Old 08-31-2013, 05:58 PM   #1
Narin
Drives: 2010 GTI (Limited BRZ Ordered)
HD radio going in and out?
Is anyone noticing this when listening to FM radio? Basically makes the radio sound terrible because it seems to be switching back and forth between HD and non-HD radio. Has been happening to me quite a bit. Just wondering if this is a known/common issue.
I'm in the North Jersey/NYC metro area BTW.
Sent from my HTC One using Tapatalk 4
Narin is offline   Reply With Quote
Old 09-03-2013, 06:10 PM   #2
BCUZ BXR
BCUZ BXR's Avatar
Drives: 2013 BRZ Limited
I have the same issue in mine. Although, I only listen to one radio station, so I don't know if it is just a weak HD signal as the station is a good 50+ miles away.
BCUZ BXR is offline   Reply With Quote
Old 09-03-2013, 06:21 PM   #3
Pavel
Drives: Raven 2013 Scion FR-S
You can turn off HD radio in setting and just have it in lower quality all the time. The switching from HD to non-HD is due to poor radio reception, not the radio itself.
Sent from my Transformer TF101 using Tapatalk 4
Pavel is offline   Reply With Quote
Old 09-04-2013, 11:24 AM   #4
Stierzy34
:unamused:
Stierzy34's Avatar
Drives: 2005 WRB STi "Edna"
Happens to only one channel in mine. All of the others work fine, so I just don't listen to that one channel anymore
They want my listening ears? Upgrade that signal!
Stierzy34 is offline   Reply With Quote
Old 09-04-2013, 11:50 AM   #5
11RApearl
Drives: Scion FR-S
i had the same problema few days ago. and was wondering if i could turn the hd off. glad to know there is a solution!
11RApearl is offline   Reply With Quote
Old 09-04-2013, 12:03 PM   #6
Narin
Thanks for the replies guys. Ended up turning HD off by default. Good to know it's just a signal issue.
Old 09-04-2013, 12:33 PM   #7
frs10
Drives: tezla
yeah, same thing happens to me also... its just the bad signal issues
frs10 is offline   Reply With Quote
Old 09-04-2013, 12:45 PM   #8
sklimo
Same here. Turned HD off
Old 09-04-2013, 12:50 PM   #9
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I put on a longer antenna. I get much stronger signals now and a lot less switching.
Old 09-02-2016, 08:44 PM   #10
LancePower
Drives: 2020 BRZ tS
I'm experiencing a lot of occurrences of the HD signal dropping out. My #1 station is an HD2 station, so I can't turn off the HD function. No HD, no station.
My previous car also had HD and almost never dropped out.
So I guess there's no factory fix for this? Firmware upgrade or something? I have a 2016 with the shark fin antenna.
LancePower is offline   Reply With Quote
Old 09-02-2016, 11:32 PM   #11
White64Goat
I started a thread a looonnnnggggg time ago about Isn't there a better antenna available and believe me when I tell you I tried a LOT of antennas, different lengths, different materials etc. to no avail. If you can turn off HD that's about the only way to overcome it. I replaced my factory antenna (2013) with a 2015 shark fin just for aesthetics and it's no better than the stock one but it looks better.
Old 09-03-2016, 02:12 AM   #12
LancePower
Drives: 2020 BRZ tS
So is the problem more on the "receiver" end than the "antenna" side of things?
Old 09-03-2016, 03:03 AM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
What fix do you want?
My 2015 Lexus ES has trouble picking up HD signals already, and that'a an almost $50k luxury car.
Old 09-03-2016, 11:57 AM   #14
LancePower
Drives: 2020 BRZ tS
To work as well as a 2012 MINI?
Noticeably low and sharp volume with AM radio stations with stock BRZ radio tracerit Electronics | Audio | NAV | Infotainment 0 07-24-2013 03:38 AM
oem frs radio Jhon19lopez Audio/Visual, Electronics, Infotainment, NAV 0 06-02-2013 02:25 PM
PA/CB radio DIY? Estey DIY (Do-It-Yourself) Guides 5 04-25-2013 09:21 PM
aha radio mechaghost BRZ First-Gen (2012+) — General Topics 1 08-13-2012 12:08 AM
Radio, Iphone?? Radio cuts out when surfing the web Fugazi Electronics | Audio | NAV | Infotainment 5 07-30-2012 12:24 PM
