Old 08-29-2013, 05:15 PM   #813
Chase Bays
Chase Bays's Avatar
Drives: FR-S | 335i | S13
Originally Posted by charged86 View Post
you will have to using caution doing this technique if you pull on the solenoid under the manifold it is possible to pull off where the vacum comes out of the manifold. and ya might as well use a hose clamp if you are able to get ahold of it any way
It's possible either way, but yes. I'm sure everyone double checks their work before reinstalling. Hopefully.
Chase Bays is offline   Reply With Quote
Old 08-29-2013, 05:38 PM   #814
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
dont pull on it, there is a gasket that seals it, ruin the gasket seal and you can end up with a leak, that you then have to dab rtv on
ask me how I know..
you guys are making this harder than it needs to be
reacharound method works with kinky assed pliers and shit
the screwdriver holes from factory I refer to are what you see looking down between the two legs of spider on manifoldm they small, but again, you will be using a small clamp
I will see I can make a video if you need me to
448hpsti is offline   Reply With Quote
The Following 3 Users Say Thank You to 448hpsti For This Useful Post:
civicdrivr (08-29-2013), M1K3 (08-29-2013), Sportsguy83 (08-30-2013)
Old 08-29-2013, 06:03 PM   #815
M1K3
M1K3's Avatar
Drives: vrooom...
Yes Please!!!
M1K3 is offline   Reply With Quote
Old 08-29-2013, 06:12 PM   #816
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Dezoris View Post
You want to avoiding pulling the manifold for numerous reasons.
1. You need replacement, intake manifold gaskets, and throttle body gaskets.
2. You need backup o rings for the port injectors they sheer off/crack easily.
3. You have to remove the injector driver, and plates from both sides of the fuel rails.
4. If its your first time removing it, plan on 3+ hours.
1. If you ruin your intake manifold gaskets in the process, you are doing something wrong. The throttle body does not need to be removed from the manifold.
2. They might have sheered off and cracked for you, but I have had no issues with mine.
3. Anyone that has installed injectors should be more than capable of removing those on both sides. Sure a few of the bolts are difficult to remove, but get used to it.
4. It was my first time, and it took under an hour.
5. YRMV
Old 08-29-2013, 07:02 PM   #817
Dezoris
Dezoris's Avatar
5. YRMV
Seriously man? Let me translate the crap you just posted.
1. Don't worry if your intake manifold no longer maintains a quality seal after and ignore the service manual. In some odd chance your seal is compromised just order an intake manifold gasket and do the procedure all over again. Boost leak is no biggy.
2. It's impossible to sheer an o-ring or crack one and have a fuel leak. In some odd chance that happens the fuel spray is normal. Just turn off your car and park it. Lead time to get o-rings from the dealer is about 14 days. Again ignore the service manual. And don't bother replacing them.
3. Almost everyone has pulled injectors and pulled the manifold before, on multiple cars. Don't worry about the 20 bolts and some that are hard to access, or pulling fuel rails and doing fuel system precautions that's not needed.
4. With all these helpful tips you should have all this done in the street or with minimal tools in 30 minutes.
The Following User Says Thank You to Dezoris For This Useful Post:
sw20kosh (08-31-2013)
Old 08-30-2013, 12:16 AM   #818
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You live in a world of Turbowski and factory service manuals. I live in the real world where orange intake manifold O rings don't need to be replaced on cars less than 2 years old. This isn't a warranty repair where they replace everything and charge Toyota/Subaru or the customer. You can do it your way, and I will do it my way.
By the way, when I removed the intake manifold, I left the fuel rails and injectors in place so there is no worry about the injector O rings. You simply disconnect the fuel lines from the rails on both sides.
Old 08-30-2013, 10:38 AM   #819
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Either way is fine, just gitrdone
Old 08-30-2013, 10:45 AM   #820
nelsmar
Finally going to try to do mine tomorrow... It would be nice to be able to get on it without worrying about that hose falling off every time i spool up lol.
My flickr - Canibeat
Local magazine scout
Old 08-31-2013, 01:05 PM   #821
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
How did it go?
Old 08-31-2013, 03:32 PM   #822
charged86
charged86's Avatar
cheap vortech mod to get the crackcase hot air and oil out of intake box make sure the inlet that is marked on oil separator (from Lowes) is being fed from the crankcase hose and the arrow is pointing towards the filter (from autozone) don't for get to cap the port on the intake box
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post:
skatery1989 (08-31-2013)
Old 09-03-2013, 05:34 PM   #823
Chase Bays
Chase Bays's Avatar
Or just run a hose to the ground so we can pollute the earth and then get oil on our tires causing us to spin out while going 100 causing us to flip 40 times and then die.
Old 09-04-2013, 08:47 AM   #824
charged86
charged86's Avatar
or put the hose directly on the front right caliper
pheoxs (09-04-2013)
Old 09-04-2013, 09:37 AM   #825
swift996
swift996's Avatar
What kind of IATs are you guys seeing at 8.5psi and 12psi?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 09-04-2013, 09:40 AM   #826
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Put it infront of the tire and do sick drift bro!
Nolan
pheoxs is offline   Reply With Quote
The Following User Says Thank You to pheoxs For This Useful Post:
charged86 (09-04-2013)
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
