#29 |
Drives: '23 BRZ
http://www.fuelly.com/car/scion/fr-s
278 FR-S's, 5673 fill-ups, 1,472,992 miles tracked Overall Average = 27.5mpg Minimum vehicle average = 21mpg Maximum vehicle average = 35mpg |
#30 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Damn that's pretty high. My average 50/50 commute I get about 28 not driving conservatively. Driving mad gives me 26.5 still =)
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
#31 | |
#32 |
Drives: Supercharged Golf Cart
#33 | |
Drives: '13 FR-S Asphalt M/T
#34 |
FYI, you actually get better mileage when you keep it in gear and let off the gas going downhill. It shuts off the injectors so no fuel goes in the engine. If you put it in neutral, it has to idle the engine to keep it from stalling.
| The Following User Says Thank You to ntr0py For This Useful Post: | strat61caster (08-29-2013) |
#35 | |
Drives: Scion FRS Ht Lva(AT)
Tire size and speedometer calibration are also important to speeding violations, especially, speed on green/stop light cameras. Usually they have a small grace range, however with bigger tires it is useful to know the impact so you can "remember" to compensate! Remembering being the key word! For the rear tire size quoted 60 mph on standard tires = 64.212 mph on the 265/40-18. That is going to be noticeable somehow! Last edited by smbrm; 08-29-2013 at 01:31 PM. |
#36 | |
Thats pretty neat
Drives: LOADING......
when compared to the "your speed is" signs in construction zones, and gps, and other vehicles around me, Everytim(except the one time i was 1mph off) my speedo has been reading true at no matter what mph. |
#37 |
#38 | |
So that suggests that(all other things being equal) "your" speedometer was off by almost that amount before you changed tires if its that close after you change. For reference http://www.paspeedo.com/calculator.htm GPS is only accurate to 7.8 metres at 95% confidence. You seem to have it rationalized. Hopefully the speed devices you are being judged by always work in your favour. Good luck. One thing that is for sure is the fuel efficiency of the FRS has a wide variation span. The Fuelly range of FE quoted earlier is the observed range of "average" FE. Max and worst FE have been observed beyond these numbers. While it doesn't impact the numbers, the interpretation of what is city driving by each individual has an impact on how you can interpret and compare the Fuelly numbers to what you might be expecting. Cheers |
#39 |
Drives: 2013 FR-S whiteout
#40 |
Thats pretty neat
#41 |
Drives: 2006 Cayman S, 2007 Outback 2.5i
That depends on a lot of factors - you can't just plop down a single number like this. If conditions are right, you can do a lot better than 7.8 meters, but in bad conditions, it could be significantly worse too. Also, positional accuracy doesn't tell you much about the accuracy of a GPS speedometer - most of the errors in GPS are not randomly distributed, so GPS is much better at determining the difference between two positions than it is at determining absolute position (which is the reason why dGPS and WAAS work as well as they do). This means that GPS speed is pretty darn accurate, all things considered, and I would tend to trust it more than just about any other method (various reports I can find seem to indicate around 0.2-0.5mph speed error for consumer-level GPS).
#42 | |
It appears you have convinced yourself, so by all means, carry on. No further need for debate. |
| Hybrid power | Perihelion | Other Vehicles & General Automotive Discussions | 6 | 06-28-2013 08:28 AM |
| My new plug-in hybrid fr-s | t88supra | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 06-16-2013 03:46 PM |
| GT 86 Hybrid. Would you? | russv | Scion FR-S / Toyota 86 GT86 General Forum | 74 | 03-13-2013 03:31 PM |
| FT-86=Hybrid?!? Please say it ain't so... | BoostJunkie | Scion FR-S / Toyota 86 GT86 General Forum | 60 | 08-31-2010 09:38 PM |
| Is it the LFA HYBRID?? | Dark | Other Vehicles & General Automotive Discussions | 6 | 04-27-2010 09:37 PM |
