Old 04-02-2013, 03:20 PM   #1
Im_SPEED
Drives: FRS hot lava
toe issues after rear control arm install
so i just installed rear control arms to get my rear camber to -2.0 and when i did that the best i could get my toe was -1.90 and this made the car very drifty undriveable i did some tweaking and got it so the toe was positive making the car drive able but now my camber is way to high in the rear. any segestions on what i can do. side note it needs to be ST legal thats why im posting here. as it sits the rear camber is -3.0 and -2.7 toe is .98 and 1.50 both positive. front is good -3.0 both sides and 0 toe i know that the front doesnt effect the rear.
Im_SPEED is offline   Reply With Quote
Old 04-02-2013, 03:36 PM   #2
Dezoris
Dezoris's Avatar
What arms did you swap in (Upper or lower)? Also what was your stock camber and toe settings before?
So here are my immediate thoughts: arms were not specifically designed for the BRZ/FR-S or you got the wrong product. If your camber and toe were very even before I'd blame it on the arms. If your factory camber and toe were off then I would try loosening the rear sub frame (4 bolts).
Old 04-02-2013, 03:42 PM   #3
Im_SPEED
lower control arms. ok well the camber/toe was even before i dont remember exact numbers but it was good. i did have the sub frame out to do rear sub frame bushings. but i marked the frame and the body to make sure i go it close on when i re installed it. btw the car is lowered on coil overs.
Old 04-02-2013, 04:15 PM   #4
Im_SPEED
oh ya one other thing the arms are spc.... yes i know im a cheap ass... but they were what was available with normal bushings at the time..
Old 04-02-2013, 04:39 PM   #5
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Did you buy that optional toe adjustment that SPC sells? Its supposed to help with dialing in the toe.
Ranatsu is offline   Reply With Quote
Old 04-02-2013, 05:18 PM   #6
Im_SPEED
yes i did. im thinking i may just have to mess with the position of the bushing it self because its an off set hole. so if i press it back out and turn it about an 1/8 of a turn away from joint end i may get closer to what i want im just hoping someone has something for me not like pressing out the bushing is hard just tedious.
Issues - Traction control and ABS warning light on G86 Issues | Warranty | Recalls / TSB 109 10-17-2021 04:32 PM
Control arm issues? Turbowned Issues | Warranty | Recalls / TSB 16 05-24-2014 01:21 PM
Ground Control Complete Kit Install and Initial Thoughts Eric1855 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 03-21-2013 10:52 AM
Rear control arms Toyobaru808 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-29-2012 09:23 PM
Rear control arms EN2_Squirrel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 11-07-2012 04:04 PM
