Old 08-31-2013, 02:58 PM   #1625
Pug
Atoning Unifex
Pug's Avatar
Drives: '13 BRZ Premium, WR Blue
Total time to install, alone, with photographs: 2 hours 12 minutes. I'm going to start the car in about 10 minutes after replenishing electrolytes!
Sent from my DROID RAZR HD using Tapatalk 2
Pug is offline   Reply With Quote
The Following 3 Users Say Thank You to Pug For This Useful Post:
BlueDubbinTDI (08-31-2013), DAEMANO (08-31-2013), SpyderMS (08-31-2013)
Old 08-31-2013, 03:04 PM   #1626
SpyderMS
SpyderMS's Avatar
Drives: 2014 BRZ - Crystal Black Silica
One thing I've yet to see mentioned is that aside from how well this thing works, it happens to look fantastic in the engine bay as well
SpyderMS is offline   Reply With Quote
The Following User Says Thank You to SpyderMS For This Useful Post:
Old 08-31-2013, 04:28 PM   #1627
Pug
Atoning Unifex
Pug's Avatar
I've uploaded pictures from the installation to an album...
Installation Album
bfrank1972 (08-31-2013), DAEMANO (08-31-2013), Gary in NJ (08-31-2013)
Old 08-31-2013, 04:43 PM   #1628
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Installation Album
Do you have any driving impressions yet?
Old 08-31-2013, 04:45 PM   #1629
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Great photos. I'm looking forward to the drive review.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 08-31-2013, 06:57 PM   #1630
Pug
Atoning Unifex
Pug's Avatar
Smile
The first drive I took felt awesome. I've got to get ready for evening events now which will involve some freeway driving, so I'll post more later.
A couple notes:
  • I used the stock tune
  • Even waiting until 4k RPM before punching it, I threw a CEL at 5k RPM on the first try
  • I repeatedly chirped the tires on my 2-3 shifts... that's never happened before
  • It felt like a new car!
  • Rob's done something amazing
The Following 8 Users Say Thank You to Pug For This Useful Post:
asher187 (08-31-2013), bfrank1972 (08-31-2013), BlueDubbinTDI (08-31-2013), DAEMANO (08-31-2013), fenton (08-31-2013), radroach (09-01-2013), RIPTRD71 (09-01-2013), SloS14 (08-31-2013)
Old 08-31-2013, 07:51 PM   #1631
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
A couple notes:
The cel at 4k, are you guys running the 3bar sensor or the stock 1.5? Just a random question.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 08-31-2013, 08:12 PM   #1632
Pug
Atoning Unifex
Pug's Avatar
@Adeets : It's the stock 1.5bar sensor.
Something that's been kicking around for a while is to limit the voltage on the existing sensor so that the engine doesn't read an over-pressure condition.
Theoretically that should be doable as an analog clamp using a zener diode and a properly-sized resistor.
I don't know what the correct voltages are, but if we assume that the max MAP voltage we want to see is 3.8V, but under compression we sometimes exceed it, then using a 1N4730A diode with a 4.7kΩ resistor would clamp the voltage to 3.79V.
With that circuit [link to CircuitLab for playing], response is ideally linear until about 3.7V, when it levels off.
So a few questions:
  • Does anyone know where we could get matching wiring harnesses for the MAP sensor? We'd want one female and one male
  • Does anyone have handy what voltage would equal 1.00-1.05 BAR on the stock MAP sensor?
  • What could go horribly, horribly wrong?
Old 08-31-2013, 08:39 PM   #1633
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
good place to look: http://www.te.com/catalog/connectors/menu/en/17560
Old 08-31-2013, 08:59 PM   #1634
fenton
A couple notes:
If you are tripping the sensor then you are certainly making some good boost. Mine would never flip above 5k. Mostly when I went wot at 3 to 4k in 3rd or above.
Sent from my HTC One using Tapatalk 4
fenton is offline   Reply With Quote
Old 08-31-2013, 10:16 PM   #1635
DJCarbine
Thupercharged
DJCarbine's Avatar
So a few questions:
My friends supercharged NSX has a voltage clamp on the MAP sensor activated by a boost switch. As soon as the manifold reads positive pressure, the switch trips and only allows a certain max voltage to be fed to the ECU.
I would say go for it! DIY map voltage clamps are not unheard of and people usually use a diode/pot to dial them in
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 08-31-2013, 10:17 PM   #1636
Thatruth2001
Drives: Raven FR-S
Tuning is done. Bob and Bill from drift office will provide the review. Ecutek owners you are now tuned.
Bill and Bob I cannot say thank you enough for the time and effort spent with the ESC today. I learned so much and appreciated the frankness of the discussion. Btw the drive home was amazing and the tune met all my expectations. I look forward to coming up again to work with a class act pair of tuners like yourselves.
Look forward to seeing your thoughs in the coming days.
Thatruth2001 is offline   Reply With Quote
The Following 5 Users Say Thank You to Thatruth2001 For This Useful Post:
Bu-Tang (09-01-2013), Calum (08-31-2013), DAEMANO (09-01-2013), Drift-Office (09-02-2013), fenton (08-31-2013)
Old 08-31-2013, 10:19 PM   #1637
fenton
So can you feed us before and after numbers??? Is Bob going to reply here?
The Following 2 Users Say Thank You to fenton For This Useful Post:
Old 08-31-2013, 10:56 PM   #1638
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
Nice!!! This is working out very nice!
I love innovation.
Toma is offline   Reply With Quote
The Following User Says Thank You to Toma For This Useful Post:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
