Old 08-28-2013, 10:48 PM   #141
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Originally Posted by nix View Post
No problems here. RPM does drop more now with the lighter flywheel but just feather it back. The car is light enough not to need any handbrake except for things like concrete car parks.
I have stalled out 3 times since i put in my new clutch.
First was pulling out of my driveway upon first drive, was not use to the catch point yet. Second and third was a steep hill stopped at a light. same place, 2 different times, just need to get use to giving it a bit more gas.
gdrider77 is offline   Reply With Quote
Old 08-30-2013, 10:38 AM   #142
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
No. The clutch works the same as the OEM one while shifting with no weird noises. The only time it feels different is when launching it in first gear.
this noise got louder today.
what can it be lol
[ame="http://www.youtube.com/watch?v=WTIemYP9zxc"]Weird Clutch noise - YouTube[/ame]
Old 08-30-2013, 10:58 AM   #143
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
That sounds annoying
Old 08-30-2013, 11:01 AM   #144
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
that was a good help lol
Old 08-30-2013, 11:53 AM   #145
SmsAlSuwaidi
Boosted
Lol sorry
I think it has something to do with your bearings
Old 08-30-2013, 12:14 PM   #146
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Lol sorry
throw out bearing?
Old 08-30-2013, 12:33 PM   #147
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Throw out bearing and not enough lube would be my guess. Have you done any adjusting of the clutch pedal like in the DIY section? Is there a chance the squeak is coming from a rubber bushing or something in the pedal assembly?
Old 08-30-2013, 10:06 PM   #148
Fabron757
Drives: 2013 blue frs m6 BW EFR 7064 Turbo
I use the fx400.
Fabron757 is offline   Reply With Quote
Old 08-30-2013, 10:08 PM   #149
Frs300
Frs300's Avatar
Drives: Pile of junk
Originally Posted by Fabron757 View Post
I use the fx400.
i use fx400 as well but i might need to upgrade or throttle back on the hp
Frs300 is offline   Reply With Quote
Old 09-03-2013, 01:15 AM   #150
pmccut
Drives: Blue Subarus
Originally Posted by gdrider77 View Post
At this rate, i have almost broke it in, so i will just run with it for now, and see how it does, as mentioned, guinea pig here, luckily was not too expensive, more the time to install it and the excruciating time to break it in....ugh.
I'm hating mine so much I might just pick up the exedy and use it till it breaks. I had a friend try it - same thoughts. Feels like a race clutch. Need to give it 3-4k rpms to get a smooth launch or it jerks. I'm going to give ptuning a call tomorrow and ask..
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 09-03-2013, 09:57 AM   #151
jamesm
the ACT full face is pretty easy to drive, engagement is nice and the pedal feels better than stock, but damn is it noisy. gotta take the good with the bad, i guess...
Old 09-03-2013, 12:50 PM   #152
xxscaxx
Drives: 2013 SWP BRZ
what weight flywheel did you go with, the 11.8 or 10.5?
xxscaxx is offline   Reply With Quote
Old 09-03-2013, 01:19 PM   #153
lexusb3
Drives: FRS
@whitefrs ANOTHER PROBLEM man please just stop lol jk jk i think you should trade in your frs for a 2014 or 15 frs and start over lol need part numbers for throwout b. SU333_00802
lexusb3 is offline   Reply With Quote
The Following User Says Thank You to lexusb3 For This Useful Post:
pmccut (09-03-2013)
Old 09-03-2013, 02:59 PM   #154
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
-_-
I know dude
Maybe grease on pedal?
Sent from my iPhone using Tapatalk - now Free
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
