Old 08-25-2013, 09:16 PM   #1
frs10
Drives: tezla
Lets talk tires...
Looking to replace and shop around for 2 new sets of tires
1) summer performance tires
interested in the michelin pilot super sport
-anyone with knowledge with the difference and trade offs between the 17s and 18s?
2) winter tires
suggestions?
things to take into consideration
-mostly NY/NJ driving
-cost not really an issue
thanks in advance
frs10 is offline   Reply With Quote
Old 08-25-2013, 09:31 PM   #2
TheseColorsDontRun
Keep calm and drive on
TheseColorsDontRun's Avatar
Drives: 2013 WRB BRZ Limited 6M
The Continental ExtremeContact series are good tires (DW and DWS) for spring thru fall. I use General Altimax Arctic for winter. All the above I have had great success with.
TheseColorsDontRun is offline   Reply With Quote
Old 08-25-2013, 09:31 PM   #3
jflogerzi
jflogerzi's Avatar
For the PSS's its going to depend on your wheel choice. Personally I would stick with tire sizes that would fit on 17x9 or 17x8 rims. Most notable difference is going to be extra weight and tire height. If your looking for a semi aggressive tire size, stick with a 17x9 rim so you can go 235 or 245
Old 08-25-2013, 09:32 PM   #4
avp1
Drives: Traded BRZ for Supra
I am in NJ.
Here is what I run on:
Summer - Dunlop Direzza ZII - 17x8 wheels, 235/40-17
Winter - Dunlop SP Winter Sport M3 - stock wheels/size
After two seasons I have no much to complain about.
avp1 is offline   Reply With Quote
Old 08-25-2013, 09:33 PM   #5
jflogerzi
jflogerzi's Avatar
PSS are the better tire, but sometimes you can catch the DW's on sale for 500$(set of 4) One advantage to the DW's is they are on average 1-2 LBs lighter then the PSS's at the same or comparable size.
Old 08-25-2013, 09:43 PM   #6
frs10
Drives: tezla
so sticking with stock size 17s seem to be better the bet? doesnt seem like i gain anything from going to 18s except for paying more?
am i seeing this right?
so let me rephrase this a lil bit...
you have ur choice of a summer tire set and winter tire set - anything you wanted
what would your set up be?
Old 08-25-2013, 09:58 PM   #7
jflogerzi
jflogerzi's Avatar
For me M PSS's are great bang for your buck. Tons of grip, decent ride, and great tread life. I can't chime in on winters, but if you getting new rims, use your stockers for winter duty
Old 08-25-2013, 10:00 PM   #8
frs10
Drives: tezla
im trying to decide what to do... i dont want to upgrade the rims to 18s to only find out i wont get much out of it...
Old 08-25-2013, 10:02 PM   #9
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
You'll be fine with 18 inch wheels, theres plenty of cars here running 18's without a problem with performance or grip. Most don't even notice a change.
Old 08-25-2013, 10:03 PM   #10
jflogerzi
jflogerzi's Avatar
No need to get 18's on this car unless you were going to be making bigger power (IE Turbo/Supercharger) They just cost more and weight more unless you shell out big $$$$ for decent light weight 18's
Old 08-25-2013, 10:06 PM   #11
dem00n
dem00n's Avatar
Drives: Scion FRS
Huge numbers of wheel are in 18's inches only, unless hes a serious tracker i doubt he'll care about the cost/weight.
Old 08-25-2013, 10:07 PM   #12
frs10
Drives: tezla
anyone try these:
Potenza RE970AS Pole Position
Old 08-25-2013, 10:32 PM   #13
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Continental and General are the same tire company.
Suberman is offline   Reply With Quote
Old 08-25-2013, 10:35 PM   #14
Suberman
anyone try these:
No but these should be pretty good A/S tires.
http://www.tirerack.com/tires/tests/...y.jsp?ttid=165
Just don't rely on them in snow.
Probably the latest Michelin Pilot A/S 3 will beat them.
Lets Talk Component Speakers Skippman Electronics | Audio | NAV | Infotainment 34 01-09-2014 01:29 PM
Lets talk rev limiter. Method Engine, Exhaust, Transmission 7 06-13-2013 09:20 PM
Lets talk exclusivity whitejdm BRZ First-Gen (2012+) — General Topics 33 02-15-2012 01:17 PM
Lets talk weight KaliKev Scion FR-S / Toyota 86 GT86 General Forum 63 09-12-2011 12:05 AM
Lets talk suspension Midship Runabout Scion FR-S / Toyota 86 GT86 General Forum 42 05-20-2010 12:51 AM
