Old 09-04-2013, 02:36 PM   #29
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Turbowned View Post
I'd like to see the Innovate unit with a smaller pulley, 93 octane, full exhaust and upgraded pump/injectors.
i believe @moto-mike may have recently done a setup just like that, no? if not, @FA20Club.com might have. I'm not sure @DeliciousTuning has done any smaller pulley setups yet (unless @robispec is running one)
Old 09-04-2013, 02:37 PM   #30
Dezoris
Dezoris's Avatar
Originally Posted by xjohnx View Post
"Not knocking moto-east, just totally questioning his credibility."
fixed your post. if you're going to insult the man, don't try to church it up.
Not knocking his credibility or abilities, just how these guys avoid all the straight and hard questions about the kit and the issues.
They skip those and focus on the marketing and cherry picked dynos.
The Following User Says Thank You to Dezoris For This Useful Post:
xjohnx (09-04-2013)
Old 09-04-2013, 03:08 PM   #31
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by fenton View Post
Problem with waste-gating a vortech is that reduces its efficiency.
You are still drawing power from the motor to create 12 psi but only using 9psi of it and bleeding the rest off.
This runs the charger and gearbox harder but doesn't really use it. You can probably see where i am going with this.
Waste gated centri SCs generate more HP then same psi level non wastegated centris, also IATs drop when the wastegate actuates, I didn't believe it either til I did some research on mustangs and corvettes... The info is out there, just have to look instead of posting.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
The Following 2 Users Say Thank You to Adeets For This Useful Post:
Calum (09-05-2013), Darryljr11 (09-04-2013)
Old 09-04-2013, 03:13 PM   #32
fenton
Nothing i said is incorrect. Running the smaller pulley increases drag on the engine(more parasitic drag). The charger is ran harder(more rpm), the gearbox is ran harder(more rpm).
I didnt say it would heat up the charge or make less power.
Anyways we havent seen anyone even attempt this yet.
fenton is offline   Reply With Quote
Old 09-04-2013, 03:17 PM   #33
xjohnx
Grip>Slip
xjohnx's Avatar
Wasn't the car-b-que car running this setup, pre cookout?
Old 09-04-2013, 03:19 PM   #34
swift996
swift996's Avatar
I'd like to see the Sprintex/Innovate unit with intercooler, smaller pulley, 93 octane, full exhaust and upgraded pump/injectors. That would help me make up my mind.
Side note: I really wish the nearest E85 retailer wasn't 30 miles away
Expect about 250-270whp with that set up.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 09-04-2013, 03:19 PM   #35
Adeets
OEDC
Adeets's Avatar
Originally Posted by Dezoris View Post
Here is a guide for you:
Stock Car with Vortech
301HP+ (Sustained Usage, requires clutch, Fuel Injectors, pump, pulley)
300HP E85 (Smaller Pulley, Fuel Injectors Pump)(Clutch wear will be heavy)
270HP 93 Octane (Change Fuel Pump/Injectors)
250HP 93 Octane (No fuel system or other changes)
220HP 91/92 Octane (No Fuel System or Other Changes)
Stock Car with Innovate Non-Intercooled
300HP+ (Not Possible without intercooler if at all)
280HP E85 Octane (In Future)(Pulley Change Fuel Pump/Injectors/Meth Injection)(Clutch Wear Heavy)
250HP E85 Octane (Fuel Pump, Injectors)(Consider Meth Injection)
220HP E85 (No Fuel System or Other Changes)
205HP 93 Octane (No other changes)
190HP 91 Octane (No changes)
I'm at 274hp tuned on 92 WAWA gas, much to moto-mikes misery. Still alot left on the table, very safe tune with only 20degrees timing.
Injectors/fuel pump/header
My BRZ FI Build
Old 09-04-2013, 03:20 PM   #36
Adeets
OEDC
Adeets's Avatar
Negative he was running flex-fuel setup with 12.5 psi pulley.
My BRZ FI Build
Old 09-04-2013, 03:23 PM   #37
Adeets
OEDC
Adeets's Avatar
That's the thing, it doesn't since the back force exerted on the blower does not go up, heat is the by product of wasted energy, if your IAT's go down, your not wasting as much energy.
If parasitic lag increases, you would generate less power at the same psi. I just realized your trying to make 2 opposite statements in that post. Google, wastegated centri vs non wastegated centri.
My BRZ FI Build
The Following User Says Thank You to Adeets For This Useful Post:
Old 09-04-2013, 03:30 PM   #38
xjohnx
Grip>Slip
xjohnx's Avatar
I'm almost postitive that it was wastegated as well, not sure that was ever publicized though.
here's the video of their dyno when it was on pumpgas:
[ame="http://www.youtube.com/watch?feature=player_embedded&v=8irVuFpvZ4w"]Visconti Tuning - Vortech STG1+ Kit Pumpgas results - YouTube[/ame]
I do know there is a wastegated vortech being installed w/ the 12 PSI pulley and hitting the dyno any minute now, pretty sure it's going to be run on 93 exclusively.
Old 09-04-2013, 03:33 PM   #39
Adeets
OEDC
Adeets's Avatar
Gems? Thought he was on e85 and a different blower.
My BRZ FI Build
Old 09-04-2013, 03:34 PM   #40
xjohnx
Grip>Slip
xjohnx's Avatar
Nope. Another poster here (on the right coast). I'm sure he'll chime in with dyno's shortly.
Old 09-04-2013, 03:35 PM   #41
Adeets
OEDC
Adeets's Avatar
Oh the great fire chucker... 290 is nice, not worth burning in a v-irey inferno though.
My BRZ FI Build
Turbowned (09-04-2013)
Old 09-04-2013, 03:36 PM   #42
Adeets
OEDC
Adeets's Avatar
It will be nice to see, I'm doing some driver light weighting before I do the wastegate, so another couple of months before I do mine.
My BRZ FI Build
N/A power output potential as race setup? rice_classic Engine, Exhaust, Transmission 67 12-17-2013 07:03 PM
Abbey Motorpsort GT86 Sprintex installation Mark@Abbey m/s Forced Induction 18 09-07-2013 04:11 AM
WA Next meet Sun 30th June - Sprintex Test Drive AND A One Audio display plus special invisage Australian Meets & Events 2 07-22-2013 03:20 AM
Sprintex Supercharger Sneak Peak!!! invisage Forced Induction 52 03-03-2013 06:11 AM
