Old 08-31-2013, 11:01 AM   #99
Racecomp Engineering
There is no magic number! No magic. Just physics and compromises. 15 mm is "safe" but it isn't magic.
I just don't like seeing the word magic in suspension discussion.
- Andy (posting from the airport)
Old 08-31-2013, 11:15 AM   #100
37
degrees
37's Avatar
Drives: 6MT BRZ
A single adjustable or even non-adjustable shock honestly can be almost as good if they are valved right from the start.
On that point, how are the Tarmac Zeroes valved compared to stock? The stock seems bouncy to me and I'd love to add some rebound damping and gain inner wheel clearance. If I don't go with the R&T, the T0 is my next step down. If the T0 gets me 90% there for 1/3rd the price then it gives me back some money for brakes.
The car is 98% street, 2% track day. My schedule doesn't allow me much track time these days.
JIC Magic.
37 is offline   Reply With Quote
Old 08-31-2013, 12:08 PM   #101
Much more damping than stock. 98% street sounds like a good fit.
JIC Magic.
My least favorite kind of magic.
- Andy
Old 08-31-2013, 12:56 PM   #102
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Dezoris View Post
I have been on sticky 225 and 235 RS3 with -1.5 up front on stock suspension and even heavy autocross I can correct wear with pressures.
Were you able to avoid the tires from rolling over? what pressures were you running? I found that anything over 37-38 PSI hot on the RS3's grip feels compromised. at 40PSI hot, it felt really squirrely when I was at buttonwillow.
Old 08-31-2013, 01:12 PM   #103
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Seems high for pressures
448hpsti is offline   Reply With Quote
Old 08-31-2013, 01:25 PM   #104
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by BRZ NA View Post
How about 1.25" to 1.5" drop? will it lost bump travel? so what's the Max can u lowered so that it won't need to regain lost of bump travel?
This... I've wondered this as well if using for example ground control top hats front and robi specs back plates would that have any benifit for those that are only going an inch to inch quarter to inch and half drop very tops. Where would those kinda of stroke adding products really benifit at what drop should a person even worry or consider such items like this to improve their suspension??
Old 08-31-2013, 01:26 PM   #105
solidONE
solidONE's Avatar
RS3 have soft sidewalls. I settled on 36psi hot all around in the later sessions. With about only -1.5 of camber at stock height they were rolling over the shoulders of the tires pretty good. Nemo camber...
Old 08-31-2013, 02:18 PM   #106
CSG Mike
CSG Mike's Avatar
Whatever distance you drop is the amount of bump travel you lose. If you want to retain all factory bump travel, you need to retain factory ride height.
Old 08-31-2013, 02:21 PM   #107
CSG Mike
CSG Mike's Avatar
Originally Posted by whataboutbob View Post
I was just thinking about how it might be useful to characterize the camber/toe changes that result from various levels of suspension compression. Thoughts?
I believe bump steer was measured, although I don't remember the thread.
The front effectively has no toe change, while the rear gains about 1/16" in toe-in per side per inch dropped (and toes out about 1/16" per inch raised), if I remember the figures correctly.
Old 08-31-2013, 02:22 PM   #108
CSG Mike
CSG Mike's Avatar
Originally Posted by ultra View Post
Also curious to know whether being able to have more than 2degrees of camber up front will increase front grip on street tires (driven on street, autoX & track).
It sure will.
We run -3 based on pyrometer and wear patterns with 225 street tires. However, YMMV, depending on your setup.
Old 08-31-2013, 02:23 PM   #109
CSG Mike
CSG Mike's Avatar
So 15mm drop is this magic number thrown around where did this come from? Is that the farthest you can go on stock suspension geometry without negative effects?
Any drop will have negative effects, with compounding results for a larger drop. Generally, static RCA products typically start for 30mm drops, although it varies by platform.
Our car runs about 35mm drop without any geometry correction, but we also run fairly high spring rates. (10k/12k, and 12k/15k at times)
Old 08-31-2013, 02:23 PM   #110
dabocx
dabocx's Avatar
Drives: Scion FRS
The Stance ones are interesting to me but I have not tried them. Off the top of my head for a given ride height you would get more bump travel and less droop travel. Overall a good thing.
- Andy
Whats are the negatives to those LCAs?
dabocx is offline   Reply With Quote
Old 08-31-2013, 02:24 PM   #111
CSG Mike
CSG Mike's Avatar
Pressures are best adjust via pyrometer readings. As @solidONE stated, RS3s tend to like higher pressures.
Old 08-31-2013, 02:43 PM   #112
whataboutbob
AutoX-10/10ths every run
Any info on camber?
Build thread:Here
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
