View Poll Results: What weight oil do you run for track days?
0W-20 98 40.66%
5W-20 12 4.98%
0W-30 21 8.71%
5w-30 76 31.54%
10W-30 7 2.90%
0W-40 16 6.64%
Other 11 4.56%
Voters: 241. You may not vote on this poll
Old 08-26-2013, 12:47 PM   #1
brillo
Drives: 2013 Firestorm FR-S
Oil Weight Poll For Track Usage
Not trying to start a heated discussion on brands etc.. but curious to see what weight folks are running who frequent the track for HPDE, Drift, Racing etc...
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 08-26-2013, 08:06 PM   #2
kster1
kster1's Avatar
I voted for 0w20 but I actually use Redline 0w20 with 1-2 quarts of 5w30. I have the Robispec oil cooler so oil temps getting too high are not a concern for me.
kster1 is offline   Reply With Quote
Old 08-26-2013, 09:22 PM   #3
clintavo
Is there a reason one would choose 5w30 over 0w30?
clintavo is offline   Reply With Quote
Old 08-26-2013, 09:50 PM   #4
brillo
I have read that 5w-30 is more stable than 0w-30 so some prefer it in extreme environments.
Old 08-26-2013, 09:55 PM   #5
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
I mix 50/50 0w20 and 0w30 for track day
My 0w30 is a liqui moly lubricant from Germany, my 0w20 is Mazda factory moly enriched idemitsu
kiichiro is offline   Reply With Quote
Old 08-26-2013, 11:30 PM   #6
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Only been on track once since getting the car, but I've run Redline 5W-30 in my FR-S the last 2 oil changes. Might look for something cheaper next oil change, but it will be 5W-30 weight....because summer time in Houston, Texas is considered an extreme environment.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 08-27-2013, 09:02 AM   #7
brillo
interesting results thus far, I hope all the resident track rats and auto-x junkies have responded.
Old 08-27-2013, 09:14 AM   #8
canu_50
canu_50's Avatar
Drives: Scion fr-s
I use 0w40 redline on track!!
canu_50 is offline   Reply With Quote
Old 08-27-2013, 11:48 AM   #9
CSG Mike
CSG Mike's Avatar
In our case, it's because 5W30 is what we have, not 0W30, in Motul 300V.
If you're using a non-synthetic, then yes, there is a reason. The base stock for the 5W30 tends to be more robust than the 0W30 base stock. With a full synthetic, it's not an issue; if we had 0W30 300V, we'd be using that instead.
Old 08-28-2013, 08:22 AM   #10
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
I ran GC 0w30 in June at Sebring and saw oil temps in the 290s and touched 300*, then in August at Sebring ran Toyota 0w20 and saw oil temps in the 270s and 280s, so I'll probably continue to run the 0w20 to keep oil temps lower.
smbstyle is offline   Reply With Quote
Old 08-29-2013, 09:59 AM   #11
brillo
bump
Old 09-04-2013, 03:37 PM   #12
bluesubie
Drives: 2004 Subaru Forester 2.5XT
True, but it depends which 5W-30 and which 0W-30 you're talking about.
A Resource Conserving oil like most off the shelf oils have a low HTHS and may shear to a 20 grade anyway so a 5W-20 may be more stable than either one. OTOH, an oil that meets ACEA A3 specs like German Castrol 0W-30 (or the Liqui Moly mentioned above) has an HTHS of 3.5 or higher will usually stay in grade in harsh conditions. GC is nearly a 40 grade oil if you look at the kinematic viscosity and the HTHS viscosity (too thick on stock internals, IMO).
I would go with a robust 20 grade like Motul 300V 0W-20 or Red Line 0W-20 at the track. Here's a used oil analysis on Red Line after some track time in a supercharged FRS:
http://www.ft86club.com/forums/showthread.php?t=45452
TBN shows this oil could easily go for 5k miles in these conditions.
Red Line 5W-20 would probably be even more stable since, as I recall, it does not use any viscosity modifiers. I'd take Red Line xW-20 or Motul 300V 0W-20 at the track over any Resource Conserving xW-30 regardless of brand. Amsoil Dominator 5W-20 is also good race oil, although you couldn't run it as long as Red Line or 300V since it has a lower level of detergents/dispersants. Any of these oils could easily handle 3,750 miles intervals though (including track time).
-Dennis
bluesubie is offline   Reply With Quote
Old 09-04-2013, 09:00 PM   #13
kster1
kster1's Avatar
-Dennis
Dennis,
Do you if there is any significant difference in the formulation of Redline 0w20 and 5w20? Isn't 0w20 their new offering? For whatever reasons, I see 0w20 recommended a lot more than 5w20 on sites like BITOG.
Old 09-05-2013, 12:40 AM   #14
SeanRTR
C-Street AutoX
SeanRTR's Avatar
I use the Joe Gibbs DRIVEN FR20 oil for daily driving / weekly autocross use. Michigan Environment.
The DRIVEN FR20 oil from Joe Gibbs Racing is formulated with a higher zinc content to produce that extra bit of horsepower, while still maintaining everything else that you need for a daily driven/street car.
SeanRTR is offline   Reply With Quote
Scratches from Window Usage? DieselxIndustry Issues | Warranty | Recalls / TSB 27 03-08-2015 08:03 PM
Help: keyless access trunk usage ohtheantics BRZ First-Gen (2012+) — General Topics 13 09-07-2013 02:17 AM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-20-2012 11:31 PM
Stock tires usage in winter? ft86Fan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 07-13-2012 09:38 AM
