Old 04-27-2013, 06:29 PM   #43
JerryMichaels7
Drives: Whiteout FRS
What extra nannies goes off with pedal dance vs just holding trac control for 3 secs?
JerryMichaels7 is offline   Reply With Quote
Old 08-23-2013, 08:12 PM   #44
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
Does the car require a wheel alignment if the car hopped. i have read somewhere that wheel hop can throw the alignment off badly.
vignesh is offline   Reply With Quote
Old 08-26-2013, 12:57 PM   #45
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
the wheel hop comes from the traction link that stops the rear knuckle from moving forward and back. we need a solid link to hold a little pressureon it, but the bushing for that is pressed into the knuckle itself so not a easy swap. I hate wheel hop. I get it on drag tracks and wet days
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 08-26-2013, 01:36 PM   #46
Calum
That Guy
Drives: 2013 asphalt FRS MT
This might be of interest.
http://www.whiteline.com.au/product_..._number=W63414
Old 08-26-2013, 02:57 PM   #47
mike the snake
I watched a vid of the rear diff moving around with the stock bushings. As much as the diff deflects I would say that shoring up the diff with stiffer bushings would go a long way towards reducing or eliminating wheel hop.
Old 08-26-2013, 03:00 PM   #48
Dipstik-sportech
Dipstik-sportech's Avatar
I have whiteline diff mounts in my car while they did help the hop is still there.
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
civicdrivr (08-26-2013)
Old 08-26-2013, 07:38 PM   #49
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
What about the subframe bushings?
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-26-2013, 07:46 PM   #50
Dipstik-sportech
Did those too, no effect
Old 08-26-2013, 10:19 PM   #51
Calum
That Guy
What air pressure are you running in the tires? What tires?
Have you tried an FRS to see if they have the same problem and/or to the same degree?
Old 08-26-2013, 10:21 PM   #52
Dipstik-sportech
Stock tires 33psi. Mickey Thompson drag radials 17psi at the track
Old 08-27-2013, 07:49 PM   #53
Calum
That Guy
And your getting wheel hop with both? I've got my stock tires at 38 psi and I haven't noticed any wheel hop.
The MT DR shouldn't have much spring rate to them. The last time I ran DR's I was down at about 12 psi, but that was awhile ago and a completely different setup. I think I ended up with about 11.5 on the drivers side and 12.5 on the passenger side when cold. The Quaife LSD wasn't enough to offset the horrible track prep at the local track and the drivers side always seemed to let go first. This was enough for me to be able to side step the clutch at 5800 rpm and still hook. The car was gutless, but man it was fun to watch people's faces when they realized a stock looking Neon just cut a 1.9 60.
/ramble
Old 08-27-2013, 08:26 PM   #54
Dipstik-sportech
Lol. I barely get hop with the dr's. I think it has to do with the low first gear ratio not allowing enough wheel speed to fully break traction. If I use launch control in second gear there's no hop just tire smoke lol
Old 08-28-2013, 01:48 PM   #55
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Originally Posted by Calum View Post
hmm not bad I'm goinna have to take a look under my car
IG-Joey_Soul
Old 08-28-2013, 05:42 PM   #56
mike the snake
Do the subframe bushings move that much? In the under-car vid I watched, I could see the diff itself moving a BUNCH, but I couldn't see the subframe bushings move at all.
I know on my BMW 135i, it made a Huge difference, and was the first thing anyone did when improving the suspension. The 135i subframe moved over an inch with stock bushings, but the BRZ/FRS subframe I couldn't see it moving at all.
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 03:55 PM
OK wheel gurus, wheel are here, now for tires FRSGT86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-12-2013 01:36 AM
Wheel Gap & Wheel Size white_knight Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-26-2013 10:01 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
