Old 09-04-2013, 05:46 PM   #1765
hlk gts
Drives: Toyota ZN6
Originally Posted by djdnz View Post
18x9.5+44 will not fit in the front on stock suspension, absolutely no way. So since you dont want to adjust anything, get the 18x8.5 +44.
In the rear it will be close but likely no major issues.
Thanks a lot!!
hlk gts is offline   Reply With Quote
Old 09-04-2013, 06:57 PM   #1766
Admired
Drives: 2013 Scion FRS
Just ordered VIP VRC 13 concave wheels 19x9.5 front and 19x10.5 rear +30 all around with Airlift suspension and GT Spec LCA's. Gonna be one hell of a setup.
Admired is offline   Reply With Quote
Old 09-05-2013, 05:01 AM   #1767
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by nguyen_er View Post
Could I just convert the 5x100 to 5x114.3 using http://www.evasivemotorsports.com/mm...ICS-CONVERSION ? I know some people don't like it because it may put extra stress but I'm not really tracking or anything so..
Yes, you could. Front firmament would be aggressive.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 09-05-2013, 06:33 AM   #1768
nguyen_er
nguyen_er's Avatar
Drives: 2013 Raven FR-S
Thanks! I don't thjnk I'm going to get them. Oh well.
nguyen_er is offline   Reply With Quote
Old 09-05-2013, 03:59 PM   #1769
Deadpool_25
Drives: BRZ Limited
I'm planning on Eibach Pro Kit or Tein S-Tech springs with 18x9.5 +40 all around with Nitto Motivo (I think) 255/35/18. I'm looking for daily driving goodness: no rubbing, good performance, decently quiet, etc. Think this will work? Again, I don't want to be rubbing the tires on moderate bumps or bottoming the suspension out ever.
Deadpool_25 is offline   Reply With Quote
Old 09-06-2013, 11:42 AM   #1770
djdnz
1337
Drives: 2013 BRZ WRB S/C
Will not fit the front without coilovers or spacers. It will very likely interfere with the stock spring perch/springs. Sorry.
djdnz is offline   Reply With Quote
Old 09-06-2013, 01:03 PM   #1771
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
I'm currently running 18x8" +40 and 225/40/18 Michelin PSS on strock struts (konis and H&R sport springs) all around with -2.8* camber in the front. Would going to a 245/35 rub the front struts?
FastLane1000 is offline   Reply With Quote
Old 09-06-2013, 02:41 PM   #1772
Deadpool_25
Drives: BRZ Limited
Damn. Okay. Would I have the same issue with 18x8.5 +35 in the front? That should work, no?
Old 09-06-2013, 10:53 PM   #1773
Davesta619
Drives: Brz
Going Staggered set-up 18x8.5/9.5 +44mm offset with a 1" drop using Eibach Pro-Kit Lowering Springs. Going for flush/stance look. Will this fit perfect or will I need to buy anything else to make it look right?
Davesta619 is offline   Reply With Quote
Old 09-07-2013, 12:19 AM   #1774
djdnz
1337
Yes that will fit no prob. Fitment is great when lowered, will poke at stock height
Front will tuck slightly, slightly lower offset would be ideal for flush. Spacers in the front will help the look if you are not satisfied. Rear fitment will be good.
Old 09-07-2013, 08:21 AM   #1775
djdnz
1337
You would know the best out of all of us. See how much room you currently have, and how much wider the tread is on the new tire and divide by two. If that is less than what you measured currently you should be okay. If it's close then it's hard to say.
Old 09-07-2013, 10:07 PM   #1776
CajunFRS
Drives: Challenger R/T, CRX SI,
18X8 *5-100/11445MCH +45 Tenzo Cuzco 225/40/18 No springs or anything YET. What should I be looking to do so that this fits? Do I need any spacers or anything? I had these rims on a Civic a while back. From what i've seen they fit I'm just trying to make sure.
Thanks.
CajunFRS is offline   Reply With Quote
Old 09-08-2013, 05:01 AM   #1777
Thongpocket
Master Troll
Thongpocket's Avatar
Drives: 2013 BRZ Limited
Just found this thread and wanted to ask before I order monday. Planning on getting 17x9 all around with +32 offset and run 245/40/17 Hankook V12. Also plan to drop with Eibach sport lines. I would rather not stretch my tire as I use my car ALOT for DD duty. am I going to need to go with coil overs to make this combo work? Thanks for any help you can provide.
Thongpocket is offline   Reply With Quote
Old 09-08-2013, 09:29 AM   #1778
djdnz
1337
No they will fit without coilovers, but they will poke in the front unless you run around 2-3deg camber.
The Following User Says Thank You to djdnz For This Useful Post:
Thongpocket (09-08-2013)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
