Old 08-27-2013, 12:11 PM   #365
WithNolock
Drives: Scion FR-S
Below are my results. Torque curve looks super flat for an NA dyno...just wish there was more of it! I might go back once I install my over and front pipe and see what kind of difference that makes.
Mods:
aFe Takeda intake
Perrin pulley
JDL UEL header
stock over and front pipe
Agency Power catback
e85 fa20 tune
WithNolock is offline   Reply With Quote
Old 08-27-2013, 12:20 PM   #366
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
oh wow, completely removed the torque dip-- I bet power delivery in-car is badass now.
However, Keith took me for a ride in his car and its ruined my perception of an N/A FRS forever now.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 08-27-2013, 12:31 PM   #367
nelsmar
Yeah.... that pretty much kills the car for ya lol
My flickr - Canibeat
Local magazine scout
Old 08-27-2013, 01:53 PM   #368
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by nelsmar View Post
It will be interesting to see how efficent the Innovate is when there is an intercooler on it and a smaller pulley. As of current there is not much floating around for charts on that charger to see where exactly we are in the efficiency zone.
All in all both products are wonderful. I love both kits for what it is. If you want lots of power the vortech just tears it up and is available right now. in the US we do not have intercooler setups for the Innovate as of yet. Also the vortech can be upgraded (but if your concerned with high power you may want to look into a turbo instead).
I have first hand snapped my belt, the night of the dyno event. It was horrible. It destroyed multiple pulleys and we are still not 100% sure the cause. It was likely due to the smaller pulley & the original belt supplied by vortech being too large for the small pulley. We have since switched it and are testing.
I think me and keith are both pleased with the superchargers we chose for our different desires. I would definitely do a vortech my self again and i think Keith would likely stay innovate if he did it again as well. At least... as of this week now that we had @FA20Club.com fly down and tune these cars for us. It was night and day difference on that innovate after it was tuned by Toni.
We will post a comparison with more info once we get the other plots & possibly do further testing.
As Marin said, I am very happy with the way the car feels now on e85. For those wanting this kit down here in the AZ heat, you will need e85 or the intercooled version to run pump sufficiently. The piss poor 91/e10 California gas we get is not enough for this unit on the car. Once the intercooler is released I will be one of the first to have it on. My next upgrades for this kit will be an oil cooler and possible 70mm pulley. I would like to gauge the differences my car will make with these before the intercooler upgrade. I will be posting dyno charts as these go on in the next few weeks. It will give everyone a better comparison of the two kits. At this point it is not a fair comparison on the two kits as he is on a higher boost pulley than I am. He makes about 5-6psi more. Once I get the pulley and cooling our comparison will continue.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 08-27-2013, 05:11 PM   #369
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Iirc 95.5 inches on my 2.87 pulley?
kiichiro is offline   Reply With Quote
Old 08-27-2013, 10:44 PM   #370
Bonks86
Drives: Gt-86
Did we ever get a baseline off a manual?
Sent from a Motorola DynaTAC 8000X
Yes? No?
Bonks86 is offline   Reply With Quote
Old 08-28-2013, 11:53 AM   #371
nelsmar
Yeah... I need to pop that 3.48 pulley back on and re-run with E85 now that im almost back to 85% ethenol. I mostly posted for the fact your torque is so much significantly higher than mine even with the high boost pulley i have installed. Its quite nice.
Hmm not sure, i am on a 3.125 with non-standard sized idlers now. =/
Originally Posted by Bonks86 View Post
Yes? No?
Auto only =/ i need to get us a manual down there at some point soon. Maybe when i go in to re-plot my E85 for crank horsepower. I know a few of us still need to go in and finish tuning.
Old 08-28-2013, 01:24 PM   #372
mattles
Proud of FR Layout
mattles's Avatar
if I dont have to pay for the run, you can toss my car up on the dyno to get a baseline, itll take me like 5min to swap the OEM intake (with OEM filter).
Old 08-29-2013, 02:59 PM   #373
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Intercooled innovate. You should be able to get it if not in the US. We're the only ones screwed by this. Install of the non-intercooled one took 3-4 hours, maintenance is pretty easy and it looks pretty OEM. It's not the fastest thing in the world, but there's a ton of torque and power down low and across the midrange where you use it 95% of the time.
Sent from...somewhere?
Just received notice, we have the Intercooled version arriving in SA within the month.
So you say the IC Innovate will be better than the Vortech?
Ryan86 is offline   Reply With Quote
Old 08-29-2013, 03:11 PM   #374
evo4g63
evo4g63's Avatar
Better? Idk about it being better. It will def be a better "comparison"of the two kits once the IC version is available. Both kits run great in different ways once fine tuned
-2016 Subaru WRX
Old 08-29-2013, 04:39 PM   #375
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
It would be better than the non-IC version of the Innovate/Sprintex kit.
Old 08-30-2013, 02:34 PM   #376
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Took a look at both cars. Brents was leaking due to heat cycles. Theses need to be re torqued after a heat cycle. I pulled the header off and checked the flanges. Bother were straight. I re installed it, got it hot, re torqued the header, and added some sea foam to ensure we had no leaks. Car is leak free now
The other car def had an issue and im correcting that now. It would be nice if we didnt get throw us under the bus as soon as there was an issue. We are here to help you guys so dont hesitate to ask
We recommend starting with the single bolt and then torque the outer 2. Also stainless steel expands and contracts with heat cycles so it would be a good idea to check on them from time to time
JDLAutoDesign is offline   Reply With Quote
Old 08-30-2013, 02:48 PM   #377
nelsmar
Better? Well that depends on what you consider better...
I dont know what the cooling system is like on the innovate but the non-intercooled edition is much easier to install than the vortech (though you do have to remove fuel components so as long as you are comfortable). And removing the belt is much simpler. The oil is harder to change, but you do it much less often than the vortech, which i like.
Vortech has been around longer, and has a long reputation and stands by their products. I feel their kit is much more complicated to install.
However when it comes to power delivery? As we don't have access to an intercooled edition in the US yet we cannot test, but we will likely be running comparison tests once they start to pop up. As for non intercooled? The vortech has a nicer pull on the top end. I made a good 25% more horse power at peak than the innovate guys (I am waiting on this dyno from the shop to show). However the torque was lower. So when it came down to higher rev's and acceleration the vortech was better. But when it came out to balanced torque distribution the innovate wins. It is your choice as to which you want.
Also note the vortech has a decent amount of headroom. I am not even maxing mine out revolution wise and I dyno'd almost 50% higher peak power than the innovate (which was not maxed out, but afaik it doesn't have too much headroom above that).
I love both the kits, and feel they both have their place. If you have access to E85 then that is another bonus, the innovate ran great after we pumped e85 into the system.
Old 08-30-2013, 02:49 PM   #378
nelsmar
@JDLAutoDesign glad to see it wasn't a huge deal! Now we need to find some time to re-dyno
idontwannatalkaboutit
OFFICIAL ARIZONA AREA REGISTISTRY jeffsides Arizona 206 11-08-2021 09:28 AM
Looking for a Tune(r) in Phoenix area Chase86 Southwest 18 06-06-2013 09:05 PM
STREETRACING WEEKEND AT KILLARNEY: SAT 23RD & SUN 24TH FEBRUARY 2013 Razzle AFRICA 3 02-26-2013 05:36 PM
March 23rd and 24th PDX, HPDE at Barber Motorsports Park naikaidriver Southeast 2 02-13-2013 01:12 PM
Anyone in the Phoenix area evo4g63 Southwest 0 02-06-2013 11:19 AM
