Old 08-31-2013, 07:09 PM   #1
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
how do i remove the trunk garnish?
how do i remove the trunk garnish? i want to remove it so i can wrap it in vinyl. i would like to know how to remove the subaru badge as well.
thanks
NYCsubaruBRZ is offline   Reply With Quote
Old 08-31-2013, 07:45 PM   #2
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
thanks
Remove the Subaru badge!?!? Blasphemy!!!! You sir, have a special place in hell waiting for you...
But in all honesty I thought the emblems are all on via tape, so heat them up, and the interior is held on by pins inside....
Touch that Subaru emblem and your still going to hell though.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
The Following User Says Thank You to Adeets For This Useful Post:
NYCsubaruBRZ (08-31-2013)
Old 08-31-2013, 07:53 PM   #3
NYCsubaruBRZ
k that dont really help me much....
i have the interior clips out and the bolts r exposed now... i took off 5 nuts with a 8mm socket now what?
Old 08-31-2013, 07:53 PM   #4
NYCsubaruBRZ
im already goin to hell lol
Old 08-31-2013, 07:54 PM   #5
NYCsubaruBRZ
it didnt even loosen up the garnish
Old 08-31-2013, 07:54 PM   #6
NYCsubaruBRZ
should i snap a pic?
thanks for the help
Old 08-31-2013, 08:13 PM   #7
Adeets
OEDC
Adeets's Avatar
thanks for the help
Are you talking the inside crap or the piece that fits into the slot right under the top of the trunk on the outside....
Shit some how I got my trunk stuck closed.
My BRZ FI Build
Old 08-31-2013, 08:23 PM   #8
NYCsubaruBRZ
this on the exterior
Old 08-31-2013, 08:26 PM   #9
NYCsubaruBRZ
the piece that fits into the slot right under the top of the trunk and above the license plate
i need to remove that so i can vinly wrap it
Old 08-31-2013, 08:42 PM   #10
Adeets
OEDC
Adeets's Avatar
Search "trunk stuck" while looking for my solution I think I saw a DIY on how to remove that and the 3rd brake light.
My BRZ FI Build
Old 08-31-2013, 10:22 PM   #11
NYCsubaruBRZ
got it.... remove interior pannel about 7 clips.
then use an 8mm socket to remove 5 nuts.
then pinch plastic clip on the left and pop it off. you might have to shake it lightly to get it loose.
now its off.
to remove the badge heat it with a hair dryer and use a credit card to pop it off
done!!!!!!
i will post pics when i vinyl wrap it and re-install it
Old 09-09-2013, 06:29 PM   #12
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
now its off.
done!!!!!!
can you post picture of how you remove the trunk stuck???
Old 09-09-2013, 06:58 PM   #13
NYCsubaruBRZ
not sure what u mean
Old 09-09-2013, 07:11 PM   #14
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
NVM. I figure out..i was asking how you remove the trunk garnish, because I want to plastidip that piece too...
DIY REQUEST: How to remove the fender garnish/vents? shishand DIY (Do-It-Yourself) Guides 37 09-11-2015 06:21 PM
Carbon Trunk Emblem Cover Garnish davidchoi BRZ First-Gen (2012+) — General Topics 8 01-06-2015 02:51 AM
Carbon Fiber Trunk Garnish & Fender Inserts GuerillaRacing Cosmetic Modification (Interior/Exterior/Lighting) 50 06-26-2013 12:03 PM
Trunk Garnish Wesley Cosmetic Modification (Interior/Exterior/Lighting) 21 06-05-2013 11:49 AM
Scion FRS Trunk Garnish wishlist item request midnightfrolic Exterior Parts (Aero, Lighting, Etc.) 0 11-30-2012 01:59 AM
