.youtube.com/watch?v=HmscSzFurwg"]The World's Fastest Lotus? - /TUNED - YouTube[/ame]
...minus a few upgrades.
Old 09-06-2013, 08:50 AM   #7
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Ethanol-free does store a lot longer then fuel with ethanol. Further, in-ground fuel storage tanks do not have the wide temperature fluctuation that a car fuel tank can see (the in ground tank with see +/-2 change during a day while a car can see +/- 40). It is this wide temperature change that causes water to accumulate in fuel. In short, I think you are WAY over thinking this.
He's a idea, why don't you ask the station owner how often he gets a delivery. That will tell you how long the fuel has been in the ground.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 09-06-2013, 08:53 AM   #8
Anthony
Weight Nazi
Anthony's Avatar
So... based on what you just said... fuel doesn't necessarily "go bad" overtime, it just gets more and more water in it?
Old 09-06-2013, 09:00 AM   #9
Shagaliscious
See, senior.
Oh, I know. I used to own a 92 Corolla. The XRS is a fun car.
Old 09-06-2013, 09:32 AM   #10
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Depending on how humid it gets outside, I believe so. Probably a piss poor example, but I bought some gas from an old, small gas station and put it in my push mower. The day I bought the fuel and put it in my push mower, everything worked great. Over the next 2 weeks, it was very humid and I finally decided to cut my yard (typically cut my grass once every two weeks). Anyways, the push mower would not start. Took it to a shop that works on mowers and they said they found a lot of water in the engine. The push mower and the gas tank for the push mower are left in my garage and as someone else mentioned, the temperature fluctuation affects the fuel. This summer, I put fuel treatment in the gas tank that I use for the push mower and have not had a single issue all summer.
Regardless, I am sure our car engines have either a better tolerance or the gas tank in the vehicle is better engineered to slow down the process of the fuel turning into more water, or both.
Eurasianman is offline   Reply With Quote
Old 09-06-2013, 09:39 AM   #11
Anthony
Weight Nazi
Anthony's Avatar
Well I knew about humidity in cans and tanks, but I was under the impression that gas just "went bad" on its own overtime. Like as soon as it's refined, it begins to break down chemically, but very slowly.
Old 09-06-2013, 10:31 AM   #12
Gary in NJ
Gary in NJ's Avatar
Yes, fuel does go bad over time. Some faster then others. However, if you can keep air away from fuel it will last a lot longer. The problem with E-10 is ethanol is hydroscopic, so it happily absorbs moisture.
The Following User Says Thank You to Gary in NJ For This Useful Post:
Old 09-06-2013, 10:41 AM   #13
Anthony
Weight Nazi
Anthony's Avatar
Good to know. I'll test it when I get back to confirm that it really is ethanol-free and I'll ask the owner how often they refill it.
Old 09-07-2013, 11:37 AM   #14
Fluxx
Drives: 2013 FR-S in Ultramarine
Straight gasoline will keep for months, at least 6 before you run into trouble. Ethanol will start going bad after about 3 months.
Fluxx is offline   Reply With Quote
The Following User Says Thank You to Fluxx For This Useful Post:
Anthony (09-07-2013)
Do you worry about scratches under the front bumper? Liquidsnake Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 57 05-06-2015 07:11 PM
New car engine break-in period -- should I even care/worry? mav1178 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 03-03-2014 02:39 PM
Getting a BRZ tmw, worry about CEL Sniper2606 Engine, Exhaust, Transmission 25 04-22-2013 10:28 PM
A worry I have; Is it too good? Draco-REX BRZ First-Gen (2012+) — General Topics 29 11-21-2012 08:12 PM
