Old 09-05-2013, 08:52 PM   #841
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
SU-092313102 $2.13 ea at my stealership
448hpsti is offline   Reply With Quote
The Following User Says Thank You to 448hpsti For This Useful Post:
M1K3 (09-06-2013)
Old 09-05-2013, 09:19 PM   #842
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Originally Posted by nelsmar View Post
Is there a part number for that? Or a size? I took a number of clamps off my engine and none of them fit my hose lol.
Got it!
http://www.buysubarupartsnow.com/oem...lamp/092313102
nokia7190 (09-06-2013)
Old 09-05-2013, 09:57 PM   #843
nelsmar
Perfect! Thanks! I have injector clamps on mine but at least now others can find it
My flickr - Canibeat
Local magazine scout
Old 09-06-2013, 12:02 AM   #844
Dezoris
Dezoris's Avatar
Dont forget the clamps on your toilet seat plumbing as well.
Old 09-09-2013, 02:30 PM   #845
Andy@FA20Club
Drives: FA20Club.com
I need to go back and re-dyno now that I fixed a boost leak... and this time on full E85 (this was at ~70% ethenol). Obviously this dyno seems to read a bit low... I overlayed 3 charts in photoshop but should be pretty close to perfect. I'll be getting actual overlays from the dyno over the next few weeks after further testing.
Stock Auto VS Visconti dyno tuned flex fuel with intake & exhaust vs me 100% stock other than vortech + 3.125" pulley (with stock snorkel etc) + 540cc injectors & pump fa20club flex fuel kit. All stock exhaust etc.
I will be scheduling to go back for further testing & to get a plot where we actually take the car to redline. (which isn't a huge deal but hey i want some bragging rights!). I will see about hitting a dynojet once it cools down a bit as well as its hard to find any time when its below 100F out here in Phoenix. Hopefully on the Maha I will tap ~320WHP on pure E85 when I go back! Hopefully I will have time here soon to compare the 3.48 vs 3.33 vs 3.125, i have plots on multiple fuels on 3.48, and will be going back to 91 octane for a new comparison on the 3.33 & 3.125 later.
I will later be posting my innovate vs vortech comparison results once we get on the dyno a few more times & i get the original plots.
And a HUGE thanks to @FA20Club.com for flying out to Phoenix for two days to get these cars dialed in.
He had a great time out there
Andy@FA20Club is offline   Reply With Quote
Old 09-11-2013, 09:37 PM   #846
djliquidsteele
Drives: Scion FR-S
@Brian@Vortech, what is the the next logical blower to turn the engine RPM's to 9000 and make around 400whp? Is it possible to have an upgrade option?
djliquidsteele is offline   Reply With Quote
Old 09-11-2013, 10:05 PM   #847
xjohnx
Grip>Slip
xjohnx's Avatar
why 9k RPMs? where'd that number come from? do you have some cams that make power up that high?
Old 09-11-2013, 10:10 PM   #848
djliquidsteele
Drives: Scion FR-S
IDK. I just have this dream of making a super high revving screamer. This is all long term stuff for me. So while there might not be certain things available right now to make it all jive, by the time I can afford to do it, there's a good chance it will be.
Old 09-11-2013, 10:16 PM   #849
charged86
charged86's Avatar
I may hit 400whp on a dynojet with my new header an update on my tune. on the stock blower at 7400 rpm
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post:
pheoxs (09-12-2013)
Old 09-11-2013, 10:19 PM   #850
xjohnx
Grip>Slip
xjohnx's Avatar
not sure if you saw this post by evasive about DI limitations at that RPM:
Originally Posted by Element Tuning View Post
There are also limitations with direct injection at such a high rpm. This results in a heavy emphasis on port injection at very high rpm and therefore you are more detonation prone among other things. When I tuned the Hydra to deliver more DI I was making more high rpm power but I started to misfire.
Mostly what you see is the oem exhaust restrictions.
Old 09-11-2013, 10:21 PM   #851
djliquidsteele
Drives: Scion FR-S
I did not. Interesting.
So then the question is, can we get a bigger blower to say 16 psi at redline?
Old 09-12-2013, 05:09 PM   #852
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
For people that reach the maximum of what the V-3 can support, we now have an H/D oil fed version that can be upgraded to. The H/D unit can be spun quite a bit higher, and (to my knowledge) no one has been able to max it out yet. So, depending on your goals...you probably won't have to spin the engine up to 9K to hit your target horsepower, as long as the corresponding exhaust modifications are also included in your build plans. However, anything that spins the compressor faster will make more boost...so revving the engine to a higher rpm can be used in lieu of, or in combination with, different pulley combinations to reach the intended target power and/or boost.
Brian@Vortech is offline   Reply With Quote
The Following 4 Users Say Thank You to Brian@Vortech For This Useful Post:
448hpsti (09-13-2013), pheoxs (09-12-2013), RedAlert (09-13-2013), Rick@Vortech (09-12-2013)
Old 09-12-2013, 05:32 PM   #853
skatery1989
Drives: BRZ Limited
O I am going to put this new unit to the test very soon!
skatery1989 is offline   Reply With Quote
The Following User Says Thank You to skatery1989 For This Useful Post:
pheoxs (09-12-2013)
Old 09-12-2013, 06:28 PM   #854
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Price and is it a direct swap (not counting the oil feed lines)
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 07:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 06:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 04:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 07:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 06:06 PM
