#365 |
Drives: Scion FR-S
Below are my results. Torque curve looks super flat for an NA dyno...just wish there was more of it! I might go back once I install my over and front pipe and see what kind of difference that makes.
Mods: aFe Takeda intake Perrin pulley JDL UEL header stock over and front pipe Agency Power catback e85 fa20 tune |
| The Following User Says Thank You to WithNolock For This Useful Post: | mattles (08-27-2013) |
#366 |
Proud of FR Layout
Drives: 2013 Scion FR-S 6MT
oh wow, completely removed the torque dip-- I bet power delivery in-car is badass now.
However, Keith took me for a ride in his car and its ruined my perception of an N/A FRS forever now. |
| The Following User Says Thank You to mattles For This Useful Post: | evo4g63 (08-27-2013) |
#367 |
Yeah.... that pretty much kills the car for ya lol
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#368 | |
Drives: 2016 Subaru WRX
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD Last edited by evo4g63; 08-27-2013 at 02:12 PM. |
| The Following User Says Thank You to evo4g63 For This Useful Post: | Ryan86 (08-27-2013) |
#369 | |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
#370 |
Drives: Gt-86
#371 | |
Hmm not sure, i am on a 3.125 with non-standard sized idlers now. =/ Auto only =/ i need to get us a manual down there at some point soon. Maybe when i go in to re-plot my E85 for crank horsepower. I know a few of us still need to go in and finish tuning.
#372 |
Proud of FR Layout
if I dont have to pay for the run, you can toss my car up on the dyno to get a baseline, itll take me like 5min to swap the OEM intake (with OEM filter).
| The Following User Says Thank You to mattles For This Useful Post: | Bonks86 (08-28-2013) |
#373 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
So you say the IC Innovate will be better than the Vortech? |
#374 |
Better? Idk about it being better. It will def be a better "comparison"of the two kits once the IC version is available. Both kits run great in different ways once fine tuned
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
#375 |
Drives: 2013 Firestorm FR-S
#376 |
Drives: 13 FRS
Took a look at both cars. Brents was leaking due to heat cycles. Theses need to be re torqued after a heat cycle. I pulled the header off and checked the flanges. Bother were straight. I re installed it, got it hot, re torqued the header, and added some sea foam to ensure we had no leaks. Car is leak free now
The other car def had an issue and im correcting that now. It would be nice if we didnt get throw us under the bus as soon as there was an issue. We are here to help you guys so dont hesitate to ask We recommend starting with the single bolt and then torque the outer 2. Also stainless steel expands and contracts with heat cycles so it would be a good idea to check on them from time to time ![]() ![]() ![]() ![]()
#377 | ||
I dont know what the cooling system is like on the innovate but the non-intercooled edition is much easier to install than the vortech (though you do have to remove fuel components so as long as you are comfortable). And removing the belt is much simpler. The oil is harder to change, but you do it much less often than the vortech, which i like. Vortech has been around longer, and has a long reputation and stands by their products. I feel their kit is much more complicated to install. However when it comes to power delivery? As we don't have access to an intercooled edition in the US yet we cannot test, but we will likely be running comparison tests once they start to pop up. As for non intercooled? The vortech has a nicer pull on the top end. I made a good 25% more horse power at peak than the innovate guys (I am waiting on this dyno from the shop to show). However the torque was lower. So when it came down to higher rev's and acceleration the vortech was better. But when it came out to balanced torque distribution the innovate wins. It is your choice as to which you want. Also note the vortech has a decent amount of headroom. I am not even maxing mine out revolution wise and I dyno'd almost 50% higher peak power than the innovate (which was not maxed out, but afaik it doesn't have too much headroom above that). I love both the kits, and feel they both have their place. If you have access to E85 then that is another bonus, the innovate ran great after we pumped e85 into the system.
#378 |
@JDLAutoDesign glad to see it wasn't a huge deal! Now we need to find some time to re-dyno
| The Following User Says Thank You to nelsmar For This Useful Post: | JDLAutoDesign (08-30-2013) |
| Tags |
| idontwannatalkaboutit |
| OFFICIAL ARIZONA AREA REGISTISTRY | jeffsides | Arizona | 206 | 11-08-2021 09:28 AM |
| Looking for a Tune(r) in Phoenix area | Chase86 | Southwest | 18 | 06-06-2013 09:05 PM |
| STREETRACING WEEKEND AT KILLARNEY: SAT 23RD & SUN 24TH FEBRUARY 2013 | Razzle | AFRICA | 3 | 02-26-2013 05:36 PM |
| March 23rd and 24th PDX, HPDE at Barber Motorsports Park | naikaidriver | Southeast | 2 | 02-13-2013 01:12 PM |
| Anyone in the Phoenix area | evo4g63 | Southwest | 0 | 02-06-2013 11:19 AM |
