Old 08-28-2013, 05:38 PM   #29
ZDan
ZDan's Avatar
Drives: '23 BRZ
http://www.fuelly.com/car/scion/fr-s
278 FR-S's, 5673 fill-ups, 1,472,992 miles tracked
Overall Average = 27.5mpg
Minimum vehicle average = 21mpg
Maximum vehicle average = 35mpg
Old 08-28-2013, 07:13 PM   #30
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Damn that's pretty high. My average 50/50 commute I get about 28 not driving conservatively. Driving mad gives me 26.5 still =)
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 08-28-2013, 07:35 PM   #31
jflogerzi
jflogerzi's Avatar
Originally Posted by ntr0py View Post
Couldn't believe it this morning, but this is my 16 mile commute on the I-5 North in SoCal traffic from a Costco Gas to my work parking lot (in traffic)! I wasn't pushing it too hard but wasn't totally doing FE driving.
FR-S M/T with about 4500 miles on it and a full tank of gas!
Just wait, it will drop. I used to see that when I DD to work with my car. Get gas, and hop on the freeway .5 miles from the gas-station. 20 miles later I had that mileage. But drive on the streets for a few miles and watch the MPG drop
Old 08-28-2013, 09:31 PM   #32
fistpoint
Drives: Supercharged Golf Cart
Originally Posted by @Art_Mighty View Post
...downhill
No, just let off the gas and put it in neutral...it peaks at 127 until you hit the pedal again.
fistpoint is offline   Reply With Quote
Old 08-29-2013, 11:08 AM   #33
ntr0py
ntr0py's Avatar
Drives: '13 FR-S Asphalt M/T
I went out to lunch and pushed it harder. It dropped 10 MPG in under 20 minutes Now I'm sitting at my normal 31.5 MPG average (according to gauge which probably means 29.5 MPG).
ntr0py is offline   Reply With Quote
Old 08-29-2013, 11:10 AM   #34
ntr0py
ntr0py's Avatar
FYI, you actually get better mileage when you keep it in gear and let off the gas going downhill. It shuts off the injectors so no fuel goes in the engine. If you put it in neutral, it has to idle the engine to keep it from stalling.
The Following User Says Thank You to ntr0py For This Useful Post:
strat61caster (08-29-2013)
Old 08-29-2013, 12:08 PM   #35
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Originally Posted by WHITE View Post
The 46.5mpg was just a one time thing with my 265's and i have not come close to getting that again, i tried hard to get the highest mpg i could on that trip. On my normal commute to and from work all highway i get 27mpg +/- 0.5 with my 265's. with my stock wheels and tires i was averaging 31mpg on the same commute.
I have no clue about the whole speedo crap, i didnt even know the speed sensor was in the diff(never cared to looked for it to be honest) all i know is yime and time again ive checked my speedo versus other speed read outs and so far the most its been off was a "your speed is" sign saying i was 1mph slower then my speedo. idk im not going to try and figure it out, im just gonna continue to drive, i dont care about mpg at all i fill up when i need to fill up and thats it.
Tire size and speedometer calibration are also important to speeding violations, especially, speed on green/stop light cameras. Usually they have a small grace range, however with bigger tires it is useful to know the impact so you can "remember" to compensate! Remembering being the key word!
For the rear tire size quoted 60 mph on standard tires = 64.212 mph on the 265/40-18. That is going to be noticeable somehow!
smbrm is offline   Reply With Quote
Old 08-29-2013, 12:28 PM   #36
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
I get what your saying and i understand what it should be, but clearly nobody is reading what im saying......so ill try again........
when compared to the "your speed is" signs in construction zones, and gps, and other vehicles around me, Everytim(except the one time i was 1mph off) my speedo has been reading true at no matter what mph.
WHITE is offline   Reply With Quote
Old 08-29-2013, 01:04 PM   #37
jflogerzi
jflogerzi's Avatar
haha and it continue to drop.
Old 08-29-2013, 01:52 PM   #38
smbrm
smbrm's Avatar
I appreciate what you are saying.
So that suggests that(all other things being equal) "your" speedometer was off by almost that amount before you changed tires if its that close after you change.
For reference
http://www.paspeedo.com/calculator.htm
GPS is only accurate to 7.8 metres at 95% confidence.
You seem to have it rationalized. Hopefully the speed devices you are being judged by always work in your favour.
Good luck.
One thing that is for sure is the fuel efficiency of the FRS has a wide variation span.
The Fuelly range of FE quoted earlier is the observed range of "average" FE. Max and worst FE have been observed beyond these numbers. While it doesn't impact the numbers, the interpretation of what is city driving by each individual has an impact on how you can interpret and compare the Fuelly numbers to what you might be expecting.
Cheers
Old 08-29-2013, 01:57 PM   #39
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Soooooo unless theyre all wrong then my computer compensated for the change in size? Idk.
psychic ECU?
Old 08-29-2013, 02:13 PM   #40
WHITE
Thats pretty neat
WHITE's Avatar
Originally Posted by SloS14 View Post
psychic ECU?
Who knows, maybe they got super powers? My cars psychic, that other guys brz tried being the human torch......JUST THINK WHAT OUR CARS CAN ACCOMPLISH IF USED FOR GOOD.
Old 08-29-2013, 03:35 PM   #41
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
That depends on a lot of factors - you can't just plop down a single number like this. If conditions are right, you can do a lot better than 7.8 meters, but in bad conditions, it could be significantly worse too. Also, positional accuracy doesn't tell you much about the accuracy of a GPS speedometer - most of the errors in GPS are not randomly distributed, so GPS is much better at determining the difference between two positions than it is at determining absolute position (which is the reason why dGPS and WAAS work as well as they do). This means that GPS speed is pretty darn accurate, all things considered, and I would tend to trust it more than just about any other method (various reports I can find seem to indicate around 0.2-0.5mph speed error for consumer-level GPS).
chrisl is offline   Reply With Quote
Old 08-29-2013, 08:20 PM   #42
smbrm
smbrm's Avatar
I didn't just plop down a single number! I just quoted one of the numbers from the standard: http://www.gps.gov/technical/ps/2008...e-standard.pdf
It appears you have convinced yourself, so by all means, carry on. No further need for debate.
Hybrid power Perihelion Other Vehicles & General Automotive Discussions 6 06-28-2013 08:28 AM
My new plug-in hybrid fr-s t88supra Scion FR-S / Toyota 86 GT86 General Forum 7 06-16-2013 03:46 PM
GT 86 Hybrid. Would you? russv Scion FR-S / Toyota 86 GT86 General Forum 74 03-13-2013 03:31 PM
FT-86=Hybrid?!? Please say it ain't so... BoostJunkie Scion FR-S / Toyota 86 GT86 General Forum 60 08-31-2010 09:38 PM
Is it the LFA HYBRID?? Dark Other Vehicles & General Automotive Discussions 6 04-27-2010 09:37 PM
