Old 08-30-2013, 11:24 AM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by charged86 View Post
I got that trying to see if the frs clutch part number is the same as other Subaru clutch part numbers. hopefully saving us money due to popularity of our platform
FRS/BRZ is part number SU333, Impreza is SU303.
Old 08-30-2013, 11:28 AM   #16
charged86
charged86's Avatar
noticed that so frs brz is SU33xx and imprezza is su30xx hmm strike out there but I was getting really excited!
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post:
Sportsguy83 (08-30-2013)
Old 08-30-2013, 11:33 AM   #17
charged86
charged86's Avatar
Act part numbers match SB5-HDG6 is same clutch for 06-07 Subaru wrx and the frs
Old 08-30-2013, 11:35 AM   #18
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
The transmission is different, and most of all the flywheel side is VERY different which everything bolts to.
I do not show the SB5-HDG6 working for the FRS/BRZ.
FT-86 SpeedFactory is offline   Reply With Quote
Old 08-30-2013, 11:36 AM   #19
charged86
charged86's Avatar
http://www.ebay.com/itm/ACT-HEAVY-DU...6a0f00&vxp=mtr
http://ft86speedfactory.com/act-6-pu...eight-593.html
its the SB5 is for Subaru wrx and the SB8 is for the frs brz
not trying to insult or pull a fast one on anybody
Old 08-30-2013, 11:37 AM   #20
FT-86 SpeedFactory
One is an SB5 and the one for us is an SB8
Plus the one for our cars is cheaper and comes with a flywheel while the WRX is more money and does not come with a flywheel.
Old 08-30-2013, 11:38 AM   #21
Sportsguy83
Drives: Limited BRZ
Regardless of part numbers, these are completely different transmissions. Other Subarus do not use Aisin transmissions, are AWD, etc.
For reference, Clutchmasters has a completely new part number for the 86's clutches that is not shared with any other car.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
FT-86 SpeedFactory (08-30-2013)
Old 08-30-2013, 11:43 AM   #22
charged86
charged86's Avatar
would you recommend the act or the spec for my car?
Old 08-30-2013, 12:30 PM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I think you are wasting time going down a rabbit hole. Go with a clutch that is meant for the car. While our transmission is similar to the S2000 Aisin box, our engine and flywheel are all Subaru boxer, so it is unlikely any clutch kit not made for the twins will work in our application. You seem set on not utilizing the more popular ACT and Clutchmaster options. I know that SPEC clutches are really popular in higher horsepower cars like Terminators. Personally I think the ACT flywheel/clutch is the best value out there, and with your power, I would definitely get the 6 Puck.
charged86 (08-30-2013)
Old 08-30-2013, 12:40 PM   #24
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
i have the spec stage 2+ in my car. installed it last saturday. talk to brady @Pure Automotive . he has done quite a few frs/brz clutches and can get them to you very quick
The Following User Says Thank You to spitfire481 For This Useful Post:
Old 08-30-2013, 12:45 PM   #25
FT-86 SpeedFactory
ACT as it comes with flywheel.
Old 08-30-2013, 02:44 PM   #26
Calum
That Guy
Drives: 2013 asphalt FRS MT
lets talk about clutches.
It's sad that the first thing that came to mind was this.
http://stokers.ca/Documents/SSSClutch.zip
Anyway, so far from what I've read the clutch is different. But that was a good question. I know the VW 1.8T and Dodge Neon's pressure plate were identical other then the size of the holes for the dowel pins and the fact that the VW part had a stronger clamp load. I think it was an L drill bit or something to that effect, combined with an old turbo dodge disk and whatever neon flywheel you wanted and you had a very cheap clutch that would happily hold 400 ftlbs.
Old 08-30-2013, 04:13 PM   #27
charged86
charged86's Avatar
But I really like rabbits. Anyway yeah I will get the 6 puck act
Lets talk tires... frs10 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 10-04-2013 05:21 AM
Lets talk rev limiter. Method Engine, Exhaust, Transmission 7 06-13-2013 09:20 PM
Lets talk exclusivity whitejdm BRZ First-Gen (2012+) — General Topics 33 02-15-2012 01:17 PM
Lets talk weight KaliKev Scion FR-S / Toyota 86 GT86 General Forum 63 09-12-2011 12:05 AM
Lets talk suspension Midship Runabout Scion FR-S / Toyota 86 GT86 General Forum 42 05-20-2010 12:51 AM
