go_a_way1
Old 08-31-2013, 06:40 PM   #1751
Neekowahhhh
Enthusiast
Neekowahhhh's Avatar
Drives: Crystal Black BRZ Limited
Originally Posted by Slick View Post
The 17x8.25+35 will fit well, no issues and should move you pretty close to flush on the front, in slightly on the rear.
Your stock tires will fit well enough on this rim, so I would reuse those as you suggest.
But the 245/45R17's will be too tall. They will fit on the wheel and not rub anywhere, but the taller diameter will give you slower acceleration, which is not a great thing on our cars.
Thanks man, much appreciated!
Would I be better off going with +25 in the rear or + 25 all around?
Don't want the front poking out too much, but also don't want the back sitting in too much.
Instagram: Neekowahhhh
Mishimoto Air Induction Hose;K&N High Flow Air Filter;Berk Tech Catless Front Pipe;Invidia N1 Catback Exhaust TT;Matte Bronze XXR 527 17x8.25 ET 25
Neekowahhhh is offline   Reply With Quote
Old 08-31-2013, 07:48 PM   #1752
DAEMANO
Time Traveller
Hey Neeko,
@Osiris has the exact setup you're asking about. A 1-1.5" drop will round this out nicely.
Here are the details:
Wheels
XXR 527's in Bronze
17x8.25 +35 (he paid $560 incl shipping)
Tires
Stock Michelin Primacy's
215/45/17
Suspension
Stock
More pics:
Here
& Here
Good luck with the build man!
Originally Posted by Neekowahhhh View Post
Can someone help me out.. I'm just about ready to order my wheels but want to make sure im doing this correctly..
I was going to go with a staggered setup and 1" larger in diameter in the rear, but decided to go square instead.
I'm looking at picking up a set of XXR 527's in the following---> 17x8.25 5x100 +35
I plan on dropping about 1-1.5".. Will this be a fairly flush set up? I've seen 17x8 on the table chart with a +35 and a 1" drop and it looks good but the extra ".25" has me a bit confused. If I'm correct.. that means an extra 6.35mm.. does that affect the outcome of where the wheels will sit?
I'm losing my hair over here and just want to order these dang things already but don't want to get stuck with something I wont be happy with.. please and thanks to anyone who might be able to help me out here...
also, I plan on reusing the original tires just to wear them out, but plan on using a set of bridgestone potenzas from my moms last car, which are 245/45/17, will these fit as well?
The Following User Says Thank You to DAEMANO For This Useful Post:
Osiris (09-01-2013)
Old 08-31-2013, 07:50 PM   #1753
Neekowahhhh
Enthusiast
Originally Posted by DAEMANO View Post
Hey Neeko,
Wheels
XXR 527's in Bronze
Tires
215/45/17
Suspension
Stock
More pics:
Here
& Here
Thanks man!
Old 08-31-2013, 10:01 PM   #1754
Admired
Drives: 2013 Scion FRS
I am about to get XXR 527 18x9.75 +20
What kind of tire is best suited for this setup? I was thinking 215/40/18 or 225/40/18 or 225/35/18, I like a lot of rim poke but i'm not sure what I will have to do to make this work. I have Stance coils and LCA's. Will I have to roll my fenders or add camber or both?
Admired is offline   Reply With Quote
Old 08-31-2013, 11:34 PM   #1755
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Stick to +35. As shown in the pics it looks pretty good, not tucked in much.
Slick is offline   Reply With Quote
Old 08-31-2013, 11:40 PM   #1756
Slick
Slick's Avatar
That's pretty damn aggressive. You will need camber and more.
Not enough experience with these sizes, but this thread should help you:
http://www.ft86club.com/forums/showthread.php?t=25171
The ideal tire for that size rim is a 285/30R18, but it seems like you are looking for a super-stretch with those narrow sizes you stated.
Maybe someone else can chime in.
Good Luck!
Old 09-01-2013, 02:17 AM   #1757
quasimoto
quasimoto's Avatar
Drives: SWP BRZ Limited
No problems with that fitment at all. I'm running 18x9+35 so it is bit wider and I don't rub at all, also on a 1" drop.
You should be able to fit up to a 245/35R18 tire without rubbing.
Thanks for the helpful tip. Sorry if my questions make me sound like a newbie because honestly, I am new to the tuning scene so I appreciate your help. :happy0180:
So with my wheels at 18x8.5 +33 squared, would this fit fine on my stock suspensions and with no poke? Would it increase the gap at all? I know a lot of people have wider tires in the rear for performance reasons, but is it uncommon to go same tire specs all around? The main reason I went with a squared setup was so that I can do tire rotations to extend the life of my tires. If so, what are good tires specs for my setup? This is going to be my DD that will be driven spiritedly, but rarely tracked.
The other reason I went with the 8.5 over the 9.5 is because I wasn't a fan of the concave look. This is pretty much how I want my car to end up looking.
quasimoto is offline   Reply With Quote
Old 09-03-2013, 06:51 PM   #1758
hlk gts
Drives: Toyota ZN6
Hi Guys,
A total newbie here. Have been thinking to upgrade my wheel to prodrive gc-05n but worry about the fitment and scrubbing that may cost me more in the end. I wanted to buy 18"x9.5" +44 for all but willing to change the front to 18"x8.5" +44 if there is any issue. I have No intention to increase overall diameter neither want to drop, adjust camber, install spacer and etc.. So my question is simple:
Will the front wheel scrub during turning with 9.5"? And will the wheel stay within the guard, not protruding out the body?
Thanks a lot.
hlk gts is offline   Reply With Quote
Old 09-04-2013, 02:27 PM   #1759
djdnz
1337
Drives: 2013 BRZ WRB S/C
Originally Posted by hlk gts View Post
Hi Guys,
Thanks a lot.
18x9.5+44 will not fit in the front on stock suspension, absolutely no way. So since you dont want to adjust anything, get the 18x8.5 +44.
In the rear it will be close but likely no major issues.
djdnz is offline   Reply With Quote
Old 09-04-2013, 02:49 PM   #1760
nguyen_er
nguyen_er's Avatar
Drives: 2013 Raven FR-S
There are some wheels on craigslist,
they're 18" Rays Arthur Exchange style-me 18x8 +37 and 18x9 +37 5x114.3
What spacers would I need for it to fit? Would it be flush?
My car isn't lowered at the moment and want to lower it before I put the wheels on it. Should I go with coil overs or get some rce yellows?
Thanks in advance!
oh and the tires are yokohoma s-drives 225/40 and 245/35
nguyen_er is offline   Reply With Quote
Old 09-04-2013, 03:08 PM   #1761
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Thanks in advance!
Wrong bolt pattern (P.C.D.). The 86 is 5x100 NOT 5x114. Otherwise fitment is close to flush.
S-drive are an excellent tire.
Rce or coilovers is your decision. If you don't need coilovers just get springs.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 09-04-2013, 03:48 PM   #1762
nguyen_er
nguyen_er's Avatar
Could I just convert the 5x100 to 5x114.3 using http://www.evasivemotorsports.com/mm...ICS-CONVERSION ? I know some people don't like it because it may put extra stress but I'm not really tracking or anything so..
Old 09-04-2013, 03:57 PM   #1763
djdnz
1337
The adapter is 15mm, your wheels are going to poke big time if you go that route.
Buy wheels that are the right PCD
Old 09-04-2013, 05:40 PM   #1764
nguyen_er
nguyen_er's Avatar
Blah I really want the wheels. Oh well. :/
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
