#15 |
Drives: Scion FR-S
Open loop when cold, closed once warmed up. This was my thinking as well. On normal vehicles, there are triggers (various temperature sensors) that'll switch it over. I just remember mad_sb saying that our cars run in open loop way too long I believe. I'm just wondering...if it's running pigrich, it's not taking in the air volume expected. Intake cam angle or throttle open % change, idle to idle?
#16 |
i've observed the switch from open loop to closed loop on cold start. this is the exact moment that the load goes from crazy high (80+%) to normal (20-30%) and the idle settles down. the hunting up and down bit happens in closed loop after the switch.
#17 |
Drives: 85 corolla gts
Can you post a log up from cold start. Curious to see a few things, timing, air fuel ratio, commanded cam timing, as well as trims when it switches over into closed loop.
#18 |
Drives: 2013 White Out FR-S
sounds like someone dinked with a table they didnt have to cause on all the cars ive tuned so far have yet to come across anything like this. sounds also like you maf scaling is off. you should have that much issue dialing in these setups. i spend more time building and adjusting ignition values while fine tuning than anything else.
#19 |
I'm going to gather some in logworks format to share once my ot-2 shows up in a couple days. The ones I have now are from techstream. I can send them to you to review if you have the software.
#20 |
this may be completely incorrect, but maybe something is possibly making your car go through a throttle body relearn procedure every time you start the car? I know this is a common issue with DBW toyotas after changing the battery.
| The Following User Says Thank You to 1stGenBRZ86 For This Useful Post: | jamesm (09-01-2013) |
#21 |
When you refer to "load", what are you talking about here? I'm still learning about our fuel injection systems. I still don't know what "trims" are either.
#22 | |
At very high rpm with the throttle barely open there is very low load. At low rpm, wide open throttle load is very high. Think of it as a measurement of how much work you're asking the engine to do. Trims are offsets that the ecu applies to the base fuel tables based on sensor feedback. These are 'learned' or cached over time. High trims are bad. |
#23 |
So how is there any load at idle? You said your load goes from high/80% to low when the idle settles. Trying to grasp/visualize this.
Thanks for explaining. |
#24 | |
OEDC
Drives: Vortech 8.5psi 274WHP 2013 BRZ
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there. please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback |
#25 |
That guy
Drives: Ultramarine mt FR-S
Maybe it's something tied to the warm up phase. I'm guessing you're on pump not 85?
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#26 |
I believe the load is so high because its holding the throttle plate open to stay idling at such a rich afr. It smokes during this period as well.
#27 |
#28 |
That guy
@JuniorAWD any thoughts?
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) Last edited by Hawaiian; 09-02-2013 at 02:34 PM. |
| Treadstone Performance Turbo Kit Update! | kmbkk | Forced Induction | 277 | 01-16-2020 11:15 PM |
| BRZ + Supercharger = ??? 1/4 mile | girlracer | Forced Induction | 38 | 09-11-2014 11:28 AM |
| Turbo Market and Technology Update | circuithero | Forced Induction | 9 | 06-26-2013 08:27 AM |
| 10,000 mile update | jeebus | BRZ First-Gen (2012+) — General Topics | 23 | 05-28-2013 06:59 PM |
| YES! AWD Turbo BRZ in the works for sure!!! | ngabdala | BRZ First-Gen (2012+) — General Topics | 155 | 06-25-2012 09:15 AM |
