Old 08-29-2013, 01:01 AM   #799
Dezoris
Dezoris's Avatar
I clamped every vacuum line as suggested when the intake manifold was off. I could see how you could clamp without but would be difficult for sure.
This may help like it did for Nelsmar to see what is under the manifold.
Originally Posted by 448hpsti View Post
I remove nothing to do the hose under the manifold, its all about steadyness, patience, and remaining very very calm, think surgery
I DO move the one hose out of the way thats clipped into the manifolds side clips
raising the car helps
use the right tools, angled pliers for spring clips and for angling the screw driver I trim off about 4mm of a plastic tab when using a screw clamp, but depending on how you angle tthe screw clamp that may not be needed
using the OE 'holes' they provide for your screwdriver to reach the clamp
think it thru and position the screw part of the clamp right
its all technique, the hose under manifold is done with both hands, and without removal of compressor or TB
stand on driver side
right hand behind manifold
left hand in front
both hands palms down
use both pointer fingers to locate the nozzle, carefully start hose
depending on whether you use a spring clip clamp or a screw clamp its a bit different from there
belt swap is very ez
also able to be done without removal, undo the two alternator bolts last, swing the entire sc plate back swap belts and wala,
both are solo jobs
The Following 3 Users Say Thank You to Dezoris For This Useful Post:
charged86 (08-29-2013), civicdrivr (08-29-2013), Sportsguy83 (08-29-2013)
Old 08-29-2013, 01:37 AM   #800
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by Dezoris View Post
Thanks man, I will have the dyno videos and interviews up next week, detailing all of this. If you can get me anymore dyno plots that would help.
Thanks again for the one on one vids we did in my car. I can't wait to see the final outcome
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 08-29-2013, 03:36 AM   #801
charged86
charged86's Avatar
@Dezoris with the money shot
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post:
Old 08-29-2013, 10:46 AM   #802
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by charged86 View Post
On mine for ample room I remove the upper charge pipe and the throttle body. And the ac compressor!!
Way easier to pull the manifold.
Old 08-29-2013, 11:55 AM   #803
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Search amazon for Vde Angle Shape Pliers
by NWS
448hpsti is offline   Reply With Quote
Old 08-29-2013, 11:55 AM   #804
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Respectfully disagree...
Old 08-29-2013, 12:23 PM   #805
nelsmar
left hand in front
both are solo jobs
Can you take a picture of these "holes" ? even if its just a cell photo. I meant to ask you for this when on the phone but we kept getting side tract lol
Thanks again for sending that pic late at night, sorry if I woke you. I was stranded for almost 8 hours -.- This pic saved my ass. Multiple tow trucks refused to tow my car etc when this hose came off. I had no idea it was even there...
And to think the extremes of diagnostic we went through for it to be a damn hose. LOL
My flickr - Canibeat
Local magazine scout
Old 08-29-2013, 01:34 PM   #806
King Tut
NASA SpecE30 Racer
King Tut's Avatar
When mine blew off, I thought I had blown the motor. I limped it home, and it wouldn't idle for shit, and I could hear the air escaping, but I couldn't find it. I contcted a Subaru tech who said it might be the throttle body gasket so I removed the throttle body and everything looked good. I was about ready to drive it to him to have him take a look at it, when I contacted LJ @FullBlown who immediately assured me I hadn't blown the motor, and that it was just a vacuum line under the manifold. I pulled the manifold that night, and I was back on the road. I am glad that most are finally figuring out about clamping these hoses. If you are running 10+psi it is just a matter of when it will blow off.
Old 08-29-2013, 01:40 PM   #807
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Mines are getting clamped this week.
Old 08-29-2013, 01:47 PM   #808
charged86
charged86's Avatar
[quote=nelsmar;1175878]Can you take a picture of these "holes" ? even if its just a cell photo. I meant to ask you for this when on the phone but we kept getting side tract lol
Old 08-29-2013, 01:58 PM   #809
Dezoris
Dezoris's Avatar
You want to avoiding pulling the manifold for numerous reasons.
1. You need replacement, intake manifold gaskets, and throttle body gaskets.
2. You need backup o rings for the port injectors they sheer off/crack easily.
3. You have to remove the injector driver, and plates from both sides of the fuel rails.
4. If its your first time removing it, plan on 3+ hours.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
448hpsti (08-29-2013), charged86 (08-29-2013)
Old 08-29-2013, 02:22 PM   #810
DJCarbine
Thupercharged
DJCarbine's Avatar
I will take pictures and maybe video when I do mine... I'm going to try to avoid taking the manifold off and go for the good ole reacharound
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 08-29-2013, 03:17 PM   #811
Chase Bays
Chase Bays's Avatar
Drives: FR-S | 335i | S13
That hose that people have blown off on the CPC Solenoid (Under intake manifold with Blue 2P connector) we blew that off as well. You can just remove the 10mm bolt on the back of the solenoid and slide it forward to get a ziptie or clamp on it. Tracked the car after doing this and haven't had the problem since.
Also removed the charger (10 minutes) so we can install a smaller pulley for more boost, went ahead and removed the AC compressor for a new Air Oil Separator.
Chase Bays is offline   Reply With Quote
The Following User Says Thank You to Chase Bays For This Useful Post:
Old 08-29-2013, 04:00 PM   #812
charged86
charged86's Avatar
you will have to using caution doing this technique if you pull on the solenoid under the manifold it is possible to pull off where the vacum comes out of the manifold. and ya might as well use a hose clamp if you are able to get ahold of it any way
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
