Old 09-01-2013, 07:30 AM   #1
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Rear toe out after LCA install
My rear toe appears out now after the Cusco LCA install, I am on Tein Flex and already have an alignment scheduled on Friday but it is pulling left and right while driving and I can smell the rubber from the toe out, anyone have suggestions on a fix for now until I take it in?
TL;DR
How to fix rear toe?
Thanks in advance.
The Following User Says Thank You to midnight23 For This Useful Post:
ZDan (09-01-2013)
Old 09-01-2013, 10:00 AM   #2
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Loosen the toe link's adjustment nut and adjust it by turning the bolt head. You'll see obvious changes and just eyeball it. A lot of people are good at eyeing it, but I got to within .06 and .08 on each side just eyeballing it until the following day for real alignment.
I jacked the rear end up and left the wheels on while adjusting to get easier judgement.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following 2 Users Say Thank You to OmarGC For This Useful Post:
DrDuquette (02-21-2014), midnight23 (09-01-2013)
Old 09-01-2013, 03:22 PM   #3
wparsons
wparsons's Avatar
You might need aftermarket toe links with a bigger adjustment range depending on how much you're lowered and your final camber setting. Dialing back camber with a LCA will increase toe out.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Old 09-01-2013, 05:46 PM   #4
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Like Omar stated, and also as mentioned you can look at DMC or Whiteline etc for toe links. If you're past 1.5" toe links would be what you need likely.
The Following User Says Thank You to OICU812 For This Useful Post:
Perrin Rear Shifter Bushing Install F1point4 DIY (Do-It-Yourself) Guides 55 10-21-2021 02:39 PM
Whiteline rear subframe bushing install... fl_speed001 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 07-11-2020 12:29 AM
Rear end clunk after H&R Super Sport Spring Install Taber Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-27-2013 08:40 PM
toe issues after rear control arm install Im_SPEED Tracking / Autocross / HPDE / Drifting 5 04-02-2013 05:18 PM
Prepping for rear spoiler install? zooki Cosmetic Modification (Interior/Exterior/Lighting) 2 09-02-2012 03:56 PM
