Old 08-23-2013, 06:07 PM   #211
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Originally Posted by bluesubie View Post
Oh, I forgot about the E85. See the elevated wear on the STI UOA above. That one doesn't show high copper though.
"regal" on this forum pointed out that there are many uoa's being posted here with elevated copper. I would say that if the levels don't look normal by 18-20k miles, it might be time to get a super uoa.
http://dysonanalysis.com/Dyson_Analysis/Welcome.html
Terry Dyson is like hiring a personal tribologist to work for you. Blackstone may point out that you have elevated wear, but Dyson will provide audio commentary on each reading and help you pinpoint the cause for the wear (if it's actually wear and not still break-in noise). He'll also help you choose the best oil for your application.
-Dennis
Yea I'll consider that. I plan to change the oil at 7000 miles and I'll take another sample to send off. I figure that should be good for comparison purposes.
I figure I'm still fairly low mileage and this will be only the 3rd oil change i've done in its life. I think it should straighten up after this, but we'll see.
Ranatsu is offline   Reply With Quote
Old 08-23-2013, 06:11 PM   #212
kanundrum
Drives: 2013 Whiteout FR-S
TLDR Version on Oil and Filter Combo??
Old 08-23-2013, 06:59 PM   #213
OrbitalEllipses
Drives: Attitude
Motul 300V. Aftermarket cold air. High Si content still present, possibly due to the filter of the cold air.
kanundrum (08-23-2013)
Old 08-28-2013, 07:39 PM   #214
Blorb
Drives: GBS BRZ
Here's the UOA from my BRZ's first oil change, 5,500 miles on the factory fill. Also worth noting I gained a couple mpg after the change, using Toyota 0w-20.
Blorb is offline   Reply With Quote
The Following 2 Users Say Thank You to Blorb For This Useful Post:
bluesubie (08-29-2013), R L Newb (08-29-2013)
Old 08-29-2013, 01:32 AM   #215
levifig
GBS Mafia Member
levifig's Avatar
Drives: N/A
Are any of you guys taking the car to the dealer for oil changes? I really don't feel like scheduling, taking it down there (35 miles away), waiting around, etc… and don't mind doing it myself. Is that pretty standard? Anything special with Subaru's (or Toyota's) "dealer care"? I'm at ~1600 miles and wanting to do an early first oil change because of all the metals that mix in during break-in… I've heard of some advising first oil change before 500 miles for those reasons…
Just wondering…
levifig is offline   Reply With Quote
Old 08-29-2013, 10:17 AM   #216
bluesubie
Drives: 2004 Subaru Forester 2.5XT
Just wondering…
From what I read, the oil changes are very easy to do on these cars. But don't be in a rush to change your oil early. Just look at the above good oil analysis at 5,500 miles on the factory fill. The metals there are measured in parts per million. It's not like there are huge chunks of metal floating around. The info that you hear about changing the oil early is from 1979. The factory fill also has additional additives (molybdenum and a little more ZDDP) that are beneficial for break-in, so I wouldn't be in a rush to change it.
There really isn't a consensus on this (or any oil topic) so do whatever makes you feel comfortable.
-Dennis
bluesubie is offline   Reply With Quote
The Following 2 Users Say Thank You to bluesubie For This Useful Post:
levifig (09-01-2013), R L Newb (08-29-2013)
Old 08-29-2013, 10:25 AM   #217
Ranatsu
Cone basher
Just wondering…
You can change the filter if you feel really concerned, but its not necessary to change the oil that early. I would wait until at least 3000.
The Following User Says Thank You to Ranatsu For This Useful Post:
Old 08-29-2013, 11:03 AM   #218
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Just wondering…
Modern engines don't benefit from early oil changes which is why they are no longer specified. Put another way, modern engines take longer to fully break in and actually need the factory fill oil for longer. The oil filter takes out any particulates that would be large enough to cause any problems. Metal "bits" that could pass through the filter do no harm whatsoever. Bits in the oil cause problems only if large enough to disrupt the oil film inside a bearing.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
Old 08-29-2013, 11:50 AM   #219
frs10
Drives: tezla
just a side question, ive been watching a lot of DIY oil change videos and dont see anyone doing a flush after they drained the oil... is there a reason why?
frs10 is offline   Reply With Quote
Old 08-29-2013, 12:41 PM   #220
Ranatsu
Cone basher
Unless you could flood the engine with a fluid moving at a reasonable rate, I don't see what flushing would do. At best it would clean out the oil pan.
Old 08-29-2013, 12:49 PM   #221
frs10
Drives: tezla
if u left drip open and just dumped some new oil through it wouldnt that flush it or u need something more high powered to actually flush?
Old 08-29-2013, 12:56 PM   #222
Ranatsu
Cone basher
The oil fills almost straight into the oil pan, just off the top of my head it may go through the drivers side head. So you wouldn't be flushing the entire engine anyways by just letting it drain through. If you wanted to flush it, you would at least have to fill the oil, drive it around for a bit and then drain it again, but whats the point? The oil filter is there to catch any debris.
frs10 (08-29-2013)
Old 08-29-2013, 01:06 PM   #223
frs10
Drives: tezla
ah, i see
thanks for explaining that
Old 08-29-2013, 06:43 PM   #224
R L Newb
Drives: LR BRZ Ltd, 06 STi
Thanks for adding to the thread! Any reason you went with the Toyota oil instead of Subaru?
R L Newb is offline   Reply With Quote
DIY BRZ / FR-S Oil Change RallySport Direct DIY (Do-It-Yourself) Guides 169 09-01-2018 03:42 AM
First Oil Change Jehuty77 CANADA 14 08-10-2012 12:54 AM
When to do your first oil change, and why... MrBodyMassage Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-17-2012 08:43 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 05:44 AM
